CLUG – A Simple and Elegant Bicycle Mount
Wall Mounted Bicycle
Indoor bike storage can be a challenge, you want to bring your pride and joy inside but the bike takes up space, it needs to be out of the way and also accessible. The CLUG is compact and elegant, a prize winning product to help you store your bike. This tiny product from Hurdler Studios in Vancouver, Canada is a head-turner, but it also comes with limitations.
Let’s start with the great attributes – it is super compact and if you have a spare corner or space against a wall, the CLUG is unassuming when it is holding your bike… and also when it is not. The modern design comes in different flavours so you can colour match to suit your style; a white or black outside and orange, green, blue or black inside.
Tiny bike mount clug
From the packaging, the CLUG promises to be small
If this suits your space, it is a superb solution. In practice you simply stand the bicycle up on the back wheel and press the front wheel into the CLUG holder which takes a nice grip on the wheel. Removing is just as simple, pull out the front wheel and then set the bike down.
The limitation is that the CLUG has to suit your space, if you want the bikes off the floor then this is not the solution for you. For wall hanging you could turn to the Cycloc, another artistic bike holder or a Bunnings budget solution. The CLUG can save you some space when the bike is positioned vertically which makes it a good option in some locations but unsuitable for others. Over time I am also expecting a side-effect of tyre marks on the wall.
Hi, I'm your Clug
Hi, I’m your CLUG
Unboxing Club Bicycle Mount
Out of the box, (the inside piece is reversed)
What's in the box Clug
Screws and plastic wall anchors are provided.
Installing the CLUG is relatively simple. I read and followed the brief instructions, the tiny packing of the CLUG is used also a guide to help mark the correct height and position of the holder on the wall. My first attempt to install the CLUG however failed, you can see what happened in the following short video.
Following this failed installation attempt, I found a second location against a cupboard and faced two further challenges, the plastic wall plugs and screws were not a good match so I switched over to German hollow-wall style anchor plugs which expand and some better screws with a larger thread. With these upgrades, the outside was then quickly fastened against the cupboard and the inside plastic piece clicked into place to complete the job.
Mounted Clug
The Francesco Moser has a nice place to call home
The good news was that my carbon fibre and my classic road bike both share the same wheel base (distance between the axles) which meant that the one CLUG was the perfect height for both bikes. The road version of the CLUG which I used suits road bikes with a tyre width between 23 – 32mm. I have a 23mm width on one bike and 25mm on the other. While the skinny tyres are easier to insert and remove, the grip was solid for both. The CLUG also comes in a version for urban bikes called the hybrid for tyre widths between 33 and 42mm and a version for mountain bikes which suits 43 – 62mm.
retro bicycle mounted
25mm wide tyres
Tyre Rim Clug
23mm wide tyres
In overview, it is a relatively simple product which is very fairly priced at $25 USD, this is converts to $35 Australian and includes worldwide shipping. A faster option is ordering from the Australian online shop where the total price is the same, $30 each and $5 shipping.
The CLUG gets my thumbs-up. For disclosure, the odds were tipped in its’ favor as I was already on the search for an elegant solution for my bikes. You can see the colours and order from the US or locally at
Alternative Text
About The Author
Christopher Jones is a recreational cyclist and runs a professional design business, Signale. As the driving force behind he has one of each 'types' of bicycles.
Comments are closed.
