Punctured tubular
- Parrott
Punctured tubular
Postby Parrott » Sun Feb 13, 2011 2:11 pm
First flat I've had in 2 years of running singles on my race wheels so not a bad run. Just a pity it was the front that is hardly worn.
Re: Punctured tubular
Postby brendeng » Sun Feb 13, 2011 2:55 pm
http://www.tufo.com/tufo-tyre-sealant/ ... The extreme one is for use after getting the puncture. It says it is for use with all Tufo tyres, can't see any reason why it wouldn't work with another type of Tubular. I think there are some products out there from other companies to do the same sort of job.
Brenden
Look 695 SR, Dura-Ace Di2, FSA Carbon Bars, Mavic Cosmic Carbone SL's, Elite Cages, Prologo Nago Evo
- Parrott
Punctured tubular
Postby Parrott » Sun Feb 13, 2011 3:12 pm
- foo on patrol
Postby foo on patrol » Sun Feb 13, 2011 3:31 pm
Goal 6000km
- aeroslave
Postby aeroslave » Sun Feb 13, 2011 4:19 pm
- ZepinAtor
Postby ZepinAtor » Sun Feb 13, 2011 4:29 pm
http://www.effettomariposa.com/prodotti_en.html
- Parrott
Punctured tubular
Postby Parrott » Sun Feb 13, 2011 6:08 pm
ZepinAtor wrote:Easily fixed with a can of PitStop or Espresso which contains latex & has proven it self thousands of times in repairing mtb & road tyres. About $25 retail. Just shove it on the valve & let it rip.
I've got a couple of cans of pitstop but understood it is only a get you home fix? I've never actually used the stuff yet.
- ZepinAtor
Postby ZepinAtor » Sun Feb 13, 2011 6:40 pm
From their website------------->permanently repairs tubular and clincher inner tubes with a latex foam that vulcanizes and seals the tube. Will fix most punctures where a thorn, nail or small fragment of glass has penetrated the tube.Parrott wrote:
Ideal for rapid on the road repairs especially Triathlon
Inflates a 21mm tubular up to 6.5bar (91psi) and a clincher tire up to 6bar (84psi)
Permanantly repairs punctures
Provides up to 3 months flat-protection after injection (the latex foam acts as anti-pucture)
Low weight weighs just 70g and adds just 18g to a repaired tube
Universal nozzle can be easily used with any valve without need for an adapter
- foo on patrol
Postby foo on patrol » Sun Feb 13, 2011 7:02 pm
I realise that, but the second post was talking about Tufo Tubular Clincher, so I thought I was missing something.aeroslavebigbelly wrote:Punctured "Tubular" = Glued on.
Goal 6000km
Postby brendeng » Sun Feb 13, 2011 7:19 pm
Tufo makes a range of Tubular's that are run on a Clincher bead ... http://www.tufo.com/c-s33-pro/ ... sort of the best of both worlds. I ran them for a while, I like to give some different things a go. At 160psi on a good stiff wheel, they were ultra quick.foo on patrol wrote:I realise that, but the second post was talking about Tufo Tubular Clincher, so I thought I was missing something.aeroslavebigbelly wrote:Punctured "Tubular" = Glued on.
- foo on patrol
Postby foo on patrol » Sun Feb 13, 2011 7:55 pm
Goal 6000km
- Parrott
Postby Parrott » Sun Feb 13, 2011 8:42 pm
Great, I had a look and it was as you quoted thanks. I will give one can a go tomorrow thanks.ZepinAtor wrote: From their website------------->permanently repairs tubular and clincher inner tubes with a latex foam that vulcanizes and seals the tube. Will fix most punctures where a thorn, nail or small fragment of glass has penetrated the tube.
- Parrott
Punctured tubular
Postby Parrott » Mon Feb 14, 2011 12:04 pm
Couldn't find a 3 corner jack or any other likely culprit in the tyre. Plenty of cuts nicks and pinholes when you look closely at the outside of the tyre though.
- ZepinAtor
Postby ZepinAtor » Mon Feb 14, 2011 2:29 pm
Don't forget that compressed air from CO2 canisters only lasts 24hrs. Something to do with the molecules being smaller than regular air from a hand pump hence escaping & resulting in a fairly flat tyre by tomorrow.Parrott wrote:Gave the pit stop a blast today. Seems to have worked, the tyre has held its air for a couple of hours so far. Put a 170 psi in it. The leak was a slowish one anyway but quicker than 2 hrs.
If you bother reading the side of a CO2 canister it says only for emergency use & to replace with regular air as soon as practical/ possible.
- Parrott
Punctured tubular
Postby Parrott » Mon Feb 14, 2011 4:11 pm
ZepinAtor wrote:Don't forget that compressed air from CO2 canisters only lasts 24hrs. Something to do with the molecules being smaller than regular air from a hand pump hence escaping & resulting in a fairly flat tyre by tomorrow.Parrott wrote:Gave the pit stop a blast today. Seems to have worked, the tyre has held its air for a couple of hours so far. Put a 170 psi in it. The leak was a slowish one anyway but quicker than 2 hrs.
No worries they usually lose a fair bit of air overnight anyway because of the latex tube. It's still pretty hard now, I have a 16k tt tomorrow arvo so I'll see how it goes. Looks like you've saved me throwing out the tyre unnecessarily
Postby ironhanglider » Mon Feb 14, 2011 10:45 pm
For the record tubulars can be repaired and it is just about as complicated and has the same amount of black magic attributed to it as building wheels. In other words whilst pretty much anyone can do it, but not many can be bothered finding out how and would prefer to pay someone else (and it gets easier with practice ).
There is an article by Jobst Brandt on Sheldon's site here http://www.sheldonbrown.com/brandt/tubular-repair.html and quite a thread on it here http://weightweenies.starbike.com/forum ... um.php?f=3.
BTW tyre sealants make repairs difficult, so it would seem that there are the two schools of thought, the sealers and throwers, and the repairers. For a while the only tubulars that I used were other people's cast offs that I had repaired (before sealants). The biggest problem I've found is finding a suitable glue to re-attach the base tape to the tyre.
Cameron
- Parrott
Postby Parrott » Tue Feb 15, 2011 12:55 pm
Thanks for the link, after reading it I'm one of those sealers and chuckers, looks like more effort and time than I am prepared to invest. One puncture in two years I'm happy with, considering the amount of caltrop we get here at certain times of the year.ironhanglider wrote:Hope your tyre continues to hold up.
Cameron
- foo on patrol
Postby foo on patrol » Tue Feb 15, 2011 5:58 pm
Goal 6000km
- Parrott
Punctured tubular
Postby Parrott » Wed Feb 16, 2011 7:19 am
- ZepinAtor
Postby ZepinAtor » Wed Feb 16, 2011 8:37 am
What was your average speed ?Parrott wrote:Did my tt and all good. Thanks again Zepinator.
- Parrott
Punctured tubular
Postby Parrott » Wed Feb 16, 2011 11:49 am
