how to remove a frozen pedals??
For Roadies
Postby Paycheck » Thu Aug 11, 2011 11:38 pm
I'm trying to change to clipless pedals but the flat one just stuck on crank...any tips???
Paycheck
by Forum Ads » Fri Aug 12, 2011 8:57 am
Re: how to remove a frozen pedals??
Postby JV911 » Fri Aug 12, 2011 8:57 am
are you trying to turn it the right way?
the left (non-drive) side has a reverse thread, so turn it clockwise to undo
<---LACC--->
<---BMC SLR01--->
JV911
Postby DaveOZ » Fri Aug 12, 2011 9:02 am
Get some freezing spray. I use Wurth Rost OFF ICE but I think WD40 do one now. Make sure you are turning the right way. Lean on it HARD.
DaveOZ
Postby biftek » Fri Aug 12, 2011 5:15 pm
spray it down with wd40 , let it sink in , shove the spanner on you might need to give it a tap with a hammer
biftek
Postby mitzikatzi » Sat Aug 13, 2011 6:39 pm
mitzikatzi
Postby damhooligan » Sat Aug 13, 2011 6:47 pm
If it is frozen, use heat to melt it... :mrgreen:
But make sure you turn it the right way... :wink:
The dutch have one word to describe the aussie MHL, this word is ;
SCHIJNVEILIGHEID !!
damhooligan
Return to Road Biking
Users browsing this forum: Redbull
