For Roadies
by jeff_o » Tue Dec 20, 2011 10:51 am
I'm about to swap frames: planning to buy 1 size larger as my current frame is small for me. I need opinions on cables, when you swap frames, do you buy a new set of brake/shift cables and housings?
I tend to reuse the old cables but after each rebuild you cut a small portion at the end of the cable (had to cut the housing too). New frames might have the cable stoppers located differently too, so i dunno how you guys handle this?
jeff_o
by Forum Ads » Tue Dec 20, 2011 11:14 am
by ozdavo » Tue Dec 20, 2011 11:14 am
Cables are cheap - get a full new set of inners & outers.
ozdavo
by jeff_o » Tue Dec 20, 2011 11:17 am
is there a particular brand? or technology of inners and outers that i should be looking for? e.g. teflon or silicon lined, fine or coarse braided, etc etc?
jeff_o
by simonn » Tue Dec 20, 2011 1:36 pm
I have to admit that when I did a frame swap I reused some of the cables... chopped the rear brake and gear cables to use for front ones. Call me stingy, I say Reduce, Reuse, Recycle  .
simonn
by pawnii » Tue Dec 20, 2011 5:21 pm
definitely get new cables.
I've tried a hell of a lot of cables out there. Shimano, Sram, Gore, Nokon, Powercords, Aligators, iLink and Yokozuna. They all have there pros and cons. I have to say Yokozuna are the best IMO. (they're also probably the hardest to setup also) I've heard the new PTFE cableset from Shimano are excellent also but no one has used them for over 6mths so it's hard to say how long they'll last. Powercordz inner cables are crap on Sram shifters. Only hardcore weightweenies should use them.
FYI i have Sram Red groupo. What groupo do you have?
pawnii
by boyracer » Tue Dec 20, 2011 7:23 pm
save 50 %!!! use back one in front mech + back brake on front. Clean and lube. Spend the rest on beer/clenbuterol.
boyracer
by jeff_o » Tue Dec 20, 2011 10:36 pm
pawnii wrote:FYI i have Sram Red groupo. What groupo do you have?
I got Ultegras. @boyracer: lol.. clenbuterol haha. lance? alberto? lol
jeff_o
by biker jk » Wed Dec 21, 2011 4:30 pm
I've been happy with Jagwire inner cables and outers. Not very expensive as well.
biker jk
by twizzle » Wed Dec 21, 2011 5:28 pm
boyracer wrote:Spend the rest on beer/clenbuterol.
I ride, therefore I am. ...real cyclists don't have squeaky chains...
twizzle
Return to Road Biking
