You could be in for a warranty replacement maybe ? Had the same issue / argument with Trek about a year ago with 2 cracks in the bottom bracket, rear stay and fork where the lugs are fused with the carbon
Titanium Road BikesRe: Titanium Road BikesComedian, might be worth talking to the guys at paint my bike to get their opinion as they are very familiar with carbon cracks / repairs and might be able to point out if any of the issues you have with the frame is leading to failure
There is an unfounded popularised belief that carbon does not fatigue. But there is evidence it does. http://en.wikipedia.org/wiki/Carbon_fibre
Ti and steel will only last long-term if built strong enough for the rider's weight. It really comes down to getting something (at least) slightly overbuilt (depending on the quality of the build) if you want it to last.
Re: Titanium Road BikesVery interesting nobody.
I just went down and compared to my bike to a current defy advanced and while on the same test it still flexed I would say it moved probably only half as much. I really doubt I'm going to ever be able to say whether it has gotten worse with age or whether its just a dead fish frame. Once you can climb hills on a bike it's all downhill.
Hopefully I'll know what that's like..... one day. ![]()
Re: Titanium Road BikesI'd be leaning toward fatigue. I'd doubt new frames are that much stiffer than a few years ago.
The good thing about metals is they generally will have the same feel/ride/flex over their life span. I've got a Giant CrMo MTB frame I bought in approx. 1991 which doesn't feel any less stiff than it was new.
Well, let's put some numbers to it, then: http://www.freewingmasts.co.uk/fwmtabl1.htm It's all relative, but after a million stress cycles that stainless steel is down to less than half its original strength, the aluminium alloy to a third.
Re: Titanium Road BikesThanks. Not a surprising result from a manufacturer of carbon masts. There appears to be results, but no link to the methodology. It's like Calfee with its "Technical White Paper" on carbon frames, which has been discussed before. viewtopic.php?t=54908&p=832549
Re: Titanium Road Bikeshttp://www.baumcycles.com/archives/1146
The story behind the bikes ..... maybe a little OT but still cool
Out of interest, what benefits do you feel from the HED rims and do you think they are caused by the rim width or the different spoking patterns?
Are you still at it Nobody This section does not cite any references or sources. (June 2012) From that highly credentialed wikipedia link that you chose to cite as evidence of CF's fatigue limit I saw this bit in it too Carbon-fiber-reinforced polymer (CFRP) has over the past two decades become an increasingly notable material used in structural engineering applications. Studied in an academic context as to its potential benefits in construction, it has also proved itself cost-effective in a number of field applications strengthening concrete, masonry, steel, cast iron, and timber structures. Its use in industry can be either for retrofitting to strengthen an existing structure or as an alternative reinforcing (or prestressing material) instead of steel from the outset of a project.
Re: Titanium Road BikesThe issue with carbon fibre used in bicycles is the quality of the resin/expoxy used to glue it all together. For most carbon fibre items, this degrades over time so after a few years your carbon frame will be less stiff than when it was new. Manufactureres of higher-grade carbon (e.g. Enve) supposedly use a better epoxy/resin.
Or so I've been told.
Re: Titanium Road BikesWell after much agonizing I've joined the Baum waiting list.
Re: Titanium Road BikesYou'll have to be more specific as I don't know what you're rattling on about. And? Believe it or not, I actually read the article. I'm not trying to hide that CF has it's uses, just don't expect it to be long term fatigue fee when built into a bike frame.
Re: Titanium Road BikesWell I hope you get your money's worth out of it. More likely to than spending the same amount on a carbon frame IMO.
Re: Titanium Road Bikes...As long as it's built right in the first place, and doesn't crack...
Welcome to the club
End of useful life/recycling This section does not cite any references or sources. (June 2012) Despite its high initial strength-to-weight ratio, one structural limitation of CFRP is its lack of a fatigue endurance limit. As such, failure cannot be theoretically ruled out from a high enough number of stress cycles As you used that "article" to illustrate that carbon is susceptible to fatigue failure, i thought it pertinent to point out that it's author could have pulled it out of thin air. Just being objective
Well, I did third-year Materials Engineering at uni. All other things being equal, carbon fibre will be better at fatigue resistance than either of those materials. I'd be interested if you can find anything that says differently. PS I have a foot in both camps, with a carbon roadie and a 'Steel is Real' one. Mixed marriages are so interesting!
Re: Titanium Road BikesOh, I see it now. Also I was not saying it was susceptible to fatigue failure (although it probably is) just fatigue, which the mast link shows anyway (although optimistically as expected from a manufacturer).
Well, how do you know? You're the one wanting hard facts and figures. Show us they're false or optimistic!
I've been in it since the middle of July. I hope you aren't in a hurry.
Re: Titanium Road BikesI've owned a CF bike in the past too. The other two materials being SS and Al, I'm in agreement. If I remember correctly SS is considered one of the most brittle steels (for lack of another good descriptor). Remember the below thread? Not too confidence inspiring. viewtopic.php?f=34&t=51878 What we need is a fatigue comparison of say 4130 to CF. But the problem is, as soon as anyone posts a CF figure, being such a varied composite, someone else will say that it's a different structure/layup/epoxy etc or that it was last week's CF and today's CF is so much better now. Although I have a good idea of what I think will and won't last and the reasons for it, it is still something difficult to conclusively prove here, other than showing personal experiences.
Re: Titanium Road BikesShow us they aren't.
I'm not expecting to see it until the middle of next year. I just hope I can keep the current bike running until then. Once you can climb hills on a bike it's all downhill.
Re: Titanium Road BikesI'm aware that Baum is considered one of the best, but surely there are others you can buy from. Isn't there? They are often cheaper too.
Yep. But as you rightly observed I wanted a great bike that fits me made with the characteristics I value. They are expensive but I spend a lot of time on the bike. I reckon they will be cheaper than the 3 year upgrade cycle the industry is pushing. Once you can climb hills on a bike it's all downhill.
