Another Speedplay vs.. question
Marty Moose
Re: Another Speedplay vs.. question
Postby Marty Moose » Fri Nov 16, 2012 1:13 pm
twizzle wrote:
southeastD wrote:Oh, I have tried everything, oil, grease, loosen the screws. The screws on mine barely touches the cleats and I still have issues clipping in. It's ridiculous. The store are happy to give me a replacement and I might do that. I suspect the cleat supplied may have had a circlip that's overly too tight out of the factory.
Didn't put the C-springs in upside down, did you?
Are you sure the base plate is flat?? Use a straight edge to check it mine are really easy to clip in and out of. Something is not right. Mine are zeros.
twizzle
Postby twizzle » Fri Nov 16, 2012 1:43 pm
Marty Moose wrote:Are you sure the base plate is flat?? Use a straight edge to check it mine are really easy to clip in and out of. Something is not right. Mine are zeros.
Good call - even when using the correct shims under the base plate, often there is still a gap. My current shoes weren't compatible with the provided shims, instead of trying to find a way of ordering the alternative shims, I ended up putting sandpaper on the shoe and rubbing away the high spots on the shims to get it flat. Not perfect, but close enough.
I ride, therefore I am.
NeillS
Postby NeillS » Fri Nov 16, 2012 1:46 pm
Yeah they shouldn't be that hard to clip in to. Only three things are possible here;
1) baseplate not completely flat. Check with straight-edge
2) spring clips in the wrong way
3) Thighs not strong enough :D
toppity
Postby toppity » Fri Nov 16, 2012 3:08 pm
sounds like so many things to think about.
Just buy some Keywins, the lightest pedal going, screw them in to your cranks, fit the cleat to any shoe, click the cleats into the pedals and ride your bike. :D
Rich-Ti
Postby Rich-Ti » Mon Jan 28, 2013 5:56 pm
I've been on and off Speedplay for a few years now. Finally tried Shimano after almost two years back on Speedplay - never has my pedal stroke felt so solid and supported. The pedals are cheaper, and the cleats are MUCH cheaper. I've sold all of my Speedplay stuff now.
jcjordan
Postby jcjordan » Mon Jan 28, 2013 6:29 pm
Rich-Ti wrote:I've been on and off Speedplay for a few years now. Finally tried Shimano after almost two years back on Speedplay - never has my pedal stroke felt so solid and supported. The pedals are cheaper, and the cleats are MUCH cheaper. I've sold all of my Speedplay stuff now.
Cleats may be cheaper as individual but I replace speeplay once every 9 months and shimano every 4week's
James
Rich-Ti
Postby Rich-Ti » Wed Jan 30, 2013 12:41 pm
True. Kind of irrelevant compared to the platform stability though.
jcjordan
Postby jcjordan » Wed Jan 30, 2013 12:45 pm
Rich-Ti wrote:True. Kind of irrelevant compared to the platform stability though.
Actually it does play to suitably. My problem with shimano cleats was that after s couple of weeks they were no longer reliable in terms of connecting to the pedal. Would regularly pull my foot out when sprinting. Never done this in speedplay
James
Dr_Mutley
Postby Dr_Mutley » Wed Jan 30, 2013 1:30 pm
twizzle wrote:
NeillS wrote:Regarding the float...
I don't need the float as such, I need a pedal which can handle my twisted tibia. Even with 12mm longer axles, my heels almost rub the cranks.
and your worried about being Euro-cool? ;-)
With regards to setup, I wouldnt think there is anymore setup with SPs than other pedal systems (ie screw on baseplate, and screw on cleat; put pedal in bike). The next step, the bike fit, is where SPs are much easier to setup than most other pedal systems. Fore/aft, rotation, and medial/lateral placement are all independent adjustments of each other, unlike other plastic 3hole cleat systems. You also don't have the issue of cleats moving when tightening them up.
Definitely more preventative maintenance upkeep of the SPs, which only takes 2 seconds every week or so...
Dr_Mutley
Postby Dr_Mutley » Wed Jan 30, 2013 1:42 pm
I agree wholeheartedly here. Even with new SP zeros and cleats, with no float dialled in, the platform stability will never approximate that of look or shimano no float systems
twizzle
Postby twizzle » Wed Jan 30, 2013 2:45 pm
Yes, but the commuters on them all look like idiots as they struggle to clip in when taking off from lights. :twisted: Yay for double-sided!
And I tried out the "keep on kovers", dead after nine weeks, not cost effective.
doggatas
Postby doggatas » Wed Jan 30, 2013 7:31 pm
My pedal history plays out something like this:
Shimano 105
Speedplay Zeros
Shimano ultegra
Look keo blades 16nm
Shimano dura ace 9000
Best pedals so far(when new) are the look blades. After a few thousand km's they wear out and become loose(yes I replaced the cleats), I have had two sets. Also when you crash and slide the bit that sits proud of the pedal body shears down.
Haven't received my 9000s yet but from all reports they are the bomb, if my ultegras were anything to go these will be beauts. Only reason I went with the looks because the ultegras were worn after many km's and a mate suggested them.
Now onto the speedplays: maintenance issues aside I just never felt completely stable/connected to them. In saying that they are incredibly easy to clip in and out of. I put them on my misses bike for this very reason.
