best wheelset for all day use $1000 to $1500
For Roadies
Postby scratcher33 » Wed Nov 28, 2012 3:55 pm
Upgrade of Fulcrum Racing 5 Evolution - what to go for - Fulcrum Zero, Mavic SL, c24 Dura ace or other suggestions - like building some to suit - I want a really light clincher - aluminium or carbon
scratcher33
by BNA » Wed Nov 28, 2012 6:52 pm
Re: best wheelset for all day use $1000 to $1500
Postby AlMac » Wed Nov 28, 2012 6:52 pm
All those will be better than Racing 5s.
I have Mavic Kysrium Elites and they have been great with only some very minor issues with rear hub which just needed re-greasing ($20 worth) in three years.
If buying factory wheels again, I would go DA c24. Good weight. Great hubs. Great price at CyclingExpress at the moment on the clincher.
I think you will find with building a set that the weight may be slightly above the DA c24 or similar. I am going for bike shop build for my next set (Velocity A23 on White Industry Hubs with DT spokes) and they've be about 110g more than DA c24's, although I suspect a chunk of that is due to the A23s being wider on the rim than the DA c24s (at least I think so - I read the DA c24 9000s haven't gone to 23mm width on the rim).
AlMac
Postby SmellyTofu » Wed Nov 28, 2012 7:47 pm
Zipp 101
SmellyTofu
Location: Obviously not on the bike when I'm online in Sydney
Postby MarkG » Wed Nov 28, 2012 7:59 pm
Fulcrum Zero
S-Works Venge
MarkG
Postby paulz » Wed Nov 28, 2012 10:59 pm
Look into Rolf Prima's which use a White Industries hub. If you want light then go for the Elan model. Up-spec to the alpha version.
I was looking at the Elan's originally, but shifted to the Vigor alpha which have the ceramic bearings and titanium hub. They are a sweet ride. The 23mm wide wheel has improved the ride quality from my Reynolds Solitudes.
You can pick them up through Vonact which is based in Queensland - contact is Matt von Bibra.
paulz
Postby Crawf » Thu Nov 29, 2012 9:16 am
If you're going to go that much $, go custom and get what suits your weight/terrain.
Crawf
Postby MarkG » Thu Nov 29, 2012 9:37 am
If they're an every day wheel, stick to an off the shelf, top line alloy clincher like the Zero, Dura Ace etc. $1500 will get you either, plus some decent rubber and a heap of spare tubes
S-Works Venge
MarkG
Postby scratcher33 » Thu Nov 29, 2012 11:33 am
Thanks blokes - I went to LBS today - and went for the American Classic Magnesium - super light 1108g - the reviews are pretty good on these too - and I like the idea of a light wheel as age creeps up - got a good deal too .. i think
scratcher33
Postby MarkG » Thu Nov 29, 2012 11:48 am
Nice choice! That's light as!
Are they AC hub or DT Swiss ?
S-Works Venge
MarkG
Postby mezla » Thu Nov 29, 2012 2:39 pm
Dura Ace 7900 C35
mezla
Postby Crawf » Thu Nov 29, 2012 3:23 pm
That is crazy light and 28/32h, I hope those super light 300g rims are durable enough.
Crawf
Postby __PG__ » Fri Nov 30, 2012 9:45 am
I just finished building my new wheels, Alchemy Hubs laced to Hed Belgium rims with Sapim CX-Ray spokes. Quite stiff and responsive, reasonably light (1600 g with skewers and rim tape) and with 28/32 spokes..hopefully indestructible.
My next wheels will be White Industries/H Plus Son Archetype ... will be interesting to see how the White Industries hubs compare.
1994 Cecil Walker custom steel frame with Shimano Ultegra STi
2013 Baum Corretto custom titanium frame with SRAM Force
__PG__
Postby Crawf » Fri Nov 30, 2012 10:11 am
I've got some Archetypes on the way now to go on the commuter, looking forward to the wider rim.
Crawf
Postby southeastD » Mon Dec 03, 2012 2:58 pm
scratcher33 wrote:Thanks blokes - I went to LBS today - and went for the American Classic Magnesium - super light 1108g - the reviews are pretty good on these too - and I like the idea of a light wheel as age creeps up - got a good deal too .. i think
Are you in Melbourne? Wondering if you could hook me up for a pair as well. How much are they btw? Cheers,
southeastD
Postby scratcher33 » Tue Dec 04, 2012 9:29 am
I am up in Darwin - the wheels are on order with my LBS - however, I have also mailed the Australian distributor to get a time frame on the delivery of the wheels - not looking good - could be a more than a few months
scratcher33
Postby usernameforme » Tue Dec 04, 2012 7:16 pm
get yourself a custom set; I'd suggest Kinlin XR-270 or H Plus Son Archetype laced to Alchemy hubs with Aerolites, well within your budget. The advantage of a wheel like this is that the rims are relatively cheap so they can be replaced should the worst happen or the brake track is worn out.
In regards to the AM MAG rims, I've heard a few reports that the brake track isn't the most durable, much softer than alloy. I would personally not use these daily.
___________________________
Giant Defy Advanced 0
Shogun Katana
usernameforme
Postby jd73 » Wed Dec 19, 2012 5:49 pm
Fulcram zero, by far the best wheels for $1,100 or so
jd73
jd73
Postby mezla » Thu Dec 20, 2012 9:28 pm
jd73 wrote:Fulcram zero, by far the best wheels for $1,100 or so
Better than Dura-Ace 7900 C35? Hmm, I'd like to see that.
mezla
Postby MarkG » Thu Dec 20, 2012 9:37 pm
Cos you're the know all on here eh mezla..
S-Works Venge
MarkG
Postby boss » Thu Dec 27, 2012 10:03 pm
HAhahahah. OH HAI MEZLA. You know how to make a guy smile.
Despite c35s being usually priced a little higher than $1100 O/S ($1200-1400 abroad - so add duty to that, $1500+ locally), and zeros being available locally (I.e. inc GST and duty) for $1100 and under $1k from Merlin in the UK (no GST/duty). And that's assuming we are talking 7900 not 9000...
They artillery and heavier than what the OP seems to want. Sure, aero is important, but if your a climber aero doesn't mean that much and weight is much more important.
You're talking 1600g (c35s) vs 1400g (zeros) which is not something you sneeze at. And 1600 vs 1100 for the American Classics is pretty crazy.
If you were preaching about DA 7900 c24s I would be on your side - I have a set on order. Sub 1400g, alloy braking surface, low profile, and apparently quite tough. Ideal for day in day out use and climbing duties.
And just personally I probably wouldn't run 35mm as my do-it-all wheelset, id personally stick under 30mm. While it wouldn't be a total handful in cross winds, I'd be 'on edge'. But that's just me andi accept there are different opinions and different appetites for risk.
boss
Postby mezla » Sat Dec 29, 2012 8:37 pm
ps: I got mine for $1170 incl postage from Ribble.
mezla
Return to Road Biking
