Shimano R320 Carbon Shoes Custom molding
For Roadies
Postby ephesiangts » Tue Feb 05, 2013 12:16 pm
Hey guys,
Just picked up my R320's. Great shoe.
Unfortunately don't have a Shoe oven so what is the best* method to custom mold them to my foot?
Cheers.
ephesiangts
by Forum Ads » Tue Feb 05, 2013 2:25 pm
Re: Shimano R320 Carbon Shoes Custom molding
Postby MichaelB » Tue Feb 05, 2013 2:25 pm
You need some sort of oven to warm the shoe (easy bit), but then the hard bit is to get the vaccuum pump setup to mould them to your feet.
I picked up one a while ago as part of a package deal that I must get rid of.
Reality is that unless you buy the setup off me , you have to go to a bike shop that sells them and get them to do it. Normally, if you buy them from the LBS, they'll charge bugger all or nothing to do them, but if you bought them elsewhere, they can charge up to $75.
Shimano tech doc
http://www.youtube.com/watch?v=5YGTGsIOtGY
Up to 1:10 is the easy bit, the hard bit is after that.
MichaelB
Postby jamesn184 » Wed Feb 06, 2013 1:40 am
I've also heard it makes little difference...
jamesn184
Postby MichaelB » Wed Feb 06, 2013 7:53 am
jamesn184 wrote:I've also heard it makes little difference...
Depends on how comfortable you are in your current shoe.
99% sure it won't make you faster, but if you are more comfortable, you can more than likely go for longer.
Have you actually tried them ?
MichaelB
Postby MarkG » Wed Feb 06, 2013 9:32 am
Heat molding Bonts tho does make a world of difference I believe .
S-Works Venge
MarkG
Postby jamesn184 » Thu Feb 07, 2013 2:14 pm
I have the r240's which can be heat molded to but was told by the lbs that he tried them at a trade show and felt no better
jamesn184
Postby toolonglegs » Thu Feb 07, 2013 2:29 pm
I have the shimano ones, for me the heat molding was a HUGE difference... They are a bit worse for wear now after nearly 6 years!!!... But are still so comfortable the thought of having to get new shoes scares me!.
Postby ephesiangts » Sun Feb 10, 2013 4:02 pm
I have riden them 3 times now and they feel better, but still some gaps that could be eliminated if moulded.
How much we talking for your kit?
Otherwise, anybody know a LBS in Sydney area that does it?
Steve
ephesiangts
Postby sb944 » Mon Feb 11, 2013 1:22 pm
I bought the same shoes from BikeBug online, the shop front said they'd do it for $50, but didn't think it would be worth it if I already had custom soles. At this stage I'm not going to do it, but then the shoes feel right as is.
sb944
Postby MichaelB » Mon Feb 11, 2013 1:39 pm
ephesiangts wrote: ...
Steve
Hi Steve, I presume you are talking to me ?
If so, I'd be looking at $200 + postage for the oven (basic toaster type oven rather than the proper 'Shimano' one, but it's the same) and the Vac pump (the real cost of the setup).
It's pretty heavy.
Let me know if you are interested
MichaelB
Return to Road Biking
Users browsing this forum: FXST01
