SRAM XX1 XG1199 11 Speed 10-42T Cassette
KL.
Postby KL. » Sat Feb 09, 2013 6:13 pm
Hi All, SRAM have released a XX1 XG1199 11 Speed 10-42T MTB Cassette and its for sale here ... http://www.chainreactioncycles.com/Models.aspx?ModelID=91007 and http://www.chainreactioncycles.com/Models.aspx?ModelID=91023... does anybody know much about SRAM new 11spd cassette and RD to go with it :-)
I know this is a MTB cassette but is SRAM intending to do something similar with their road cassette ...
PS: Here's a bit of info on the RD ...
SRAM XX1 11 Speed Rear Mech Technologies:
- X-Actuation - Designed specifically for SRAM XX1, X-Actuation keeps shifting sharp and consistent across the entire 10-42T cassette.
- X-Sync - A "wide tooth, narrow tooth" pattern is repeated around the pulley wheel, perfectly mirroring the chain's inner and outer links for maximum control.
- Cage Lock - With Cage Lock, wheel removal and installation - becomes faster and simpler. Just pushing the cage forward to create slack and lock it into place.
- Roller Bearing Clutch - Roller bearing clutch technology eliminates derailleur bounce and chain slap without sacrificing precision.
- X-Horizon - Straight parallelogram design limits all movement to the horizontal axis, which makes ghost shifting impossible while also reducing shift force. For quicker, more exact shifting, the large upper pulley offset design maintains a constant chain gap across all gears.
Brownster
Re: SRAM XX1 XG1199 11 Speed 10-42T Cassette
Postby Brownster » Sat Feb 09, 2013 9:03 pm
Running it on my Merida 96 Team. Absolutely love the simplicity of the single front ring with the new development of the rear derailleur.
No chain slap !!!
gabrielle260
Postby gabrielle260 » Sat Feb 09, 2013 9:57 pm
I'd love to put it on my Lynskey 29er but I understand there are few compatible hubs.... I'll be interested in following this topic!
Postby singlespeedscott » Sat Feb 09, 2013 10:28 pm
Concept sounds great but the aesthetics are hideous. It looks like the pie dish off an old Repco 10 speed.
KL.
Postby KL. » Sun Feb 10, 2013 7:52 pm
42t sprocket is huge and it can apparently be as large as 44T. With a sprocket that large there should not be an issue with the RD cage striking the spokes ...
So one could run 10-44T cassette with 44/46T crankring for a road setup, although the largest crankring for the MTB setup is 38T :-)
rkelsen
Postby rkelsen » Sun Feb 10, 2013 9:57 pm
singlespeedscott wrote:Concept sounds great but the aesthetics are hideous. It looks like the pie dish off an old Repco 10 speed.
Can't argue with that. Wouldn't stop me from testing one though, if I had a set of compatible wheels, that is...
KL.
Postby KL. » Mon Feb 11, 2013 10:17 am
It would appear that there are no wheel compatibly issues, only the need for a compatible XD Driver freehub for your wheel ...
XD Driver freehub - The XD retains a portion of the current splined interface, but adds threads on the outside of the freehub body. The X-Dome cassette has an internal sleeve that acts like an integrated cassette lock-ring. To install, one simply places the cassette on the driver body and uses a Shimano lock-ring tool to spin the internal sleeve onto the freehub’s threads, securing the cassette in place.
In an industry awash in competing standards it’s refreshing to see a company develop a new technology that places an emphasis on minimizing compatibility issues. The motivation was less of an act of altruism than it was a sound strategy to ensure that this new freehub standard would gain widespread acceptance. To this end, SRAM has made the technology open to all hub manufacturers who agree to follow the tighter tolerances the XD driver body requires. The manufacturing details and a list of companies who have signed on to XD driver standard can be found at http://www.xddriverbody.com. This list currently includes Mavic, DT Swiss, Bontrager, Specialized, Syncros, Easton, Stan's, Hope, FRM, Tune, Novatec and Crank Brothers.
KL.
Postby KL. » Mon Feb 11, 2013 10:20 am
It's amazing that the cassette only weighs 260gms ...
KL.
Postby KL. » Tue Feb 12, 2013 10:11 am
Hints appear to be that the road version will be released here ...
SRAM Sea Otter Road Classic Race, Friday and Saturday, April 19-20, 2013 ... All Road Race categories will start on Laguna Seca Raceway at the Sea Otter Bridge. The route continues down Barloy Canyon Road to the classic Fort Ord race loop. After completing the required laps for your category, you will climb back up Barloy Canyon, to its crest, for a mountaintop finish. Sea Otter Classic is part of the Northern California and Nevada Cycling Association (NCNCA) series and NCNCA point system.
http://www.seaotterclassic.com/index.cfm/competitive_events_rb_sram_road_bike.htm
