TCR advanced owners: where to mount rear light?
jeff_o
Postby jeff_o » Fri May 03, 2013 2:59 pm
Hi fellow TCR advanced owners, or any wedge shaped aero seatpost road bike owners: where do you mount the rear safety led lights? i've been figuring this for days. mine is the traditional cateye rear led light that has the round seatpost mount, but our seatposts are aero shaped.
Marty Moose
Re: TCR advanced owners: where to mount rear light?
Postby Marty Moose » Fri May 03, 2013 3:31 pm
I Don't use those types.One is a moon light with a bungy the other a Magicshine also with a Bungy. I use my cat eye and clip it top my Jersey but always have one or two mounted to the bike as well
reefer
Postby reefer » Fri May 03, 2013 4:36 pm
Go ask for the rear red reflector that comes with the bike, but is rarely supplied to customers and use that.
Covered here viewtopic.php?f=12&t=62505
le_quiet_uno
Postby le_quiet_uno » Fri May 03, 2013 4:58 pm
Have you tried seat stay? Or the back of your helmet?
That's where I put my wife's light.
Other alternative is to get Knog lights.
2009 - Current - BMC SL 01 [2009]
2008 - 2009 - Cervelo R3 [2008]
2007 - 2008 - Trek 1.4 [2005]
jeff_o
Postby jeff_o » Fri May 03, 2013 5:08 pm
unfortunately i only have a seat post mount for the cateye and i got the bike used so no reflectors. i checked the seat stay and it's triangular shaped (like an aerodynamic blade). i guess i have to just get the silicon ones OR do a DIY to mount the cateye under the seat. that would look cool!
reefer
Postby reefer » Fri May 03, 2013 6:13 pm
Find a giant store, ask, I am sure they will have plenty spare….
tk38
Postby tk38 » Fri May 03, 2013 10:01 pm
niterider stinger is actually designed to work with aero seat posts
Gerry.M
Postby Gerry.M » Fri May 03, 2013 10:16 pm
I'm hoping this type of bracket will fit on mine once I pick it up, but may be a little short... I'll let you know.
http://compare.ebay.com.au/like/3308796 ... eItemTypes
It has a reasonably long strap but otherwise may need cable ties
HAKS
Postby HAKS » Fri May 03, 2013 11:15 pm
I use cateye but had to buy one of their aftermarket brackets which fit my TCR post.
Edit: Here is the link http://www.wiggle.co.uk/cateye-rear-light-clamp/ . It is flexible enough to mould the TCR aero post.
Current Ride: Trek Madone 6.5 (2013)
Gerry.M
Postby Gerry.M » Sat May 04, 2013 6:24 pm
Gerry.M wrote:I'm hoping this type of bracket will fit on mine once I pick it up, but may be a little short... I'll let you know.
Works a treat - it is probably quite similar to the cateye one mentioned above. The light is a Tioga Dual Eyes which came with this type of mount.
From the rear:
dale79
Postby dale79 » Sat May 04, 2013 8:22 pm
just buy a giant rear light.. made to suit the aero seat post
jeff_o
Postby jeff_o » Sat May 04, 2013 8:47 pm
just great, 1 of the 3 LEDs in my cateye died. time to get a new one with the right mount.
Farmer Elvis
Postby Farmer Elvis » Mon May 06, 2013 9:52 pm
Mine clips onto the little saddle bag that has tube etc in located under the seat.
aditwahyu
Postby aditwahyu » Tue May 07, 2013 8:19 am
im using the knog elastic rubber and mounted on the seatpost directly
dale79
Postby dale79 » Tue May 07, 2013 8:55 am
Killswitch
Postby Killswitch » Wed May 08, 2013 2:52 pm
tk38 wrote:niterider stinger is actually designed to work with aero seat posts
This. +1
open roader
Postby open roader » Mon May 20, 2013 9:08 pm
I've a bike with similar aero profile seatpost. I fixed this with a Cateye RM-1 clamp. Goes onto the saddle rails, and tucks your light under the saddle - very neat.............
http://www.evanscycles.com/products/cateye/rm-1-rear-saddle-mount-bracket-ec035721
warthog1
Postby warthog1 » Tue May 21, 2013 5:12 pm
Needed to mount a rear light in a hurry to my Cervelo P2C.
Worked a treat :)
durianrider
Postby durianrider » Wed Jun 12, 2013 12:44 pm
I use a Nite Flux red zone 4. I clip it on the back of my jersey.
Note to cyclists riding in bunches using rear lights : please put em on solid mode vs flash mode.
Vegan since 2001.
Pedaling
Postby Pedaling » Wed Jun 12, 2013 8:52 pm
If you are using a fizik seat, you can purchase a light that clips onto the seat.
Check out the link; http://www.fizik.it/en/accessories/lights/Blink/black/
AUbicycles
Site Admin
Site Admin
Postby AUbicycles » Thu Jun 13, 2013 12:02 am
As a TCR owner the light issue has been a bit of a sore spot for me after losing a Radbot where the strap broke and the knog blinder type lights with clasp simple don't fit. The silicon only strap light are ok, though these are lower powered lights.
I have just gone for a moon light which seems to be well rated, better suited to aero posts with the chunky rubber strap. WIth my saddle bag I can't fit a light there and have lost too may lights mounted in the light strap.
Previously I had a great helmet upon which I had a light mounted, it fit perfectly in the rear and I felt was a good solution.
coyote
Postby coyote » Thu Jun 13, 2013 6:01 pm
+1 for the Moon lights, run them on all my bikes, good rubber strap and very bright light that is usb rechargeable. 8)
g-boaf
Postby g-boaf » Thu Jun 13, 2013 11:39 pm
I've got a Moon light on my TCR Advanced SL - it does have a mount for the saddle rails, but with the saddle bag there, that makes it pointless. So you have the rubber strap that IMO doesn't seem too trustworthy.
You could get the Giant rear reflector (designed for the ISP type TCR bikes) and use the clip it comes with to mount a standard light. Just screw the light mount onto it. I did that with a Bontrager rear flashing light. But it is not very bright.
black4tress
Postby black4tress » Tue Jun 18, 2013 5:13 pm
Cables ties are the easiest way to go and works most of the time.
Otherwise, the Moon lights are good for ISP.
[Centurion LeMans Single Speed] [BMC Fourstroke FS03]
sylloxtric
Postby sylloxtric » Sun Jun 23, 2013 9:53 am
Standard Giant mount (came with the rear reflector) plus Radbot 1000. Works a treat!
