Bianchi Sempre Pro with a pannier rack?
zill
Postby zill » Tue Dec 17, 2013 11:37 pm
I recently bought a Bianchi Sempre Pro and am very happy with it.
However, I am also a commuter and would like to replace my old commuting bike. There are pannier racks out there that can be fitted to a road bike with no rack mounts (e.g. http://www.axiomgear.com/products/gear/ ... -road-dlx/) but is the Sempre Pro strong enough to carry a pannier bag on a daily basis that could range between 10kg to 40 kg?
I have heard positive things mentioned about the construction of the Sempre Pro and how it is stronger than most other carbon bikes such as on this website http://www.competitivecyclist.com/bianc ... -pro-frame
The paragraph below is from this site:
"Bianchi has incorporated a few proprietary construction methods to the Sempre's carbon design. For one, it's been made stronger by using Bianchi's Carbon NanoTube technology. This process involves adding nano-scaled particles to the resin. By doing so, the particles reduce the microcopic gaps between the resin and the fibers of the carbon. Ultimately, this increases the strength and fracture-resistance by 49% compared to using standard epoxy resin systems."
But does that make the Sempre Pro able to carry a potentially heavy pannier rack?
Please note that I usually cycle on a flat bike path for about 2 hours each day.
Thanks.
Pravda
Re: Bianchi Sempre Pro with a pannier rack?
Postby Pravda » Wed Dec 18, 2013 1:04 pm
Please don't.
Sent from my GT-I9300 using Tapatalk
2014 Canyon Aerode SLX
Puegeot Aneto 105
Kona Jake the Snake CX
eeksll
Postby eeksll » Wed Dec 18, 2013 2:32 pm
zill wrote:The paragraph below is from this site:
pretty sure that paragraph is sourced directly from the Binachi marketing site.
Are you sure your going to be carting 10kg +? I sometimes commute with a over-full ortlieb rear pannier. Even when its heavy it would not touch 10 kg. If your commuting much lighter and dont have a carbon seat post something like a "Topeak RX Beam rack" would probably suit better. Especially if you need to remove it for weekend rides.
