Colour is sorted.......Finally FINISHED!!!!!!! Yay for me!
- Lark2004
Postby Lark2004 » Mon Dec 08, 2008 10:55 pm
Kukamunga, can you shed any light into the frames history, or did I buy it pretty much how you had received it?
I only ask because whoever did the powdercoating sucked bigtime.
BTW, I still don't know what colour I'm going to finally put on her, but it will be dark.
- fatherofmany
- Location: Central Coast NSW Australia 33°26'16"S 151°20'39.50"E ish
Postby fatherofmany » Tue Dec 09, 2008 10:23 am
then mask them off.
then a black base coat over everything else.
then remove the masking and Candy Apple Red over the top.
then a couple of coats of clear to follow..
1, you get your dark colour.
2, you get to notice the lugs.
3, you get red and everyone knows that red cars go faster, why not the same with bikes!!
- im_no_pro
Postby im_no_pro » Tue Dec 09, 2008 12:09 pm
Thats where my thoughts were heading.... then I see someone beat me to the suggestion so +1fatherofmany wrote:Candy Apple Red over the top.
Postby Wazza » Tue Dec 09, 2008 2:09 pm
Excellent choice, I think Kukakukamunga wrote:Ah... that frame. Me thinks it needs a fluro rasta paint job!
But does really take a certain type to be able to ride the "Kolors" with flare (or was that flares)
Andrew,
Hands down winner, with all the highly polished extras, it will look a treat.
Waz
- munga
- munga
- Lark2004
Postby Lark2004 » Tue Dec 09, 2008 7:36 pm
And the depth really comes down to getting a good solid base of colour on, then at about 6 or 7 coats of clear.
On a side note, I've been doing some looking around for some rims to go with build. I decided a while ago that I would try and squeeze 27" rims into her.....they fit...very snuggly. Anyway, I'd been looking for something that looked more modern, and had a talk to Velocity.... end result is that they make two different 27" rims. Their website only lists the "Twin Hollow" a traditional looking 27" rim, however they also do make the "Synergy" in 27" on special order. At $99 each I think they are quite reasonable, and should really look good with the high flange hubs that I'm using.
- munga
- Lark2004
- Mulger bill
Postby Mulger bill » Wed Dec 10, 2008 7:48 pm
Yes please, sounds MegaFroodyLark2004 wrote:Ok......Last minute change of mind while I was buying paint. The frame is now "Hammertone Metallic Charcol".
Pics will follow soon.
Shaun
Postby kukamunga » Wed Dec 10, 2008 8:02 pm
- fatherofmany
Postby fatherofmany » Wed Dec 10, 2008 8:20 pm
You can even have a go at making your own by mixing them up. Or by adding a small amount of silicon oil to normal enamel paint, we haven't quite mastered it yet otherwise I'd let you know how much.
- Lark2004
Postby Lark2004 » Wed Dec 17, 2008 9:43 pm
The photo hasn't shown the colour very well.
It's suppost be a Hammertone Metallic Charcoal......but it's more silvery grey than Metallic Charcoal. I'm still happy with it so far. I still need to get some bits, the brakes are in the mail, and I pick up the handle bars tommorrow. Seatpost is yet to be bought, and I may have to rethink the wheels..... I had been planing on putting 27" rims on it, but I've been playing around with the 27" wheels off the Apollo (same hubs) and another set of brakes, and I think I'm going to have problems with the brake reach being to long....... ....... so 700c rims may be on the cards.
- Mulger bill
Postby Mulger bill » Wed Dec 17, 2008 11:48 pm
Looks damn nice so far.
Shaun
- Lark2004
Postby Lark2004 » Sat Dec 20, 2008 9:12 pm
I also have the handle bar's fitted, although they didn't fit the stem , I have used a clamp on stem with an 1" quill adaptor at the moment (to get the brakes and gears set up). I plan on machining a small bit out of the stem's clamp so that I can fit the bars properly......
Postby kukamunga » Sat Dec 20, 2008 9:42 pm
26.0mm bars in a 25.4mm stem?Lark2004 wrote:I plan on machining a small bit out of the stem's clamp so that I can fit the bars properly......
I've thought about modifying some of my MTB and old road stem collection to fit 26.0mm bars. Need to look into whether i can get a 26.0mm or adjustable reamer at not too great an expense....
How do you plan to 'machine' yours, Lark?
- Lark2004
Postby Lark2004 » Sun Dec 21, 2008 9:26 am
Postby kukamunga » Sun Dec 21, 2008 12:08 pm
Kerosene might work better than WD40 on aluminiumLark2004 wrote:I was thinking maybe a small engine/brake cylinder hone would do the job, it doesn't have to remove too much material, a minute in the drill press with plenty of wd-40 to flush it should do the trick....I have a few old stems that I can practice on first.
~0.5mm is a fair bit to hone, I would've thought - let us know how it goes.....
Users browsing this forum: OnTrackZeD
