Bicycle Storage - Gravity Bike Storage Rack - any good?
Postby hitch » Thu Feb 26, 2009 2:17 pm
http://www.crazysales.com.au/index.php? ... #pCodeSent
- sogood
Postby sogood » Thu Feb 26, 2009 2:29 pm
The simplest is to just go to Bunning and pay $7 for a two large screw-in hooks that allows you hang your bikes by their front wheel.
Postby Wrongway » Thu Feb 26, 2009 2:44 pm
Hooks to hang your bikes from the front wheel were no good for me as I wanted to mount the bikes along a wall.sogood wrote:Of course there are rip-offs.
Bunnings did however have the appropriate mounting brackets for $14 each and the end result is very similar to this bike rack (just obviously not portable).
- fatherofmany
- Location: Central Coast NSW Australia 33°26'16"S 151°20'39.50"E ish
Postby fatherofmany » Thu Feb 26, 2009 3:02 pm
Postby hitch » Thu Feb 26, 2009 3:07 pm
Simplest, but not best if you're in a rental apartment and are a bit wary of screwing large things into walls, when you can't even put pictures up. Will be doing that when I own my own place thoughsogood wrote:Of course there are rip-offs.
- herzog
Re: Bicycle Storage - Gravity Bike Storage Rack - any good?
Postby herzog » Thu Feb 26, 2009 6:16 pm
I've got one of these. For $50 it's a pretty good deal., holds two bikes quite snugly against the wall.hitch wrote:Has anyone had any experience with this sort of thing? Similar products in store cost > $200 sometimes, so I'm wondering, are bike stores ripping people off, or is this a piece of crap - or something in between?
It can also be used as a rudimentary workstand for the upper bike. This allows minor adjustments, like rear derailleurs or brake calipers, and gives you full access to turn the cranks. You can't turn the cranks of the lower bike.
It's not perfect though. Although it says it can be leaned against a wall, in practice, it's pretty unstable unless you connect the top to the wall to hold it steady.
This can be done with a single screw in the wall, and there is a little hole in the upper tube which you can sorta slide over the screw.
You can remove the stand in seconds, leaving just the screw behind, which you could hang a picture on to hide it.
Only other issue would be if you had two bikes which were both extremely tall, like Downhill bikes or other long travel (6"+) MTB. It won't accomodate two such bikes.
- ez
Postby ez » Thu Feb 26, 2009 11:16 pm
Ez
- tallywhacker
Postby tallywhacker » Thu Feb 26, 2009 11:57 pm
- sogood
Postby sogood » Fri Feb 27, 2009 12:10 am
I wonder how safe is it to use on gyproc ceilings? I'd be concerned it'll wear down and poke a hole in it, let alone crashing down.tallywhacker wrote:thisis always an option. My LBS uses almost the same thing to display their bikes
- tallywhacker
Postby tallywhacker » Fri Feb 27, 2009 12:14 am
- sogood
Postby sogood » Fri Feb 27, 2009 7:34 am
But is it enough? Those gyprocs aren't that strong are they? No problems for concrete ceilings or solid beams, but gyproc ceilings?tallywhacker wrote:thats why in the picture there is a block on the top and the bottom of the post. You're a "glass is half empty" type of guy aren't you ?
- Earthy Ochre Man
Postby Earthy Ochre Man » Fri Feb 27, 2009 8:15 am
Should be fine if you position it directly below one of the roof joists.sogood wrote:But is it enough? Those gyprocs aren't that strong are they? No problems for concrete ceilings or solid beams, but gyproc ceilings?tallywhacker wrote:thats why in the picture there is a block on the top and the bottom of the post. You're a "glass is half empty" type of guy aren't you ?
- sogood
Postby sogood » Fri Feb 27, 2009 8:32 am
Can accept that. Is there a technique to do that? Or are gadgets required?Earthy Ochre Man wrote:Should be fine if you position it directly below one of the roof joists.
- Earthy Ochre Man
Postby Earthy Ochre Man » Fri Feb 27, 2009 10:48 am
Just tap the ceiling to find where the timbers are, or look for indents or marks showing where the fixings are.sogood wrote:Can accept that. Is there a technique to do that? Or are gadgets required?Earthy Ochre Man wrote:Should be fine if you position it directly below one of the roof joists.
- peter
Postby peter » Fri Feb 27, 2009 11:23 am
http://www.topeak.com/mediafiles/products/1132/
Topeak Dual-Touch Bike Stand ($235):
http://www.topeak.com/mediafiles/products/1130/
- locco
Postby locco » Sat Feb 28, 2009 7:14 pm
Postby Joeblake » Sun Mar 01, 2009 12:06 pm
This is the beginning of another stand but I think it could be adapted to hold a bike.
Joe
Bertrand Russell
- Aushiker
Postby Aushiker » Sun Mar 01, 2009 2:59 pm
I got one of these the last time they where discussed here. I keep a steel roadie on it and Julia my XTC 2 mountain bike.
It works okay, reasonably stable but I find that my bikes, being larger sizes don't fit as well as I would like. They get caught up in each other etc.
Would I buy one again? Probably not.
Aushiker.com
- gorilla monsoon
Postby gorilla monsoon » Sun Mar 01, 2009 5:49 pm
- Aushiker
Postby Aushiker » Mon Mar 02, 2009 10:47 am
My one which looks the same in the OP's link is self-standing.Joehax wrote:So does the Gravity Bike Storage Rack work well without screws?
Aushiker.com
- tallywhacker
Postby tallywhacker » Tue Mar 03, 2009 10:30 am
