Page 1 of 1
Refitting tyres - The case of the protruding tube
Posted: Fri Apr 13, 2007 8:45 pm
by gururug
Howdy Yall,
I tried to replace the tyres on the new old bike I bought. It runs 27" rims and the tyres I got are identical to the ones I removed, 27" x 1"
The old tyres had little wear but the sidewalls were freying and bubbling a little so I didn't want to take chances.
Anyway I refit the new tyres and when I pump the front up, 5 minutes later the tube is protruding out the side and has lifted the tye off, before I can let the air out....BANG!
I am thinking this was because I didn't get the tyre fully over the tube. So I get a new tube, install, pump up, five minutes later it is starting to protrude again. I was pretty sure that I got all the tube under the tyre. I even slightly inflated the tube whilst I put the tye over to unsure it din't get stuck underneath.
So, the question/s are;
a) What could be the causes of this
b) What are the techniques to use to prevent this
Posted: Fri Apr 13, 2007 10:25 pm
by mikesbytes
It could be a faulty bead on the tyre
Posted: Fri Apr 13, 2007 10:36 pm
by Mulger bill
I think Mike's prolly got it. Is it happening at the same spot on the tyre every time? Otherwise a damaged lip on the rim could be the culprit.
Shaun
Posted: Sat Apr 14, 2007 10:23 am
by MountGower
I
Posted: Sat Apr 14, 2007 2:12 pm
by europa
I had a similar problem with the tyres on my son's Gitane, again 27x1 - maybe a coincidence. I've seen it happen before with bike tyres. It's a matter of being aware of it and watching the tyre as you pump it up. You'll usually see the bead that's not sitting right and that, I believe, is the problem. You haven't got the tyre seated properly, it starts to go skewiff and then, as you add the pressure, it gets worse.
The cure?
Put a bit of air in the tube and then check that everything's lined up properly - for a bead to be off the rim on one side of the wheel, it's got to be inside the rim on the other side of the wheel (across the diameter) and it's that point that you need to address - very easy to do on my son's old seventies Mavic rims. One you know you've got a problem, it's just a matter of pulling the tyre into place with your fingers (low pressure at this point, just enough to get things moving). One the tyre has been seated correctly once, it shouldn't be a problem. Pump her up to full pressure.
Then something I do with every tyre that's been fully deflated - bounce the wheel a few times with different contact points. Then check to see it's beaded properly - there's always a mould line around the tyre to check this with.
The first time it happened to my son's wheel, I'd actually refitted the wheel to the bike before the bead slipped out of place. However, I had done it in a rush and hadn't done the 'bounce' test, nor been too fussy about the bead. I reckon that's all that's happened to you.
Posted: Sat Apr 14, 2007 2:36 pm
by gururug
Well, I took the tread bake to the BS, they guy was a bit reluctant about the bead issue but eventually swapped it over none the less (with a tube that has a squashed area - he says this shouldn't be a problem and its due to the transporting).
I think richard may be right on this one or a combination of both. I didn't know it was even possible to get faulty beads. Is this common? Can it happen with foldables / 700c aswell?
Well, i'll try to whack it on tonight, taking extreme care to ensure it is as centered as possible on the rim.
Cheers for the comments.
:P
Posted: Sat Apr 14, 2007 3:55 pm
by Halfanewb
The mate rides a retro with the 27" wheel standard and he had the same problem on a few occasions, even once when he had left the wheel in the back of his landrover and in the full sun. We solved the problem eventually by putting a 23mm tube in. It seems the larger multifit tube could expand strangely and force the tire slightly over to one side and exceed the gripping force of the bead.
Posted: Sun Apr 15, 2007 6:24 pm
by gururug
Problem is solved, touchy tyre needs to be set 100% center, even then you've got to take it easy pumping it up. Go in 20psi increments after 60psi and wait 10minutes while watching both sides of the rim to make sure it doesn't blow on you. (only taken them to 100psi so far but that seems ok)
I think the last tyre was a little malformed (stretched) around one side though.
Thanks again all.
