How does a bike chain get so filthy?
Postby gururug » Fri Apr 20, 2007 10:26 pm
Gee I feel sorry for the MTB riders.
I only ride road but I just cannot understand how a bike chain get so filthy.
What percentage of grit on an average road chain after 200kms is road dirt and what percentage is metal ware?
gururug
by Forum Ads » Fri Apr 20, 2007 10:39 pm
Postby Mulger bill » Fri Apr 20, 2007 10:39 pm
What sort of lube are you using Guru?
On a similar note, does anyone know if Shimano 9x road chains will take a master link? (SRAM or Connex)?
Shaun
Postby sogood » Fri Apr 20, 2007 10:50 pm
Metal grinds, dirt sticks. Some oils are dirt magnet. A quick wipe after the ride and careful choice of lube should be able to keep your chain reasonably clean.
sogood
Postby Mulger bill » Fri Apr 20, 2007 10:54 pm
Do you use solvent on the rag Sogood?
Shaun
Postby gururug » Fri Apr 20, 2007 11:15 pm
Prolink...here
Very black soot
I am just surprised at how much gunk gets in there. Maybe iwasanewbie can give a scientifical breakdown if dirt has a different charge than the drivetrain thus "attracting" more grit from the air. Because I sure can see that much stiff getting "bumped" up from the ground into the chain.
gururug
Postby Mulger bill » Fri Apr 20, 2007 11:32 pm
I suppose a fair bit gets flicked up by the front wheel :?
I've had a look at Prolinks site, it's a dry lube so I got nothin'
I thought a roadie chain would need less cleaning too, but it don't look that way with Deni :roll:
Shaun
Postby gururug » Fri Apr 20, 2007 11:43 pm
Ooops, I thought it was called prolink, it actually tri-flow
gururug
Postby Mulger bill » Fri Apr 20, 2007 11:54 pm
Well the Triflow dry sounds a lot like the RockNRoll extreme I use, that don't get too gungy.
The wet stuff sounds pretty much like any wet lube to me.
Methinks we need someone of a scientific bent to weigh in about now...
Postby sogood » Sun Apr 22, 2007 11:32 am
I usually just use a paper towel that has a bit of lube spread in the middle, and then just run the chain through it. Yes, I should use an old rag for environmental reasons.
If you hate dirt, then dont' use Tri-flow. I have used it but found it to be excellent in the rain and lasts a long time. But dirt stick to your chain like superglue. :wink:
From what I understand, if you want something that works in the rain, then expect dirt. If you don't want dirt, then don't expect it to last in the rain.
sogood
Postby LuckyPierre » Sun Apr 22, 2007 3:11 pm
Mulger bill wrote: ... does anyone know if Shimano 9x road chains will take a master link? ...
I can say "yes" to that one, because I've been using a SRAM Powerlink for a while now (with a CN7701 - DuraAce 9-speed chain)
LuckyPierre
Postby LuckyPierre » Sun Apr 22, 2007 3:14 pm
When it comes to chain lube, I use ProLink Gold and it doesn't get gungy - but you do need to re-lube if it gets wet (only had to do it twice because of that, though).
LuckyPierre
Postby Mulger bill » Sun Apr 22, 2007 3:15 pm
Thanks Pierre :D
Deni's gonna be getting a good scrubbing this week :wink:
Postby LuckyPierre » Sun Apr 22, 2007 3:20 pm
Remember, we rabbited on about cleaners on another thread - I'd use a bike cleaner rather than anything else. I think that RockandRoll make some, or you can get the BlueBike stuff I use from Torpedo7.
LuckyPierre
Postby Mulger bill » Sun Apr 22, 2007 3:27 pm
Yeah that's right. :)
I'm from the school of whip the chain off, soak and scrub. I don't want to fiddle with Shimanos pins so I'll go the link. I'm very impressed with
Rock N Rolls blue Extreme lube, it's giving me a good run between cleans on Princess. I'd like to know exactly what solvent is in it, I'd use it as a stand alone drivetrain cleaner too.
Shaun
Postby leojvs » Mon Apr 23, 2007 6:50 pm
I use the ol' triflow, with teflon. Great in the rain, but yeah, dirt sticks. To clean, I use a stiff tooth brush and some degreaser. scrub scrub. then apply a little more triflow. Works well for me.
oohhhh shiny new bike parts : -)
leojvs
Users browsing this forum: Kraeg
