heart rate
heart rate
Postby ShanDog » Thu Apr 26, 2007 7:40 am
I've seen a few times in different posts about how people try to remain at certain heart rates and something about how this helps you do certain things, such as burning fat. I'm just interested to know the science behind this. why does you body do things such as burn fat better at certain heart rates and not others? wouldn't it be different for every person, considering all the different body sizes and shapes?
Shannon
ShanDog
by Forum Ads » Thu Apr 26, 2007 8:00 am
Postby sogood » Thu Apr 26, 2007 8:00 am
It's all to do with the energy management of the body and how different energy systems release their energy store at different rates. So it's pointless to activate an energy system that can only release slowly when you are on max power (where very rapid energy use is required) for instance.
Start with Polar's spill, the most well known HRM equipment maker. Check out their "fitness" tab on the left.
<http://www.polarusa.com/consumer/weightmgt/hrm.asp>
Then you can find all you need to know via Google.
sogood
Postby ShanDog » Thu Apr 26, 2007 8:11 am
that explained it perfectly. Thanks sogood.
ShanDog
Postby mikesbytes » Thu Apr 26, 2007 10:23 am
http://www.polarusa.com/consumer/fitness/hrm.asp wrote:*Her estimated max heart rate is 220-(age) 45=175
I like they way there's an * at the front, but no related foot note.
_________________________________________________________________________________
Burn plenty of Glycogen
Frame Size Calculator.....Park Tools Repair Guides Frame Size Calculator.....Rolling Resistance.....Rolling Performance.....Sheldon Brown's Bicycle Technical Info
training log.....Body-Mass Index, Waist-to-Height Ratio, Basal Metaboic Rate
Bicycle FAQs.....Bicycle Safety.....Cadence in Cycling.....Types of Bicycles
mikesbytes
Users browsing this forum: norbs
cron
