mikesbytes wrote:13th flat this year, in RNP just past flat rock.
Wow! Cheaper tyres just don't suit your weight and power. Time to dump those 25s for your Pro2Race.
Park Tool pre-glued patches
• Page 2 of 2 • 1, 2
year time to put some new rubber on the OCR. I'm not blaming the tyres though. _________________________________________________________________________________ Burn plenty of Glycogen Frame Size Calculator.....Park Tools Repair Guides Frame Size Calculator.....Rolling Resistance.....Rolling Performance.....Sheldon Brown's Bicycle Technical Info training log.....Body-Mass Index, Waist-to-Height Ratio, Basal Metaboic Rate Bicycle FAQs.....Bicycle Safety.....Cadence in Cycling.....Types of Bicycles I've got stuff on ebay
I've got 2 pro race 2's sitting in the cupboard, 1 conti ultraspeed 1 50% worn rubino pro.
I might shift the existing front pro race 2 to the rear to wear it out and put a new pro race 2 on the front. The Dynamites are good tyres, but I'll deplete my existing stocks. Need some new tyres for the track bike. _________________________________________________________________________________ Burn plenty of Glycogen Frame Size Calculator.....Park Tools Repair Guides Frame Size Calculator.....Rolling Resistance.....Rolling Performance.....Sheldon Brown's Bicycle Technical Info training log.....Body-Mass Index, Waist-to-Height Ratio, Basal Metaboic Rate Bicycle FAQs.....Bicycle Safety.....Cadence in Cycling.....Types of Bicycles I've got stuff on ebay
Retired my first ever bicycle tyre today. Approx 4500+km on a Conti GP4000 used at the rear. There's still some life left according to the wear indicator on the tyre but there's a big piece of rubber missing which exposed the Vectran belt deep within.
Re: Park Tool pre-glued patches
I tried them on the mountain bike and founf they worked fine, sanding and having a dry clean surface is the way to go. On the Road bike I find they tend to leak/lif t off once you go above about 70 PSI, have gone back to patches with glue.
Interesting number and certainly makes sense. Unfortunately at 70psi for a road tyre, it'll be asking for pinch flats. Bianchi, Ridley, Montague, GT, Garmin and All things Apple
During our ride the other day, managed to catch some glass, so when we had a quick stop on top of the hill, thouroughly checke dthe tyres for anything embedded. I was shocked at how many cuts were in the rear tyre, and managed to dig one piece out taht wouuld have gotten me a flat in quick time. So, my advice is, even if you didn't ride over anything noticeable, check the tyres regularly and try and prevent any flats. BTW, I know it is off topic, but Torpedo7 have Vittoria Rubino Pro's for $19.99 each !!! Bugger I don't have a credit card .....
Well it's been a week and have had the tyres at around 100psi. Patch is holding fine.
The guy from the bike store says they're the best he's used, provided you clean and sand the area, and brush off any remaining sand from the area.
Check and wipe down the tyres after every ride should be the standard operating procedure. It doesn't take much time at all if you turn it into a routine. Bianchi, Ridley, Montague, GT, Garmin and All things Apple
Tiny rubber tube I assume? Many, many years ago, there was a type of valve that had the rubber tube over the valve body to act as the valve. I haven't seen one of these valves in about 20 years... but all the repair kits used to have a spare 'valve'.
Was it a tube? Some modern kits provide a piece of rubber that is a solid cylinder - it's used for plugging holes in the TYRE, not to keep the air in, but to keep the tube in. I've heard people rave about how important this is, never seen the point meself.
Kits often include a small hollow rubber tube. This is to replace the rubber on a dunlop valve. Haven't seen a dunlop valve in years.
They went out with the dinosaurs ... yes, I used them as a kid. Got a bike in the back shed that still has them fitted Richard
Great, thats where we can send them so they don't get wasted and clog up the landfill and drains. What's the address Richard ??
Who is onlineUsers browsing this forum: coffeeandwine, Majestic-12 [Bot], QuangVuong, rabobank89 |
