How much power are you generating?
• Page 1 of 1
Very interesting, making a guess from using the thing, I must be able to put out around 200-250 watts of energy. Not bad
Donald BCC give us some more bikeways fore safe travel!!!!
Upgrade the NCL now QR!!!!!! http://nakedcyclistbrissy.blogspot.com/ My views do not represent any organisation I may be apart of unless otherwise stated
Interesting time waster here at work....
It confirms my observations from my weekend ride. On the flat and downhill, the recumbent is significently faster. Of the bike configurations offered, only the 'Superman position one hour speed record' bike is faster. Going up hill, however, the difference is only 1-2 kph. From this, I can only conclude that the speed with which bikes were passing me going uphill was purely due their hugely greater power output! Now that's a sobering thought.
Yes. But you wouldn't get all that much power. I mean, if you rode the bike for an hour pretty hard, you might get enough to run a light bulb for an hour, or two CFs. I often wonder when I go to the gym, you have self-powered exercise bikes and then you have treadmills plugged into the wall. Now, how come they don't just plug the bikes into the treadmills so you can have the rider take on the runner!
Slightly of the topic...
A friend of mine decided to throw a yoga ball at the back of another mate who was running on the treadmill. The ball bounced of his back, of a wall then hit the back of the tread mill sucking it under lifting up the treadmill. Needless to say the guy on the treadmill had some tread marks on his arse.
Yes... but as you go through each transformation, you lose power. Electric alternators are around 90% efficient, then you have an inverter at around 90-95% efficiency. So call it a 20% power loss. Assume you can pedal for 12 hours (AT) 100W, that's only ~ 1Kw/h (worth about 10c-12c). The 'average' Australian house supposedly uses ~ 21Kw/h a day. (Edit : Fixed a Typo) Last edited by MJF on Thu May 17, 2007 3:16 pm, edited 1 time in total.
Nah, because you don't physically push your foot backwards when you walk/run, rather you shift your balance forward and put your other foot in front to stop the fall. The treadmill moves the ground to simulate this movement - of course, it's not as effective because the treadmill is doing some of the work.
Interesting. To maintain 17.9kph on a 10% hill, I have to produce 500w. So if I know the slope of the hill and record the time to get up, with a bit of playing, I can calculate the wattage.
_________________________________________________________________________________ Burn plenty of Glycogen Frame Size Calculator.....Park Tools Repair Guides Frame Size Calculator.....Rolling Resistance.....Rolling Performance.....Sheldon Brown's Bicycle Technical Info training log.....Body-Mass Index, Waist-to-Height Ratio, Basal Metaboic Rate Bicycle FAQs.....Bicycle Safety.....Cadence in Cycling.....Types of Bicycles I've got stuff on ebay
Here is a link to another power formula from the Cycle2max website
Cycle2max Power Formula Gives you the data on why and how
In the US you can get a TV that only works when you are cycling on a power generating stationary bike. _________________________________________________________________________________ Burn plenty of Glycogen Frame Size Calculator.....Park Tools Repair Guides Frame Size Calculator.....Rolling Resistance.....Rolling Performance.....Sheldon Brown's Bicycle Technical Info training log.....Body-Mass Index, Waist-to-Height Ratio, Basal Metaboic Rate Bicycle FAQs.....Bicycle Safety.....Cadence in Cycling.....Types of Bicycles I've got stuff on ebay
yeah, you would generate a lot more power if you were just feeding the resistance of the dynamos/generators, rather than also trying to propel a mode of transport, you could also ease up on the gears or adjust the gears for optimum spin.
• Page 1 of 1
Who is onlineUsers browsing this forum: gretaboy, Majestic-12 [Bot], Shred931, warthog1 |
