Max
TailightsRe: Tailights+1 to what Il Padrone said.
Max One of the best things about bicycle commuting is that it can mitigate the displeasure of having to go to work. - BikeSnobNYC
Re: TailightsI find it a hassle that most tail lights are for fitting to the seat post which is a nuisance with a rack pack or larger saddle bag. Some have a little clip thingy that hooks onto a loop on the bag, but they tend to be smaller lights. I haven't found one yet where I can screw the mount to the back of the rack but be able to easily remove the light when it isn't needed. Same for front lights with a handle bar bag.
Re: Tailights
Hi I have two Superflash (or similar) lights mounted to the rear of my Tubus rack on my Surly Long Haul Trucker. Regards Andrew
Re: Tailights
I'm running one of these at the moment. I've had it for about a month, no complaints so far. Bright, two flashing options and durable. I was using Niterider Cherry Bombs, but went through two of them as the clips broke and the lights just fell off. Edited to correct spelling. Last edited by Fletcher on Mon Apr 19, 2010 1:42 pm, edited 1 time in total.
Re: Tailights
Cateye sell a rear rack mount to use with their lights http://www.wiggle.co.uk/p/cycle/7/Catey ... 360032017/ Fletcher: Where did you pick up the Tioga light? Might suit my bike so wouldn't mind having a look at one if a Cbr LBS has them. Cheers Current Ride: Giant 2010 TCR Advanced 1
Re: Tailights
Sure Haks. MalAdjusted in Dickson stocks them. Cheers ![]()
Re: TailightsAndrew,
Something like that is what I would like but hadn't seen it lights I have looked at. I will chase up that model. thanks
Re: TailightsBlackburn Mars 4.0
An excellent bright 1W tail-light that comes with a seat-post mount and a rear rack/reflector bracket mount ![]() Riding bikes in traffic - what seems dangerous is usually safe; what seems safe is often more dangerous.
Re: TailightsRadbot 1000
![]() All of the above [rack, seatpost and seatstay mounts] , plus it's cheaper;) I've got the Radbot 1000 and love it - it's rather bright Specialized S-Works Roubaix (With electronic Ultegra, oooo the boogey man)
Re: Tailights
I was riding behind a guy on the weekend (during the day) that had one of these lights and they are quite bright, brighter than PB SF. Another guy had a Dinotte and it was superbright, might be a bit too much at night, definitely too much for groups I would say.
Re: Tailightswhere are folks buying there Superflashes from?
I see the 1watt headlight and .5 watt superflash combo is around $90 online. eg. at bikelights.com.au Litespeed Tuscany with SRAM Force and Open Pros - soon!
Re: Tailights
Go to ebay you will get them shipped from the USA for half that price.
Re: Tailights5 LED Catyeye style knockoff at Goldcross for 12 bones. Does the job really well.
Do or do not. There is no try
Re: Tailightsjust bought this - http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0425817156
fingers crossed it arrives before it gets much darker! Litespeed Tuscany with SRAM Force and Open Pros - soon!
Re: TailightsEverywhere I have googled for the superflashes, I can't seem to spot a rack mount.
Andrew: where are yours from? thanks
Re: TailightsNow that night riding is becoming increasingly the solution as winter draws near, the Dinotte light is being investigated.
I have used a Superflash for some years now and have been happy, and in winter, typically attach another flasher (a Cherrybomb) to one of my booties for extra visibility. Then, not only does it flash, but moves up and down as well !!!! I have purchased my Superflash from Wiggle in the past. Not real waterproof though.
Re: TailightsI've gone through a torrent of rain with the superflash. Still works fine though admittedly I didn't have it out too long. I promptly detached it and put it in my pocket. But would glad wrapping the unit make it sufficiently rain proof?
Re: Tailights
My rack mount for the superflash came with the racks.
Re: Tailights
I have used mine for a couple of winters without dramas. Andrew
Re: Tailights
Do you happen to know if it is possible to mount this on a rear mudguard? It might be the sort of thing I'm looking to use on one of my Raleigh's. Martin Christopher Hartley
http://raleightwenty.webs.com - the top web resource for the Raleigh Twenty http://madmartysblog.blogspot.com - my cycling adventures
Re: Tailights
Mine has worked pretty fine in the wet. I've applied a grease smear around the edges, and that seems to have worked pretty well.
Re: Tailights
Agree with that. I have a few Superflashes, both genuine PB SF and the Basto equivalent and find that pretty much any spray off the road makes them work erratically, doesn't have to be a downpour, a light shower will do it. They dry out and are OK afterwards but it would be better if they didn't malfunction in the first place.
Re: Tailights
Can't realy answer that but if it helps any, its got exactly the same clip on the back as a PB superflash and it only comes with barckets for seatpost and seatstays. Les
06' Giant TCR C1 08' Colnago CLX 07' Apollo Swift VW Jetta Diesel 5.5l/100km
Re: Tailights
+1 My Macgyver solution was to put sticky tape over the seals. It works and doesn't cost a fortune Max One of the best things about bicycle commuting is that it can mitigate the displeasure of having to go to work. - BikeSnobNYC
Re: TailightsI prefer to mount on the seat-stays, as I have no fenders so anything in the midline (ie seatpost) gets all the water and dirt from the road thrown onto it reducing visibility when it's wet.
Who is onlineUsers browsing this forum: hannos, KonaCommuter, sblack, Tbird |
