Après Vélo 2011 Black Cat Awards (Flat Tyres)Re: Competition - Black Cat Awards (flat tyres) 2011+2 = 16 Havnt had an entry for a while but got 2 last week. First was a rock going throught the face of some worn out Crossmarks resulting in a 1.5cm tear in the tire and the second was a tear in the side wall of Maxix Larson Orriflmme. So 2 tyres stuffed in one week-bugger
Re: Competition - Black Cat Awards (flat tyres) 2011seems to have been a while but tempted fate tonight by going out without any pump, tubes etc. Sure enough a flat on the MTB - coincides with the start of another wet season. Started the long walk home but fortunately got rescued after a short while. So back to the best puncture protection I know - being prepared
Years total now 12
Why on earth!? Lol... lesson learned I suppose
Re: Competition - Black Cat Awards (flat tyres) 2011+1, 27, Rear. Hit something in an intersection while concentrating on traffic, fairly fast deflation and whatever caused the cut hit my ankle on the way out. Thankfully, no injury to the ankle.
This was the first cut all the way through the Panaracer Duro, all the other punctures have been wire or glass slivers. The cut was about 4mm long and required a patch on the inside, but the tyre doesn't show any deformation when inflated. These Panaracers are tough tyres! I ride, therefore I am.
Re: Competition - Black Cat Awards (flat tyres) 2011Wow, I haven't been here for a while, but the Puncture Fairy has been my friend.
2 flats on Friday on the way home - 1 front, 1 rear. I had a quick look at my own tally, and realised I've missed few in here, so Twizzle, my new total is 17 (AT) 545km. GT MTB - 11 rear flats, 0 front flats. Gitane Roadie - 3 rear flats, 2 front flat. Kuota Roadia - 1 rear flat, 0 front flats. Kev.
Re: Competition - Black Cat Awards (flat tyres) 2011+1 = 13
Went to ride the fixie down to the gym and the rear was flat, so I rode the Focus. When I pulled the tube out, it appeared to be a failed patch, but after putting the tube under water, I discovered the hole was bang in the middle of the patch. I laid the tube back over the wheel and discovered a fine hole in the tyre liner. So some thin object and gone thru the tyre, then thru 2 layers of tyre liner (it was where the ends overlap) and then smack thru the middle of the patch I've got stuff on ebay
Après Vélo 2011 Black Cat Awards (Flat Tyres)The Australian After Cycle Wear brand, Aprés Vélo is kindly sponsoring this thread as a prize sponsor.
This means this comp is serious and the most unfortunate member will come out a winner at the end of the year. The winner with the highest tally (and honesty is the key) will take home an Après Vélo prize pack to the value of $X The winner will take home the mens Behind Bars or womens Love Handles prize pack valued at ca. $100 ![]() ![]() ![]() About Après Vélo The coolest range of After Cycle wear on the planet Land of the Devoted and Home of the Insane Join our Cog-regation Online: www.apresvelo.com Total prize value: $100 incl. GST End Date: 31.12.2011 Prize Sponsor: Après Vélo Terms and Conditions apply BNA Feature: E-Bike Buyers Guide App on Now iTunes
Re: Après Vélo 2011 Black Cat Awards (Flat Tyres)Hmmm.... this might change a few things.
O.K. - from now on people need DETAILED stories, not just "I had three on the weekend". Pictures of your dead/patched tube collection would be an advantage. People who aren't "known" to this comp should expect to be treated with suspicion. I ride, therefore I am.
Re: Après Vélo 2011 Black Cat Awards (Flat Tyres)I got some Schwalbe Ultremo R1 and if I had posted all the flats I would be in pole for the Apres Velo gear.
Threw the Schwalbes away and have gone back to Vittorias - be perfect for the last 2 months and expect it to continue I know........tempting the fates!! The trouble with jogging is that the ice falls out of your glass
Re: Après Vélo 2011 Black Cat Awards (Flat Tyres)If the winner is decided by sheer number of punctures, I'm nowhere near "winning" but I might get an honourable mention.
viewtopic.php?f=17&t=41556&p=698894#p698894 Nobody younger than 27 has experienced a month with temperatures lower than the 20th century global monthly average.
Re: Après Vélo 2011 Black Cat Awards (Flat Tyres)Damn you Hutchinson intensive tubeless - thanks to them I am well and truly out of the running for this prize.
2008 Specialized SWorks Roubaix SL - Zipps - Campag - Nuff Said
1986 Spokesman Model 11 Racing - Campag Nuvo Record - Stronglight - Shimano 600 ![]()
Re: Après Vélo 2011 Black Cat Awards (Flat Tyres)Yeh, props to the Vittoria Rubino Pros... 3240Km this year and not a single flat. 5073Km (same tyres) last year and I think I only had 4 flats. That's 2078Km per flat, and my tyres look brand new. Damn Rubino Pros!!!!!!
Max One of the best things about bicycle commuting is that it can mitigate the displeasure of having to go to work. - BikeSnobNYC
Re: Après Vélo 2011 Black Cat Awards (Flat Tyres)Perhaps I should remove my tyre liners
Re: Après Vélo 2011 Black Cat Awards (Flat Tyres)I know that everyone is honest here, and those who are not may suddenly find the cycling mafia against them.
Re: Après Vélo 2011 Black Cat Awards (Flat Tyres)+1 for me. On my Bianchi - mystery puncture, no visible debris on tyre inside or out, not a snake bite etc.
Of course just about to ride... Makes four for me on three bikes. PiCO
Re: Après Vélo 2011 Black Cat Awards (Flat Tyres)wanted to borrow till the end of the year ! set of worn Corsa Evo's to help me win this competition.
He he, I could send you some that I'm not using and have had little use. ![]()
Re: Après Vélo 2011 Black Cat Awards (Flat Tyres)My votes on Tizzle winning the comp, its that [glass] magnetic personality
I think it's just because the local Govt. are a bunch of tight-arses and I do 99% of my rides on on-road cycle lanes that aren't ever cleaned. Half my punctures occur on one section of road of about 4km, and at the right time of the day you can see the lane glistening from all of the glass. Big thumb up to the Panaracer Duro Tyre - total bitch on the first fitting, but stacks better than every other tyre I have tried in terms of the combination of wear rate/grip/puncture protection. I even used one on the front for a crit the other day, as I had been using the carbon front for commuting for a few days to sort out a bike setup problem and couldn't be bothered switching back to a Pro3. I ride, therefore I am.
Re: Après Vélo 2011 Black Cat Awards (Flat Tyres)G'day
Two for me from Saturday's Audax ride, the 200 km "Smelly Welly." First puncture was in the rear just as we where leaving Popanyinning (1). This was a bit frustrating as we had stopped here for lunch and it would have been handy if I had noticed before lunch as I could have fixed whilst waiting, instead of loosing time after. The second one was about ten kilometres up the road, just short of Pingelly. In the rear again. Seems I hadn't cleared the cause properly. Found the culprit this time, patched the tube and got going again. Lost 20 minutes but. The rear tyre is a Michelin Pro Race 3 which had done ~ 4,900 km. This ride has pretty much killed it off but. (1) The townsite of Popanyinning is located in the great southern agricultural region, 174 km south east of Perth and 17 km south south east of Pingelly. The townsite is located on the Great Southern Railway, a private railway built by the Western Australian Land Company and opened in 1889. Popanyinning was one of the original sidings on the rail line when it opened. In 1896 the Western Australian government purchased the rail line and land, and in 1903 decided to have a few lots surveyed at the Popanyinning siding to meet the requirements of the local settlers. After survey the townsite of Popanyinning was gazetted in 1904. Popanyinning is an Aboriginal name, first recorded by the surveyor John Forrest in 1869, for a pool in the Hotham River. Some records spell the place Popanying, or Popanyining, but these appear to just be misspellings of the original name. The meaning of Popanyinning is not known.
Max - I don't know about you, but this is one price I DO NOT want to win.
Re: Après Vélo 2011 Black Cat Awards (Flat Tyres)Thats a big +2 for me, on the same tyre no less.
Got a puncture 2kms out from home, and got to try out my newly acquired CO2 canister to reinflate the tube, after I changed it. All went well for another 7kms then the new tube managed to succumb to a puncture. I'd just about patched the tube (and tyre!) when a work colleague offered me a lift. Not a good result for what is likely to be the only bicycle commute to work this week. ![]()
Après Vélo 2011 Black Cat Awards (Flat Tyres)+0. Swapped out the rear Panaracers after I got home tonight - I had a close encounter with a truck on Friday morning, and when I pulled out the bike this morning found that a strip of rubber about 5cm long a 1cm wide had been torn off the carcass. Bare threads to the road... so I did did what any fairy hater would do, I did another 40km on it.
But tonight, after playing musical tyres (an almost new Panaracer went onto the rear), I left the rear sitting by the front door after pumping it up to 110psi, and about 20 minutes later the tyre popped off the rim and the tube exploded. Four kids, two dogs and the better half were NOT impressed. Given how damned hard these tyres are to fit, I'm still trying to work out how the bead came off the rim. I ride, therefore I am.
Re: Après Vélo 2011 Black Cat Awards (Flat Tyres)punctured again today (3 this week! i would have to be close to the lead in this if i was counting). all the guys rode straight past, but 2 lovely ladies slowed to ask if i needed help.
yep, i've still got it
Who is onlineUsers browsing this forum: Cruiserman, liamw |
