Video Camera who uses one?
Postby GraemeL » Sun Feb 06, 2011 9:02 pm
The First Part of this post has been added as a running compilation
Bicycle Cameras
There are more and more cyclists wanting to use a video camera to record their commutes, in the event of an accident, they are able to rely on the footage to prove what took place.
There is a wide variety of cameras on the market, some as cheap as $10 and others costing $400 or more. This information only covers a few of the more popular cameras.
I have provided the following information about various cameras and an external battery to help you decide which is best for you. This is a guide only and the information is from my own experiences as well as from what other users have reported. You should always do your own research before buying any camera.
Related information about cameras and mounts, can be found here:
Camera FAQ's Here >
Mounting FAQs - DIY and Third Party Mounts >
This will be updated as I receive more information about the different cameras. I hope this information is a help to you.
Cameras
MD80
(I own and use this camera)
Cost: $14 (approx)
Footage:
What’s Included:
1 X Mini DV Camera, 1 X Silicone cover, 1 X USB cable, 3 X Brackets, Manual
Details:
• Video Format: AVI
• Resolution: Support 30 fps for 720x480 and 320x240 IT IS NOT HD
• Lens: 80 degree (approx)
• Photo: NO
• Memory: Micro SD (up to 16gig)
• Battery Time: Approx 1hr
• Water Proof/Resistant: NO
• Number Plate readability: Yes as long as the car is directly behind or in front and close.
• Size: 55mm (L) x 20mm (W) x 20mm (H)
• Weight: 36g
Purchase from:
• Ebay Seller novelemart
• http://www.ebay.com.au/itm/ws/eBayISAPI ... OC:AU:1123
• Search Name: Mini DV Sports Video Camera Spy Cam MD80
This camera is very small and lightweight. It only has a recording time of 1 hour and is AVI, so it is not HD. If you are looking for a cheap alternative then this is as cheap as they get. If you are looking for a HD camera then keep reading.
Jumbo HD 808
Cost: $48 (approx)
Footage:
What’s Included:
1 x HD Car key camera, 1 x Car Charger, 1 x Car charger Cable Thin 2 meters long, 1 x USB cable, thicker and 1 meter long, 2 x Stick on Velcro Squares, 1 x User Manual
Details:
• Video Format: MOV H.264 compression
• Resolution: 720P High Definition Video 1280 x 720 H.264/AVC1 30fps .
• Photo: 5.0 Mega pixels Photo JPEG format: 2592 x1944.jpg
• Lens: 90 degree (approx)
• Memory: Micro SD (up to 32gig)
• Battery Time: Approx 1.5 hrs
• External Battery Pack: (Optional) YES Extra 2.5hrs
• Number Plate readability: Yes very good
• Size: 65mm (L) x 34mm (W) x 18mm (H)
• Weight: 64g
Purchase from:
• Ebay Seller eletoponline365, extremely good service and fast shipping
• Search Name: #11 Full 808HD Cam Car Key Camera DVR Driving Recorder
This is the best value camera at the moment. Used with the External Battery Pack, you will get approx 4hrs recording time, provided you use a large capacity memory card.
Extreme Cam (Crocolis HD Extreme Cam)
(Reviews)
Cost: $185 (approx)
Footage:
Coming Soon
What’s Included:
Camera, Battery, Helmet Grip, Velcro and 2 x 3 M Pad Handle Bar Grip, Base Bracket, AV Cable, USB Cable, Power Adapter, Short/Long Velcro Strap, HDMI Cable, Microphone, Suction Cup Bracket, Car Charger, User Manual-English
Details:
• Video Format: Mov H.264 compression
• Resolution: FULL HD 1080P = (1920*1080) 30FPS/25FPS 720P = (1280*720) 60FPS/30FPS/25FPS WVGA = (320*240) 30FPS/120FPS
• Still Image Resolution: 2048x1536, 2592x1944, 3200x2400, 4000x3000, 4608x3456
• Timelapse: Yes, 3, 5, 10, 30 and 60 seconds
• Lens: 142 degree(1080P), 172 degree(720P&WVGA)
• Digital zoom: 4x
• Sensor: 5 Mega CMOS
• Screen: 1.5 inch TFT Screen
• Memory: SDHC card (up to 32G)
• Battery Time: Approx 2.5hrs
• Water Proof/Resistant: Yes Waterproof (IP68)
• Dimensions: 115mm (L) x 58mm (W) x 50mm (D)
• Weight: ?
Purchase from:
• Ebay
• Search Name: Crocolis HD - 1080P Full HD Extreme Sports Action Camera (Waterproof)
This camera has received some very positive reviews and seems to be a very good mid priced option.
Contour Roam
(User Feedback)
Cost: $299 (approx)
Footage:
Coming Soon
What’s Included:
1 x Contour Roam Camera, 1 x Rotating Surface Mount, 1 x Profile Mount, 1 x Mount Tether, 1x USB Cable, 1 x Lens Cap
Details:
• Resolution: 1080p = 1920x1080 pixels at 30 fps or 25 fps, 960p = 1280x960 at 30 fps or 25 fps, 720p = 1280x720 at 30fps or 25 fps
• Still Image Resolution: No
• Timelapse: No
• Lens: 170º Rotates 270°, from -90° to 180° allowing inverted mounting
• Sensor: 5 Megapixel
• Screen: No, Settings need to be changed via PC
• Memory: Micro SD card (up to 32G)
• Battery Time: Approx 3.5hrs
• Water Proof/Resistant: Yes Waterproof 1 metre for 30mins
• Dimensions: 100mm (H) x 55mm (W) x 34mm (D)
• Weight: 145g
This is an excellent camera if you can afford it. There are also other mounts available
Purchase from:
• Plenty of Australian retailers or online
• Search Name: Contour Roam
GoPro HD Helmet Hero 1
Cost: $309 (approx)
Footage:
What’s Included:
1 HD HERO Camera (5 megapixel), 1 Rechargeable 1100 mAh Lithium-Ion Battery 1 Waterproof Quick-Release Housing (197’/60 m), 1 Headlamp-Style Head Strap ,1 Vented Helmet Strap, 2 Curved, 3M™ Adhesive Mounts, 2 Flat, 3M Adhesive Mounts, 1 Three-Way Pivoting Side Arm Assembly, 2 Quick-Release Buckles, 1 USB Cable, 1 Component Video (HDTV) Cable 1 Composite Video + Audio Out Cable
Details:
• Resolution: 1080p = 1920×1080 pixels, 30 fps, 960p = 1280×960, 30 fps, 720p = 1280×720, 60 fps, 720p = 1280×720, 30 fps
• Timelapse: Yes 1, 2, 5, 10, 30 or 60 secs
• Lens: 127º wide angle in 1080p mode, 170º ultra wide angle in WVGA, 720p, or 960p mode
• Sensor: 1/2.5″ HD CMOS, 2.2µm-sized pixels
• Screen: LED 16mm x 15mm Change settings only
• Water Proof/Resistant: Yes Waterproof 60 metres (waterproof housing)
• Dimensions: 42mm (H) x 60mm (W) x 30mm (D)
• Weight: 167g (includes battery and case)
This is an excellent camera if you can afford it. The housing is just about bomb proof and will take some bangs and knocks. There are a host of mounts for it, which are also very good. There are also other accessories, such as Battery Bacpac, this increases recording times to approx 5 hrs, there is also a LCD BacPac which is a detachable LCD screen for on camera playback and preview.
Purchase from:
• Search Name: GoPro HD Helmet Hero 1
Contour GPS
(User Feedback)
Cost: $379 (approx)
Footage:
http://vimeo.com/30007777
What’s Included:
1 x Contour GPS, 1 x Rechargeable Battery, 1 x Goggle Strap Mount, 2 x Rotating Adhesive-Backed Helmet Mounts, 1 x USB Cable and 1 x 2GB MicroSD Card and a leash to keep your camera safe.
Details:
• Resolution: 1080p = 1920 x 1080 at 30 fps, 960p = 1280×960 at 30 fps, 720p = 1280×720 at 60 fps, 720p = 1280×720 at 30 fps,
• Still Image Resolution: 2592 x 1944
• Timelapse: Yes 2592 x 1944 pixels at 3, 5, 10, 30, 60 second intervals
• Lens: 1350 wide angle (720 and 960 modes), 1100 wide angle (1080),Sensor: 5 Megapixel
• GPS: NMEA Format, embedded in the Video file, Stills: GPS data stored in a log file
• Bluetooth: Bluetooth v2.1 EDR (Enhanced Data Rate)
• Water Proof/Resistant: Yes Water resistant ("splashproof"), not submersible
• Dimensions: 95mm (H) x 58mm (W) x 35mm (D)
• Weight: 150g (including battery)
Purchase from:
• Search Name: Contour GPS
External battery Pack
(I own and use this)
Cost: $17 (approx)
What’s Included:
Various connectors for connecting to different things, such as phones, Ipod, Bluetooth and GPS
Details:
• Battery Type : Lithium-iom Cell
• Input Voltage: DC about 5V
• Input Currant: 500mA
• Capacity: 7.8Wh
• Charge Time: 4.5 hours
• Charging Mode: USB or AC adaptor
• Dimensions: 80mm (L) x 45mm (W) x 13mm(D)
• Weight: 55g
This is used with the Jumbo 808 camera, it allows for another 2.5 hrs recording time. It even has two LED lights, these are quite bright and could be used as a torch in an emergency.
Purchase from:
• Ebay Seller: eletoponline365, extremely good service and fast shipping
• http://www.ebay.com.au/itm/ws/eBayISAPI ... OU:AU:1123
Search Name: External Power Pack UPS Charger for #11 HD 808 Car Key Camera
If anyone has footage that I can use, for the Roam and Extreme Cam please PM me.
If you see something that is not correct please let me know, I'm only human and do make mistakes.
The Second Original Part of this Post
I thought I might start a thread about video cameras. Who uses them, what type, specs, quality etc.
Others that are thinking of buying a camera will have a place to start their research.
Hopefully others that own a camera will jump in and add to this thread.
I use a GoPro HD Helmet Hero...
Video:
Resolution : NTSC: 1920 x 1080 (30fps), 1280 x 960 (30fps), 1280 x 720 (30 or 60 fps), 848 x 480 (60 fps)
PAL : 1920 x 1080 (25fps), 1280 x 960 (25fps), 1280 x 720 (25 or 50 fps), 848 x 480 (50 fps)
Lens Angle : 127 degree (1080p mode), 170 degree (960p and 720p modes), CMOS sensor
Waterproof : 60 metres
Storage : SD Card, Max size 32GB (4.5 hours at highest resolution)
Power : Rechargeable 1100mAh Lithium-Ion battery, approx 2.5 hours recording
Photo :
Resolution : 5 megapixel
Capture Modes : Single shot, photo every 2, 5, 10, 30 or 60 secs.; 3 photo burst; self-timer
The Good :
The image quality IMHO is top notch, it comes with a range of mounts for easy mounting http://gopro.com/cameras/hd-
helmet-hero-camera/
It's 100% Waterproof up to 60 metres (180ft).
It is quite small and very light, but it is very well made.
This camera sits inside a plastic housing, now this housing is just about bomb proof :) it will take a beating. If for any reason you scratch the lens of the housing, you just buy a lens kit for $34 and comes with two replacement lenses and seals and fit it to your housing, no need to buy a whole new housing.
The Not So Good :
The audio is not the best though, but then again if you want 100% waterproofing you can't expect it to be.
You are given two backs for the camera housing, one is to make is 100% waterproof and the other has a small section cut out of it to allow for better audio. Even with the non waterproof back the audio is still muffled. The backs simply clip on and off the main housing.
I am sure if you made some small modifications to the housing, like drilling a small hole near the mic and this problem would be fixed. But it is no longer waterproof. and you could add a small amount of fluffy stuff to the hole, to cut down wind noise.
Shooting at night isn't that flash. But if there is light then it does a pretty good job. I will try to include some night footage later on.
Uses :
I have it mounted to the h/bars most of the time, although I do have it mounted to my helmet and on the rear of the bike
sometimes. I find that when it's mounted to my helmet, the video is a bit better. The body absorbs the shocks, But I have to learn to keep my head still :roll: and not being fixed you tend to get a lot more in.
I also use this camera in the car, when ever we go anywhere. I have put a 3M quick release on the underside of the rear view mirror and attach the camera to that, that way it is out of the sun most of the time. I also use it in the work ute, I have the camera mounted on the back window of the ute, this way the speedo can be seen as well as me. If for any reason I need proof it's on video. There might also come a day when I catch something on camera and can help someone out with the evidence.
It's 100% waterproof, so you can take it diving, swimming, surfing or any other water sport.
Other Functions :
You can use this camera just like an ordinary camera to take pictures or you can use the self timer to take pictures and even do time lapse with it as well.
Here is some footage, it is shot at 720 x 50fps
Mounted at the rear.
This is mounted on the H/bars.
Helmet Mount and Rear Mount Facing Forwads
Graeme
GraemeL
by Forum Ads » Mon Feb 07, 2011 6:33 am
Postby Nate » Mon Feb 07, 2011 6:33 am
There's a bucket load of camera threads about ;)
I also put together somewhat of a definitive guide on them here: http://www.rigidmount.com/camera_guide.html
Nate
Postby GraemeL » Mon Feb 07, 2011 7:37 am
Nate wrote:There's a bucket load of camera threads about ;)
I thought it might be good to have all the info in one place. People could see the different videos etc with out having to hunt all over the place.
Congrats on the guide, it is very well done :)
Graeme
GraemeL
Postby Christine Tham » Mon Feb 07, 2011 7:49 am
Hi GraemeL,
You have done a very nice review of the GoProHD, thank you very much!
However, as Nate said, there has already been plenty of threads of people comparing various models, mounting options etc. For example, this one?
http://www.bicycles.net.au/forums/viewtopic.php?f=12&t=36332
Rather than asking people to pull together towards your new thread, maybe it's better that you contributed to one of the existing threads, such as the one above?
Alternatively, you can make your thread specific to the GoProHD? I would suggest renaming the thread title to "My review/experiences of the GoProHD" and invite other owners to offer their feedback.
Weekdays: "Bliss" (Trek Madone 5.2 2012) | Weekends: "Cadel" (self built) | Casual: "Kitty" (Giant Cypress LDS 2009)
Christine Tham
Postby Nate » Mon Feb 07, 2011 7:52 am
The issue with putting videos together is that the conditions vary - so results arent that realistic.
especially with bike mounted cameras - as road surface is EVERYTHING
If you want to send everything to me i'll do a review :)
Nate
Postby norbs » Mon Feb 07, 2011 9:23 am
I am interested in how you managed to get the GPS data on there. That is very cool.
norbs
Postby zero » Mon Feb 07, 2011 10:53 am
norbs wrote:I am interested in how you managed to get the GPS data on there. That is very cool.
Most camera's have optional overlays for time - if the camera has GPS it will have an optional overlay for it. Mine has an overlay for its accelerometer, but I've never bothered to figure out how to turn it on - more useful from a car where acceleration can be considerable most of the time, and cornering forces aren't up/down through the chassis like a leaned over bike.
zero
Postby Aushiker » Mon Feb 07, 2011 2:31 pm
Hi
Reasonably happy owner of a Contour HD1080P here. Now looking for a second camera to face rearward.
Postby Baalzamon » Mon Feb 07, 2011 3:11 pm
Aushiker wrote:Hi
Let me know what route you go down, I'm thinking of a cheapie from ebay one of the $10 ones. But then need to consider how to waterproof it...
Happy own of a Contour GPS camera here, glad I got that one as Bluetooth support is coming up soon :)
Baalzamon
Postby GraemeL » Mon Feb 07, 2011 6:49 pm
I use a program called DashWare http://www.dashware.net/ . You will need GPS data, that you use with the program. I have a Garmin Oregan 550 that I take with me. I just upload the gpx file into DashWare along with the video footage.
Aushiker wrote:Hi
I too am thinking of getting another for the rear, I was thinking about getting another GoPro, but I would also like to try out another camera and was looking at the Contour, the one with the GPS.
Graeme
GraemeL
Postby Nate » Mon Feb 07, 2011 8:03 pm
FYI - joining front & rear footage with split screen:
its poorly aligned but should look pretty cool if you had 2 cameras, 1 front 1 rear
Nate
Postby Aushiker » Tue Feb 08, 2011 12:22 am
Hi
This video goes on a bit but it I thought the approach to mounting the rear camera was interesting ... you can see it around the 2:55 mark.
I think a Go Pro or Contour HD1080 is probably over kill for a rear camera ... but happy to be convinced otherwise :)
Postby Oxford » Tue Feb 08, 2011 8:29 am
that's a very professional version of the mounting process I adopted.
- anonymous
Oxford
Postby Aushiker » Tue Feb 08, 2011 8:50 am
Oxford wrote:that's a very professional version of the mounting process I adopted.
Hi
With your mounting (any chance of photos?) is it easy to remove the camera for charging etc?
Postby Oxford » Tue Feb 08, 2011 11:08 am
Hi
yeah I've got to take some photos for some other queries I've had, I'll try to take some tonight of this and the other stuff and post up.
- anonymous
Oxford
Postby GraemeL » Tue Feb 08, 2011 6:05 pm
Aushiker wrote:Hi
Thanks a lot :roll:
After watching that video, I had to check out the rear light. It's a Fibre Flare, I just ordered 4 of them for our bikes.
Graeme
GraemeL
Postby Oxford » Tue Feb 08, 2011 7:41 pm
This is how I have mounted the rear camera I have on both bikes I commute on:
Seat post mount using an old mudguard clamp mount with a barend bolted to where the mudguard attached.
The helmet mounts were used on the other bike using cable ties to attach the mount to the seat stay, the front is similarly mounted to the handlebars same style.
- anonymous
Oxford
Postby Aushiker » Tue Feb 08, 2011 11:20 pm
GraemeL wrote:After watching that video, I had to check out the rear light. It's a Fibre Flare, I just ordered 4 of them for our bikes.
Hi
Gaz545 has more on lights here.
Postby Aushiker » Tue Feb 08, 2011 11:21 pm
Hi
Thanks Oxford. Giving some ideas there.
Postby Aushiker » Tue Feb 08, 2011 11:28 pm
Hi
I like the look of the GoPro HD Hero 960 with the seatpost mount as a rear camera setup. Price is RRP of US$179.99 + US$20 for the mount. Comes with a waterproof case. Anyone played with one?
Postby zero » Wed Feb 09, 2011 12:17 am
Oxford wrote:This is how I have mounted the rear camera I have on both bikes I commute on:
Those are the same mounts (different colour) supplied with the atc9k. The plastic clamp of the bar mount eventually broke - though it may have survived much longer if I only used it right way up - when I bought my roadie I tried it hanging from the right drop for a different perspective - my camera holds its weight a little distance off the mount, and thats probabably too much for it. I also found once the mounts got used, they wore a bit and needed the cam slipped in on a piece of paper to prevent the mic picking up clacking from the click in part.
Not particularly enamored with the helmet mount either - though it might work better mounted the way you have with cable ties on a helmet with more amenable vent placement than mine.
zero
Postby GraemeL » Wed Feb 09, 2011 7:48 am
Aushiker wrote:Hi
It looks to be the same as my GoPro HD, the difference being it doesn't do 720x60fps or 1080. Also it doesn't have the expansion slot, you won't be able to use the new accessories with it, like the LCD Screen or the Battery Pack (when it's released).
I think this would make a great second camera.
Graeme
GraemeL
Postby Nate » Wed Feb 09, 2011 7:57 am
Aushiker wrote:Hi
I've heard good reports - the sensor is MUCH better, so while it doesnt do 1080p, it has a much better picture, vivid colours, sharper etc.
Also nice price point & a lot more affordable
Nate
Postby Aushiker » Wed Feb 09, 2011 11:06 am
GraemeL wrote:It looks to be the same as my GoPro HD, the difference being it doesn't do 720x60fps or 1080. Also it doesn't have the expansion slot, you won't be able to use the new accessories with it, like the LCD Screen or the Battery Pack (when it's released).
Hi
I am not bothered by 720 x 60 fps or the expansion slot and as I want it for a rear camera I think features for the price make it work. Whatever I use has to be suitable for winter.
I need to wait until I have finished the commuter's set-up to see if a seat post mounted camera will be feasible but.
Postby Aushiker » Wed Feb 09, 2011 11:07 am
Nate wrote:I've heard good reports - the sensor is MUCH better, so while it doesnt do 1080p, it has a much better picture, vivid colours, sharper etc.
Hi
Sounds good then. I particular like that it comes with a waterproof housing.
Users browsing this forum: gazman, InTheWoods, Mulger bill, Red Rider, The 2nd Womble, vince
