AUbicycles wrote:Did you screw or cabletie?
I copied norbs today.
[youtube]http://www.youtube.com/watch?v=Pe0aAn6qFFA&feature=share&list=UUv_N2TLz5k6bxiSS9TpUQ_A[/youtube]
I am just waiting for his blog post to see if I can fit it to my MTB.
Video Camera who uses one?Re: Video Camera who uses one?
I copied norbs today. [youtube]http://www.youtube.com/watch?v=Pe0aAn6qFFA&feature=share&list=UUv_N2TLz5k6bxiSS9TpUQ_A[/youtube] ![]() I am just waiting for his blog post to see if I can fit it to my MTB. Giant Reign 1 Merida CX4 Trek Superfly Al Trek Earl
Re: Video Camera who uses one?I don't know much about cameras.....Can someone please explain to me why (in the sony) it has a 16 megapixel sensor but can only shoot 2mp stills?
All is revealed! New on the blog : That View from the Bottom Bracket. (HowTo) http://norbs.tk/bp
It works on the MTB, stand by for another video. Giant Reign 1 Merida CX4 Trek Superfly Al Trek Earl
Re: Video Camera who uses one?How many people have been caught out later reviewing the video rubber necking with a helmet mounted camera?
Re: Video Camera who uses one?Mugglechops, is that the Rollbar mount?
BNA Feature: E-Bike Buyers Guide App on Now iTunes
Re: Video Camera who uses one?The Sony Action Cam review is now up on BNA:
How Good is the Sony Action Cam for Capturing Video on a Bike? Note, in the photo below, I choose to mount the camera up-side-down on the handlebars which keeps it away from the top of the handlebars and out of trouble. ![]() ![]() ![]() BNA Feature: E-Bike Buyers Guide App on Now iTunes
No just the handlebar mount. It was pretty much at the end of it's adjustment. Giant Reign 1 Merida CX4 Trek Superfly Al Trek Earl
Re: Video Camera who uses one?A while back I posted about Liquid Image EGO camera, so thought I'd do a bit of an update.
Still very happy with it, and I especially like the method that is used to mount it - it threads onto a standard tripod mount (1/4" gutter bolt thread) so making your own mounts is simple. Photo below shows its permanent mounting on the commuter bike: The bracket is just an aluminium angle shaped to achieve a decent alignment of the camera. However I was really keen to get hold of a chest mount for use on the roadie and MTB, but it looks as if these are still in 'pre order' stage on the webz. I had heard that the mounting system is compatible with the GoPro stuff, so when the local JB had a special on, I went and purchased one of these to test out the theory. While remarkably similar in appearance of both the quick release clip, and the rotating clevis there are subtle differences that need to be made for the everything to be fully compatible - but they are simple tasks. Pictured above is the clip that comes with the EGO. I wanted to fit this straight into the GoPro harness, and all that needed to happen was that a 'poofteenth' had to be shaved from that centre groove - I had a fine sharp chisel in the shed that accomplished this in about two minutes. During a subsequent on bike test, I found that if riding the roadie on the drops, I could not tilt the camera back far enough to get a decent view of the road ahead, so I ended up placing the EGO swivel piece onto the GoPro clip - this required a bit of a fine sanding of the centre tab on the GoPro clevis as this was point something of a mm wider than the matting piece from the EGO - The sanding allowed installation without needing the apply force, and also allows smooth rotation. Below is the camera as mounted on the GoPro Harness: Other things I have found: The control buttons can be a bit hit and miss when riding along, the the small screen with the LCD can be difficult to see in some lighting conditions. I have missed some great CC racing action from mis-hitting the buttons, and being unable to read the display to guage the success or otherwise of starting / switching on the camera. I'm getting more used to this now, and tend to only operate the camera when stopped so I can be assured of positive engagement. This is mostly a problem with where it sits on the commuter - won't be such a big deal in the chesty. Camera tends to get warm, and will do a self preservation shut down if it gets too hot. Have not seen this yet, but with our Tropical summer, I'll be interested to see how this handles the heat and humidity. Mind you, I'm often got a healthy headwind to ride into, so this would contribute to an overall cooling affect. I seem to need to reformat the SD card from the Camera itself. Deleting files from the computer (and then emptying 'Trash') does not seem to convince the camera that it has spare capacity to record. This might also be due to a Linux system I use. I have successfully done a format of cards from the computer, but these were on small 4 GB cards. My new 16 GB cards seem to insist on being formatted by the camera itself. Anyway, its no biggie - in camera format is a simple manipulation of the control buttons. When reviewing the footage straight off the camera, I still get a surprise at the clarity of the footage. I have found a good setting in my video software to retain this for various compilations I do, but there is a bit of loss when uploading to youtube. To finish off, I suppose I should include a couple of random samples from Youtube. First Vid is 5 minutes towards the end of my commute to work in Cairns. Shows the camera performance in various lighting conditions (into sun, shade, shadow, good light etc). Also note that the way the camera is mounted, a lot of frame noise is transmitted to the camera - good for detecting brake applications etc. Second vid is chasing a departing train from its originating terminal in Cairns. https://www.youtube.com/watch?v=MDVrnoRvW28 https://www.youtube.com/watch?v=z5vBjnAL36U PS - if anyone can pass on the youtube embedding secrets in the forum, I'd be most happy!
Thanks for the update. Much appreciated. As to the embedding issue. Its seems that with the changes to YouTube the links are no longer working consistently with the forum software Andrew
I don't know if something has changed, but it always works for me if I used the "long" www.youtube.com type links. The "youtu.be" links don't work. ![]()
Yes, that is my experience on other forums I inhabit / administer. I tested and previewed those links before posting, but nothing seemed to want to work. Strangely enough, I have had success here on other posts.
Re: Video Camera who uses one?Anyone else had Go Pro issues after firmware update? I used it this morning then turned it off and it wouldn't turn on past the camera icon and wouldn't turn off either. Plus my video footage was a bit jumpy.
The under BB mount on the MTB worked well though. ![]() Giant Reign 1 Merida CX4 Trek Superfly Al Trek Earl
/Borat voice - Very nice
Re: Video Camera who uses one?Right here. I've had a few niggling issues. Sometimes when I turn it on it will freeze on the video logo screen (like you) or it would record for 10 secs then stop. The 10 second issue seems to only be old data on the memory card which is rare but the freezing icon I don't know why. I tend to notice it does it alot more with 32gb cards but then again there have been times where it just instantly works.
On the plus side the update has done wonders for the video quality on standard (not using protune). It cut down from 30 minute files to 18 minute files but the quality is worth it imo.
Are you replacing the youtu.be with www.youtube.com yourself as YouTube is longer providing the long link option which worked before. The YouTube interface has changed recently and hence some features related to sharing have changed. Andrew
You're right, it has just changed. Seems you can still get the full youtube.com url just from your browser's address bar though. ![]()
I know I am right I tried the URL yesterday and it didn't work with the partiuclary video. Seems a bit hit and miss. Andrew
Re: Video Camera who uses one?So I grabbed a filter to filter out direct sunlight hitting my gopro on my commutes. Got the lense off and wasn't aware that the glass lense had landed in my lap off my desk somehow. Stood up and there it goes to the ground with a crack on the side of it
Re: Video Camera who uses one?For the lense on the GoPro waterproof casing you can buy replacement lenses. I got myself a few as a backup.
It is literally a 3 minute job to change them out.
Re: Video Camera who uses one?Founder of GoPro now a billionaire apparently ...
Source: GearJunkie.com Andrew
Re: Video Camera who uses one?Well done to him you have to say.
How did the Canons and Sonys of the world miss this boat so badly that a little guy steps up and creates a billion dollar business from nothing?
+1 There are still so many opportunities out there for people who are willing to think outside of the box. Check out my practical cycling and cycle touring website: VELOPHILE AUSTRALIA
Simple. Different markets. Canon aren't really into the cheap video market so to say but Sony is now playing catchup and is utilising its software/techinical side to gain lost time. They tend to focus on mass consumer cameras (point and shoot cameras that a todler to grandma can use) and on high end photographic equipment. Only recently has that transitioned into consumer video production using their photographic products aswell. None is better than the other. Flatout quality wise GoPro holds nothing compared to them. Price wise gopros are in another world being a couple hundred bucks all up and not a few thousand for the lens + a few more thousand for the body. You can mount GoPros on nearly anything but cameras are very limited. GoPros are lighter than a bag of chips while cameras and lenses can weight more than some airlines allow for checked baggage. The GoPro might not be able to read a number plate 600m away but with my camera I sure can. The market for small action video cameras was very small and GoPro captured that market. Just as Fuji, Canon and Sony captured the high end professional video market. The first GoPro which was a film camera that only took photos wasn't a huge success at first but as it evolved over time it became a more powerful, more usable and way more marketable. They really only started to gain in popularity with the first of the HD Hero series (GoPro HD960). I think the GoPro Hero 3 is the 7th generation of camera that they have made.
Who is onlineUsers browsing this forum: blkmcs, Google [Bot], Google Adsense [Bot], gretaboy, Jesmol, Mitchnash, revinR1, simonn, Steve_F, Summernight |
