Video Camera who uses one?
- outnabike
Postby outnabike » Fri Nov 28, 2014 11:23 am
Thanks Chriss,I look forward to the review.AUbicycles wrote:Busy time for Fly6 who today publicly launch and announce the new brand Cycliq. Fly6 is a cycliq product so good news for forum members speculating on new product directions (Fly12! as named in this forum)
The Australian distributer, Jet Black has been named and it means that the camera's will also shortly be available in local bike shops for $275 (RRP)
It will be interesting to see the effect of the narrower field of view. It is always a bit of a jaundiced view with my rear Sony when a car is beside the bike, yet if you want the best pic it has to be set at the wider angle. Most cameras in the 720 res have to be that way to get a decent pic and that is probably a motivating factor for fly6 to close down the field of view.
So the cam will get a better picture but less sideways field of view.
I hope the future front cam will retain a 120 field though....
- Aushiker
Postby Aushiker » Fri Nov 28, 2014 1:29 pm
Aushiker.com
- cancan64
Postby cancan64 » Thu Dec 04, 2014 1:36 pm
The garmin 1000 bounced well but Sony camera case didn't.
I have sent them a message but I guess the weight of the garmin plus the camera being further out front had caused extra stress to the arm. .. Although you would have thought this would have been well tested.
- Nate
Postby Nate » Thu Dec 04, 2014 6:19 pm
If anything i'd call poor engineering on the mount manufacturer, having a load waaay out from the attachment point isnt good.
I'd swap over - something like:
going hard for years under brutal conditions over ere...
Postby Rex » Fri Dec 05, 2014 11:29 am
Postby jasonc » Fri Dec 05, 2014 11:35 am
+1Rex wrote:Wowee, very interested in K-Edge's response to this!
I was looking at getting a k-edge 560
plus one of these:
http://www.amazon.com/Rec-mounts-Conver ... ight+mount" onclick="window.open(this.href);return false;
- AUbicycles
- Site Admin
Postby AUbicycles » Fri Dec 05, 2014 12:22 pm
Keep in mind that with the plastic will introduce more movement - so if used for a camera, not optimal. For a light or computer it is an option.jasonc wrote: I was looking at getting a k-edge 560
plus one of these:
Regarding K-Edge, the bolts arn't very nice. Far too soft and I can't even undo a linkage bolt.
I usually run just this - K-Edge Go Big Pro with universal mount (for Sony action cam)
But for my MTB set up this, the Go Big and the Go Big Universal mount adapter. The bolt linking is so soft, even with proper Allen Keys the bolt has failed miserably, and is now miserably stuck. This has been a long term criticism of K-edge, they use substandard bolts that are subject to wear.
Postby jasonc » Fri Dec 05, 2014 12:49 pm
- cancan64
Postby cancan64 » Fri Dec 05, 2014 1:12 pm
- RonK
Postby RonK » Fri Dec 05, 2014 1:13 pm
Postby jasonc » Fri Dec 05, 2014 1:47 pm
- Nate
Postby Nate » Fri Dec 05, 2014 2:08 pm
save your time & cameras.. only mount above the bars!
- AUbicycles
- Site Admin
Postby AUbicycles » Fri Dec 05, 2014 2:46 pm
Yes, was refering to your Amazon plastic thingy.jasonc wrote:but cancan's is straight out metal failure. the bolt looks fine to me
Yes and no.save your time & cameras.. only mount above the bars!
Yes to reduce the forces / stresses which may lead to a failure, a top mount is a better solution. It compresses rather than 'tears apart'.
No because a top mount takes room above the bars which I personally don't like as I want a more compact less prominent position, plus for MTB learnt the lesson [see video] that you want to mount it out of the way to avoid trashing your camera and mount.
52738149
The Go Big style mounts without the arm are better in that there is less leverage effect, however I prefer the extended are for the Go Big Pro versions because the camera extends forward, past the cables and clears space directly below the bars (more hand room, and in some cases, you can knock you knees against anything mounted below).
- Summernight
Postby Summernight » Fri Dec 05, 2014 6:08 pm
Darn it! I'll have to put a safety lanyard back on the camera now!cancan64 wrote:The new K-Edge Mount didn't last long. .. It decided to part company with the bike.
- trailgumby
Postby trailgumby » Fri Dec 12, 2014 2:40 pm
Unfortunately using MovieMaker crashes with larger files.
- Boognoss
Postby Boognoss » Fri Dec 12, 2014 5:57 pm
- trailgumby
Postby trailgumby » Fri Dec 12, 2014 7:27 pm
- Boognoss
Postby Boognoss » Fri Dec 12, 2014 9:26 pm
Yes 64bit indeed.trailgumby wrote:I assume your installation of Win7 is 64bit Boogs?
Postby defy1 » Sat Dec 13, 2014 7:37 am
nm found oneNate wrote:I'm always ASTOUNDED at how much stresses are induced in mounts over long periods of bump bump bump.
- outnabike
Postby outnabike » Sat Dec 13, 2014 9:51 am
Hi trailgumby this is what fly6 likes.trailgumby wrote:Any recommendations for decent (preferably free!) video editing software that works on a 64-bit Wintel 8.1 platform?
https://cycliq.freshdesk.com/support/so ... deo-editor" onclick="window.open(this.href);return false;
http://www.nchsoftware.com/videopad/" onclick="window.open(this.href);return false;
I have tried it and its very good to start with. All the different programs have a bit of a learning curve and they have a reasonable help area.
- AUbicycles
- Site Admin
Postby AUbicycles » Mon Dec 15, 2014 5:32 pm
This is a Go Big mount with a universal adapter and a very stubborn, sub-quality bolt.
Using good allen keys, the bolt is simply too soft and very quickly wore out so that the Allen keys wouldn't work.
The destructive method (1) to remove is to cut a slit with a metal saw and unscrew with a screw driver.
Nope. The metal is to soft that it just deforms. (The photo is halfway through the cut, so was deeper).
I have always complained that the bolts used are poor - unfortunately this is unusable now which is a pit as it wasn't that old and they are not cheap.
Postby Je » Mon Dec 15, 2014 6:04 pm
Whats the best gopro mount for all conditions including MTB trails?
Looked at handlebar mounts but a lot seem to break.. Would the best option be the chest mount?
- bychosis
Postby bychosis » Mon Dec 15, 2014 6:54 pm
Postby cp123 » Mon Dec 15, 2014 11:08 pm
Ideally I need 2 hours a day and I thought I read somewhere it did it. but mine hasn't run anywhere near that amount of time.
I usually use the light on the brightest setting too if that makes any difference
