Oxford wrote:Contour Roam2, waterproof as is, can use go pro mounts, plus its own. 3.5 hour life etc etc. Also doesn't look dorky mounted on a moto helmet.
Yep water proof is good but the size is not smaller.
http://www.ebay.com.au/itm/Contour-ROAM ... 4897.l4275" onclick="window.open(this.href);return false;
Dimensions
Depth 3.94 in. = 100 mm
Height 1.34 in. = 34 mm
Width 2.17 in. = 55.1
And around $ 200-00 delivered
The Mobius is $110 with cables and is good for a car dash use as well,as It also recycles over the card, then runs indefinitely. A poor mans cam but dorkineness factor not a lot different to the Mobius. In fact if the dims are correct the ROAM it is a bit larger.
And its double the cost of the Mobius as well. No doubt the water proofing battery life of the Roam is great. Any way who said I wasn't a dork?
