For my GoPro HERO I needed to improve the mount and dramatically improved the stability.
Original mount on the stem with a sticky pad, bluetac jammed on the left / right side to better fit the contours of the stem and a cable tie. Even with a cabe tie over the camera and case, vibration was getting through. In what will be an ongoing process (as I will be using different mounting positions) I have improved the video quality adding some bartape underneath which significantly has improved dampening.
Next challenge is condensation that builds in early morning rides. It builds directly on the inside lense (of the case) and notice that the GoPro fix are two strips and other tricks are anti-fog on the inside. Any tips for preventing raindrops from forming on the outside? The surfer trick of licking the lense make not work from riding, though I am willing to try.
AUbicycles wrote:For my GoPro HERO I needed to improve the mount and dramatically improved the stability.
As far as mounts go, I really like the Quick Release Mount that I made a few weeks ago, It is cheap to make, is rock solid and frees up the real estate on your bars.
If you don't have the Tripod Mount, you could just fix a small piece of wood to the L bracket as a platform and use a GoPro adhesive mount instead.
This can be mounted to the front wheel quick release or rear.
AUbicycles wrote:Next challenge is condensation that builds in early morning rides. It builds directly on the inside lense (of the case) and notice that the GoPro fix are two strips and other tricks are anti-fog on the inside. Any tips for preventing raindrops from forming on the outside? The surfer trick of licking the lense make not work from riding, though I am willing to try.
It is recommended that before you use the camera, you open the case and let cold air from an aircon blow into it for 2 mins, either from the aircon in your house or car. Close the case while aircon is blowing onto it and never open the case outside. Put small strips of tissue in the case with the camera, this will help prevent fogging, or you can also get the anti fog strips, which by all accounts work very well. For water drops, use Rain-x http://www.carcareproducts.com.au/products/rain_x
Graeme
Thanks for the feedback. On the mounts you made (saw the lovely photos when you first posted) is this a rock solid mount?
Are you getting any extra vibration that you feel needs to be dampened? I am finding front mounted positions to add more vibration from the forks whereas rear mounted positions seem to sit better and provide more stable video.
Will look into the anti fog options. I avtually tried the lick trick today and while it works, the effect on a bike is limited with the oncoming wind, and impractical to lick while you ride
AUbicycles wrote:Thanks for the feedback. On the mounts you made (saw the lovely photos when you first posted) is this a rock solid mount?
You can also use some apple...Cut an apple in pieces and use them to wipe over the lens.
The mount is solid, as you can see in the pics, I reversed an L bracket, this makes it rock solid.
It doesn't matter what mount you use, DIY or brand name, the mount itself has to be absolutely tight with no movement, any slight movement is amplified as it travels to the lens. Again, regardless of what mount you use you will need to use something between the mount and bike. But be aware that if it is too thick it introduces vibrations instead of eliminating them. I find a piece of old bike tube works wonders, two TIGHT wraps is plenty.
A GoPro Tripod mount comes in REALLY handy, and can be placed just about anywhere on the bike using some hose clamps and either an L Bracket or flat piece of metal, a nut and bolt and some old bike tube.
If you want some DIY ideas using GoPro adhesive mounts... Quick Release Wood helps to dampen vibration, you can use a small piece of wood 1cm thick, as your platform for the GoPro and mount a GoPro adhesive mount to it. You could use this on the quick release either front or rear using the method in the photo's.
Stem Using a small flat piece of metal approx 8cm l x 1.5cm w, two hose clamps to fit the stem, one small piece of wood the same width and length as the GoPro flat adhesive mount and old bike tube. Handle Bars Same as above but smaller hose clamps, you can have it on the top or hang it under the bars.
Rear Seat Stay Same as Stem but use a small L Bracket.
Graeme
And feedback on the Hair Dryer... works a treat. A minute or so on cool and then pop in the camera and a little tissue, no more condensation. Now it hasn't been quite as cold this week though it is having a noted effect.
It looks the goods on paper, although the recording time is only 1.5 hrs. I would like to know what the mounting options are like as well.
Graeme
Yeh, I'm hoping to be able to use some sort of supplementary battery if I need to extend the time. According to CooD it comes with Superlock, helmet straps and mounts to suit, a handlebar mount and a tripod mount and is supposed to be compatible with Go-Pro mounting systems.
johnm_oz wrote:Yeh, I'm hoping to be able to use some sort of supplementary battery if I need to extend the time. According to CooD it comes with Superlock, helmet straps and mounts to suit, a handlebar mount and a tripod mount and is supposed to be compatible with Go-Pro mounting systems.
Built in GPS and G sensor appeals to me.
Cheers JM
Being able to use GoPro mounts would be a very good selling point as well. I wonder what the battery use is like with GPS enabled? How long before you get it?
Graeme
Cheers JM
It seems the GPS module is an optional extra and is not standard.
Graeme
IME from Cood about 10 days to 2 weeks. Yeh I assume the GPS'll severely limit the battery life, that's why I'm hoping to be able to use an extension powersource.
The CooD package is advertised as being bundled with the GPS module and a 16G card. If it doesn't come with them it'll go back...
Love the dog's eye view, now I know why legs hold such a fascination for them, that's about all they see!
I'll be replicating your QR bracket now so I can use the Otek as a rear camera.
johnm_oz wrote:Can you resolve numberplates on the original? I wasn't able to on the youtube version. Looks good, tho.
Cheers JM
You can. Usually. It records at 1280 x 960 at 29FPS. The image quality OK, but not great. There are some issues with blurriness over exposure when the light changes. It has a mic, but it might as well not have. Completely useless.
It's definitely more suited to uploading a bit of fun to YouTube rather than gathering evidence for road rage cases.
Those looking for GoPro2's could try out Torpedo7 Looks like they're on sale!
GoPro Hero2 Outdoor and Motorsports editions $299.99 each Chest mount $39.99 LCD Bacpac $99.99 Wrist housing $39.99 Helmet front mount $14.99 Suction cup mount $29.99 Vented helmet strap $14.99
Wishing I hadn't bought mine (plus all the accessories) at the more expensive price now!
