Crawf wrote:Tried a different view today (with a small CCR win), might stick with this one but push the bracket out wider. Thoughts on front vs rear view?
No seriously, there's a lot of obstructions in that shot, it would be better to have it on your seatpost or saddle facing backwards. I've got mine mounted under my saddle and its very stable there using a twofish lockblock. As a bonus I use the lockblock to mount my zebralight h51r red light at night, and shine it up at alfoil under the saddle, which gives me a nice amount of rear and side red light (i use it in medium mode, high is too bright at night).
I agree, there is too much in the shot. If you want to try different angles try mounting it on the quick release, either front or rear, you have the option to face it forward or backward in either position. It gives a different perspective, take a look at the video I posted on the previous page.
Graeme
GoPro users, would you like to have a chest mount?
Some time ago I advised GoPro users that you could make a chest mount using the plastic base that came with your GoPro and I said when I had a chance I would see if I could make one and post it for you all. Well today I had a choice, keep painting the exterior of the house or go down to the shed and play around, I chose the shed
This is easily made using the plastic base that came in the box for your GoPro, some strapping and a buckle, some double sided velcro and about 30 mins. You will also need the GoPro's J Hook Buckle
The Parts needed
Cut four slits into the plastic base, you could also round off the corners.
I used an old strap that I bought at Bunnings, it is 25mm wide and 2.75mtrs long and comes with a quick release buckle, the cost is approx $7. The double sided velcro is also at Bunnings in the same isle. Cut one piece long enough to just fit around your chest, you will need to also allow for the buckle. Next you want to create a Y in the back, cut a small piece that will be the bottom of a Y, cut two lengths to go over your shoulders. Stitch the bottom of the Y to the Chest Strap, next stitch the two Shoulder Straps to the top of it so it forms a Y on your back.
Now for the front, thread the Chest Strap through the two bottom slits in the base and attach the buckle, be sure to have the buckle just off to the side or it may rattle against the plate. Thread the shoulder straps through the slits on the top corners, be sure to have enough strap so you can adjust it if need be. Stitch the double sided velcro to each of the shoulder straps, these will be used to lock off the shoulder straps and also adjust the tightness.
Finished
You could also stitch in some short strips of elastic, maybe on the sides of the chest strap and also on back of the shoulder straps. This may prove to be a bit more flexible and comfortable.
I didn't have time to try it out on the bike, instead I went outside and jut jumped up and down along my driveway.
Graeme
Something else I came across for GoPro Users. GoRemote, remotely control your GoPro, it connects to the Bus Port on the GoPro and costs $59US. As you probably already know GoPro are going to release a WI-FI Remote, but there is no pricing yet, so the GoRemote may be a cheaper option.
I bought a chest mount but I can understand how you made yours!!! nice work... But I think the real one is more solid. I do have the problem of it picking up my heart beat I only realized when it was connected to the sub. I'm thinking of putting foam between mount and chest.
newbikeorupgrade wrote:I bought a chest mount but I can understand how you made yours!!! nice work... But I think the real one is more solid. I do have the problem of it picking up my heart beat I only realized when it was connected to the sub. I'm thinking of putting foam between mount and chest.
I also have the chest mount and I agree it is very good and is made from elastic material so it is very comfortable to wear as well. The DIY mount is for those that don't want to or can't afford to buy the GoPro chest mount. There were a few members that were interested in it after seeing some footage posted by Trailgumby. A lot of people don't realise the box the GoPro comes in has a very useable plastic base.
Graeme
Yet another option for GoPro users, Unruly make Cases, Latches and Lenses for your GoPro,
Their Pro Case is the HeadCase Pro and apart from being bomb proof, it has 9 mounting points and although it's expensive $348, this must be the ultimate case.
Headcase Pro is a lightweight, multi-mount protective case for gopro, cut from a single block of aircraft grade aluminum.
features
Compatible with the gopro hero and hero ii. Sealed buttons, windows and door keep dirt and moisture out. Rugged aluminum and stainless steel construction. 9x quarter-twenty threaded holes give unlimited mounting options. Incorporates gopro six-screw mount for ultimate compatibility Included screw lets you to bolt the case shut for extreme situations. Access all cable ports by removing the sealed rubber side inserts. All tally lights on the hero ii remain visible via clear tubes. The front lcd and tally light are protected behind a sealed, clear acrylic window. Super-strong rare earth magnets and a patent pending cam latch keep the door securely shut in all conditions. A single reversible-flippable rubber hood with acrylic window eliminates multiple doors. 1 hood = 4 accessories.
johnm_oz wrote:Yeh, I'm hoping to be able to use some sort of supplementary battery if I need to extend the time. According to CooD it comes with Superlock, helmet straps and mounts to suit, a handlebar mount and a tripod mount and is supposed to be compatible with Go-Pro mounting systems.
Built in GPS and G sensor appeals to me.
Cheers JM
Being able to use GoPro mounts would be a very good selling point as well. I wonder what the battery use is like with GPS enabled? How long before you get it?
It seems the GPS module is an optional extra and is not standard.
Graeme
IME from Cood about 10 days to 2 weeks. Yeh I assume the GPS'll severely limit the battery life, that's why I'm hoping to be able to use an extension powersource.
The CooD package is advertised as being bundled with the GPS module and a 16G card. If it doesn't come with them it'll go back...
Love the dog's eye view, now I know why legs hold such a fascination for them, that's about all they see!
I'll be replicating your QR bracket now so I can use the Otek as a rear camera.
Cheers JM
It arrived today. First impressions are excellent, GPS module and 16G micro SD included as advertised. Comes with a little remote, yet to work out why you'd want that. Mounting options are as described, helmet mount with an assortment of straps and pads, some superlock, handlebar mount and tripod socket. Don't know what the GoPro mount looks like, but I've taken a couple of photos of the package contents and I'll make sure the mounting system is visible.
Strapped it on the mountain bike (handlebar mount)and went for an hours ride along the foreshore this arvo, again first impressions are good. Video is nice and steady, car numberplates are clearly resolvable at speed. Microphone level was way too high, as soon as I started doing any speed the tyre whine overloaded it badly, but level is adjustable so I'll have a play with that. Got to have a play with the helmet mounting options, too, as that's where I want to put it when I'm on the roady, glad I didn't have it there this arvo, I nearly took my head off on a low branch as it was...
Battery seems ok, it wasn't fully charged when I left, and there still seemed to be a goodly bit left in at the end, I had the GPS and G sensors enabled to maximise the load. Can't see any way of using a supplementary pack, but it's a 5 second job to pop a freshly charged one in, so a spare battery will be handy. It didn't come with a mains charger, it's just charged via a USB lead, but one of those generic lipo chargers should work ok if you need an external charger. Couple of nice featuresit has- you can use the G sensor to line it up flat and level, and there's a laser aiming pointer that comes on for the first 10 (settable) seconds of recording. HDMI output works well and it comes with a mini to standard HDMI lead. You can overlay GPs data including speed, G sensor data and of couse timestamp directly on the video as it records, too.
Software's a bit clunky, but works ok, and I'm sure there are a heap of 'dashboard' programs out there. Video format it uses is .mov, so you need quicktime, and it writes a .map file which will be the GPS and G sensor data. So far I'm impressed, I'll post the pictures and a bit of video as soon as I can.
Not sure if this cam has been posted previously, but when I was looking for a retailer to order a GoPro Wi Fi Back and Remote, I stumbled across the interesting looking cam which already does wifi streaming and is competitively priced with the Hero 2.
Seem alright for the sub $20 price (specs similiar to 808 Jumbo?)
Main issues I see are: 1) Waterproof (or lack there of) - Creativity/ingenuity should sort that. 2) Mounting - Creativity/ingenuity should sort that. 3) Battery Life - Includes External Battery "Bottle", single AA size... easy to carry spares.
Products Description: Smallest mini DV with powerful functions. Functions including: camera, video recoding, sound recording, webcam, motion detection, etc. 1280*960 high resolution. Adds more fun to your everyday life. Ideal for travelling and other outdoor activities.
Features: The smallest mini DV: 4.5cm×2.9cm×1.0cm, 15g. Video resolution: 1280*960. Picture resolution: 5 mega pixel (interpolated by software), 3 mega pixel (recommended). Powerful functions: camera, video recorder, sound recorder, and webcam. Advanced video motion detection function. (As long as objects move into effective range of the lens, this mini DV will begin recording video automatically without pushing any buttons by yousrself.) Playing while charging. Supports time and date display. Supports Micro SD/TF card up to 16GB. (memory cards NOT included) Charged via USB port or powered by connecting 1 x AA battery (emergency). Comes with a mini iron case. Perfect companion while you're shopping, hiking, travelling and other outdoor activities. Can add fun and color to your life, not a professional camera though.
Specifications: Image sensor: CMOS image sensor Lens angle: 60 degrees Video resolution: VGA?1280*960 (AT) 30fps Picture resolution: 5 mega pixel (interpolated by software), 3 mega pixel (recommended) Webcam resolution: 320*240 Format: AVI (video), JPG (picture), WAV (soud) Video compression: M-JPEG Charging time: About 3 hours Play time per charge: About 85 mins (video recording), About 3 hours (sound recording) OS: Windows me/2000/XP/2003/Vista?Mac OS 10.4?Linux Memory: Micro SD (TF) Battery: Built-in 220mA rechargeable battery Input: DC-5V Charged by: USB port or 1x external AA battery Color: Black Camera weight: 15g Camera size: 45mm x 29mm x 10mm
NOTE: Import duties,taxes and charges are not included in the item price or shipping charges.These charges are the buyer's responsibility. Please check with your country's customs office to determine what these additional costs will be prior to bidding/buying.
Package Include: 1 x Mini DV 1 x Wrist Strap 1 x Mini USB Cable (connecting external AA battery) 1 x USB Charging Cable 1 x USB Data Transmission Cable 1 x Battery Bottle (1 x AA battery) 1 x CD (user manual and driver)
Yep got one very similar, as in the 1280 x 960 is the same, but then the front label states 3.0 mega pixels. Reasonable but very grainy picture, but it could capture rego plates if not too far away, and if the camera wasn't shaking around too much at the time. Does not deal well low light or lighting changes. Have since got hold of a Kaiser bass, which does a better job, but have considered mounting the old one as a rear facing.
I think for an extra $10 there is a waterproof version.
The only mod I'd suggest is to round the corners to at least 25mm diameter quarter-circles. Four or so weeks ago I went over the front of the bike on a section of techy mountain bike trail and landed on the GoPro, cracking a rib.
What those sharp corners would do to you with your full bodyweight landing on them from handlebar height is not a nice thought
(Oh, and the GoPro is fine. Thanks for asking )
Does any of these cameras record in a cyclical fashion? ie: record continuously and just record over the oldest footage? Thinking of using one of these in a car as recording device, and have it set to just record continuously when the cars on...
Dr_Mutley wrote:Does any of these cameras record in a cyclical fashion? ie: record continuously and just record over the oldest footage? Thinking of using one of these in a car as recording device, and have it set to just record continuously when the cars on...
From what I have read the Swann Freestyle HD will do this.
... except when it runs out of battery it doesn't close the current file properly, and you can't then access it. For in-car use I'd recommend running a USB lead off your GPS power supply.
I assume there are probably some software tools available on the dubyadubyadubya to fix the file in this crcumstance, but they're not worth the effort to find at this time. Camera's going back to wholesaler shortly because he's decided to discontinue sale of this model once current stock is gone. Will be reviewing a unit called a "Gaoki" when it lands.
I have a 1080p keychain cam that does that, and has a cigarette lighter to usb power supply that comes with it when you buy it. You'll still have to turn the cam on and off. It was a cheap $50 experiment that would be fine on the dash, but didn't pan out real well on the helmet.
I've tried three different ones so far and found that the $14 MD80 type you can find on Ebay are the best quality but not the most reliable and not waterproof. I then "moved up" to a Swann Sports cam which was fine but too poor a resolution to get rego numbers unless they were directly in front. The Kaiser Baas sportscam was my latest and this is absolute rubbish. Even with a Class 10 memory card in it it constantly stutters, the handlebar mount locks tight to the handlebars but the camera still wobbles around on its attachment and the quality of the footage is so grainy you can't make out much at all, in particular in the low light of early morning or even early evening. Even during fine daylight hours the overall video quality is extremely grainy. Was going to take it back but can't find the receipt.
May have to save up my pennies for a GoPro or Contour but no-one seems to review them for lowlight capability. Anyone got examples of this?
