Video Camera who uses one?
Postby Ozkaban » Fri Aug 17, 2012 11:39 am
*** NERD ALERT ***
For those of you who don't find the way the gopro/any camera names files particularly useful, I have written a script running in cygwin bash that renames them to the date/time last modified (ie, the end of the video recording). If there are two files modified in the same minute then it adds a counter which it increments thusly:
Code: Select all
Aug 17 10:50 20120817-1045.mp4
Aug 17 10:50 20120817-1049.mp4
Aug 17 10:50 20120817-1050.mp4
Aug 17 11:28 20120817-1128.mp4
Aug 17 11:28 20120817-1128.1.mp4
Aug 17 11:28 20120817-1128.2.mp4
Aug 17 11:28 20120817-1128.3.mp4
Aug 17 11:29 20120817-1129.mp4
Aug 17 11:29 20120817-1129.1.mp4
Aug 17 11:29 20120817-1129.2.mp4
I've deliberately not added a .0 to the first instance because a) it's a simple script and b) I didn't want every file to have a .0 in it. Someone else can work that bit out :-)
it's called gopro.sh and stored in /usr/bin
Code: Select all
#!/bin/bash
for f in `ls *.MP4 *.JPG`; do
  FILE=$f
  EXTN=`ls $FILE | awk -F. '{print $2}' | tr '[A-Z]' '[a-z]'`
  NEWNAME=`ls -l --time-style=long-iso $FILE | sed -e 's/-//g' | awk '{print $7"-"$8}' | sed -e 's/://g'`
  NEWFILE="$NEWNAME.$EXTN"
  COUNTER=0
  while [ -a $NEWFILE ]; do
    let COUNTER=COUNTER+1
    #echo "$NEWFILE exists, incrementing counter"
    NEWFILE="$NEWNAME.$COUNTER.$EXTN"
  done
  mv $FILE $NEWFILE
  echo "$FILE --> $NEWFILE"
done
Hope this helps someone. Don't know if it will work on a mac bsd shell. probably would with some modifications.
Dave
Ozkaban
by Forum Ads » Fri Aug 17, 2012 3:17 pm
Postby Vivifyer » Fri Aug 17, 2012 3:17 pm
am50em wrote:
Vivifyer wrote:finally got some extra mounts to use my gopro2 on my bike. Don't think I can be bothered using it every day I commute though...
Excellent video! Loved watching the hands move on the controls and it looks like a great commute. :mrgreen:
cheers :) I was surprised at how much my bars flex when i first took a look at the video
GraemeL wrote:
Why don't you want to use it for your commutes? It really doesn't take much to put it on and take it off your bike. If you have it, you might as well use it
valid point, :P I meant that I'm using it more during recreational rides. my commute is almost entirely on PSP, which is surprisingly uneventful most of the time.
Flickr Stream
DArt Gallery
Vivifyer
Postby RonK » Sun Aug 19, 2012 12:49 pm
Mentioned in the Sunday paper - the Liquid Image Ego cam. Looks interesting, relatively inexpensive, is wifi enabled and apps are available for streaming to IOS and Android phones.
Postby Xplora » Sun Aug 19, 2012 9:25 pm
RonK wrote:Mentioned in the Sunday paper - the Liquid Image Ego cam. Looks interesting, relatively inexpensive and is wifi and apps are available for streaming to IOS and Android phones.
These could be really nifty for bad necks as a rear vision camera 8)
Xplora
Postby AUbicycles » Mon Aug 20, 2012 12:05 pm
(choose to watch in 720p HD for better quality)
Youtube direct link: GoPro K-Edge in Akuna Bay, Sydney
This a GoPro Hero with a K-Edge GO BIG mount (the more expensive ones) and a nice downhill section with a few rough bits.
The quality of the footage compared to previous mounts is much better and I also use a secret material between the K-Edge and handlebar (which probably has not effect as it is really really tight).
You tube has compressed the video a lot and though the detail is nice. Rolling Shutter is greatly reduced so there are now heavy 'jello moments' though as a bumpy road there is still some distortion of the video.
On this cycle route, there are some other really rough sections though this is a nice downhill (along McCarrs Creek Road just before the turnoff to Akuna Bay and Westhead), and I put some music on it as well.
AUbicycles
Site Admin
Site Admin
Postby Lukeyboy » Mon Aug 20, 2012 1:01 pm
Nice downhill run.
To me it looks like the compression has more to do with how you exported it in your videoediting program rather than how youtube has compressed ie your bitrate.[/photographerandvideoeditormode] :P
Lukeyboy
Postby AUbicycles » Mon Aug 20, 2012 7:05 pm
You could be right, I was trying to get it done quickly so didn't take a lot of time on this though on youtube when viewed in 720p in HD then it is much closer to the original file.
AUbicycles
Site Admin
Site Admin
Postby Vivifyer » Thu Aug 23, 2012 6:06 pm
Youtube still seems to crustify your videos even when exporting at a higher bitrate. Using the default "youtube 720p" export settings which have your 2 pass encoring set to 5kbps still ends up looking worse once its uploaded. I tried 8kbps which is plenty for a 720 video using h.264, still ends up covered in compression artifacts once uploaded. Vimeo is much better for retaining quality. Unless there is some magical settings around, I think its just the way youtube is with uploads.
also here is a new one I put up
regular gopro bike mount, tightened till my fingers went numb.. to minimize vibration. Also tried putting warp stabilizer (after effects) on the video.. well it took about 22 hours to render. and looked like rubbish, so didn't upload that.
This is straight off the camera and speed up 400%
[youtube]http://www.youtube.com/watch?v=C6bUylDsYY4&hd=1[/youtube]
Flickr Stream
DArt Gallery
Vivifyer
Postby Baalzamon » Thu Aug 23, 2012 7:25 pm
Vivifyer wrote:Youtube still seems to crustify your videos even when exporting at a higher bitrate. Using the default "youtube 720p" export settings which have your 2 pass encoring set to 5kbps still ends up looking worse once its uploaded. I tried 8kbps which is plenty for a 720 video using h.264, still ends up covered in compression artifacts once uploaded. Vimeo is much better for retaining quality. Unless there is some magical settings around, I think its just the way youtube is with uploads.
Nice going, riding over a pedestrian only bridge at the 12min mark...
Baalzamon
Postby Vivifyer » Thu Aug 23, 2012 7:34 pm
yes, suppose to dismount there. But I didn't, congrats for noticing. :)
Flickr Stream
DArt Gallery
Vivifyer
Postby KonaCommuter » Thu Aug 23, 2012 8:04 pm
Like a boss 8)
2012 Oppy A4 | 200x Hard tail Kona Blast Deluxe
KonaCommuter
Postby AUbicycles » Fri Aug 24, 2012 10:12 am
On Youtube the image stabilisation trial I did made it 'washy' - while much of the vibration was compensated, a blurry results doesn't help much either.
That said, the bumps are from poor surfaces on the roads so when riding smooth sections the video is also smooth and on the road bike I have high tire pressure which doesn't help much for getting smoother video. Pretty happy with the K-Edge Go Big, even if it is pricy.
AUbicycles
Site Admin
Site Admin
Postby BadBlood » Sun Aug 26, 2012 5:42 pm
Ozkaban wrote:*** NERD ALERT ***
Code: Select all
Code: Select all
#!/bin/bash
  FILE=$f
  COUNTER=0
  done
  mv $FILE $NEWFILE
done
Dave
For those of us that do not know how to add a script, can you please tells us the steps involved?
Todd
viva la bianchi
BadBlood
Postby Ozkaban » Sun Aug 26, 2012 6:41 pm
It involves installing cygwin which is probably something you don't really want to do unless you're familiar with linux/unix.
I'll talk to my father in law who's a Windows admin about how to write the same in a windoes batch script, which will be very straight forward to run - will get back to you in a day or so.
Dave
Ozkaban
Postby RonK » Tue Aug 28, 2012 8:38 am
RonK wrote:At the price Mugglechops posted (thanks Mugglechops for the discount code too) wifi bacpac and remote kit was dispatched overnight by USPS First Class International for only $7 US.
It has become pretty much accepted that shipping costs from the US are high, but this goes to show that most US sites way overcharge for shipping. Rip off.
So a big thanks to Dave's Motors for getting it right.
Wifi BacPac & Remote Kit arrived from Dave's Discount Motors yesterday. K-Edge mounts arrived from Wiggle last week, and the Amari helmet with camera mount arrived a few weeks ago.
So with a Tamrac Zipshot tripod I'm almost ready for my solo tour of southland NZ.
On the weekend I bought some 19mm square alloy tubing. I'm going to fashion a camera boom which will be attached to the rear rack and give a view over my head.
Oh, forgot to mention the XSories U-shot telescopic boom I'm taking as well.
Postby AUbicycles » Tue Aug 28, 2012 9:43 pm
I was raving about the K-Edge Go Big mount (For GoPro) until this happened…
I will admit it wasn't a gust of wind though actually didn't expect it to give as easily as it did.
AUbicycles
Site Admin
Site Admin
Postby jcjordan » Tue Aug 28, 2012 9:48 pm
How did you do that?
Sent from my HTC Sensation Z710a using Tapatalk 2
James
jcjordan
Postby Lukeyboy » Tue Aug 28, 2012 10:33 pm
Pretty sure they'll send you a new one under their lifetime warranty.
Specifications:
Made in the USA. CNC Machined 6061 T6 Aluminum
Weight – 46 grams, super light, super strong
Compatibility – fits 31.8mm diameter bars; all mounting hardware included
Two position design – in front and below or in front and above handlebar
Lifetime Guarantee – if you break it, we will replace it
http://www.acecosportgroup.com/shop/k-e ... mount.html
Lukeyboy
Postby MattyK » Tue Aug 28, 2012 11:14 pm
MattyK
Postby wizardhat » Wed Aug 29, 2012 10:08 am
The video on youtube for that camera looks better than my contour gps :(. Looking forward to part 2 of his review.
wizardhat
Postby PA » Wed Aug 29, 2012 10:39 am
Early racecam mount.
In the morning, we RIDE.
PA
Postby mjd » Wed Aug 29, 2012 1:53 pm
Interested in this one. Unsure of mounting options though. $160.00 from Top Buy, anyone bought from there ? http://www.topbuy.com.au/tbcart/pc/Liqu ... 166454.htm
mjd
Postby Marto » Wed Aug 29, 2012 2:36 pm
PA wrote:Early racecam mount.
The camel couldn't keep up?
Marto
Postby jules21 » Wed Aug 29, 2012 2:57 pm
i have one of these, with the battery pack (as shown). i can't seem to get the camera to record, when the battery pack is plugged in. is this normal? or am i doing something wrong?
jules21
Postby Marto » Wed Aug 29, 2012 3:34 pm
jules21 wrote:Image
I read somewhere that the charger cable is wired in specific and differing ways between 808/Jumbo camera models, so a battery pack for a 808 #16 doesn't work in a Jumbo (or 808 #11). It could be that, which means wasted money for you (but if it turns out you have a "808 #16" battery pack, I'd be interested). Cant remember where sorry but one ebay seller of these cameras sells chargers specific to each model Link Jumbo, Link #16.
Another possibility is that you may have to do a different key press sequence when recording while charging. GraemeL?
Marto
Users browsing this forum: Addictr3, arkle, jules21, Summernight, VRE
