fingy wrote:I have been using a version 2 808 #16 keychain cam with the D (120 deg) lens as a helmet cam,
and am finding it an improvement as a helmet cam over the earlier ver1.
What is the battery life like?
Video Camera who uses one?Re: Video Camera who uses one?
What is the battery life like? Thanks Andrew
Re: Video Camera who uses one?About an hour as is, about 2.5 hours with a battery pack.
Re: Video Camera who uses one?I'm using a ching made 1040P HD camera, plenty of memory (with a 32GB class 10 SD fitted), it records in 4m59s sections, I have it mounted on the top of my helmet (yep it is a bit heavy), I've commuted with it in the rain & that hasn't presented any issues.
To see the end results, I post our Retro Riverloop Raturday ride onto you tube every week, if you check the forum page you'll find where I posted last weeks ride. The only downside is that at 1040P it takes nearly an hour to upload a 5 minute clip to you tube. I tried another lower def 'lip stick' camera, mounted on the side of my helmet, it's way lighter but doesn't segment the video, so you end up with one massive file, that you can't upload onto you tube. We run a go pro on the roll cage of our race car & without a direct comparison, I think the chinese one gives nearly as good a video.
I have only used it withan external supply which gives about 3 hours recording ![]()
with the configuration tool you can choose either 5-20-40-70min files with the #16
Thanks and thanks for the image. That has given me an idea as to how to use the battery. I had thought of putting it my jersey pocket but your approach looks much neater. Andrew
You would be better off recording in 720P. For cycling you don't really need 1080P and there really isn't much difference in quality, recording at 720 makes it a lot easier to edit and doesn't bog down your PC. Also some cameras allow a wider angle at 720P which is good for cycling.
Why not just edit the file? If you want some information about video editors check out the Bicycle Camera FAQ's link in my signature and scroll down the page to the editing section. Graeme ***Looking For Information About Bicycle Cameras ***
For a cycling camera the 808 #16 or the Jumbo are all you really need. They are inexpensive and easy to mount just about anywhere on the person or bike. Graeme ***Looking For Information About Bicycle Cameras ***
I just checked the camera & it isn't 1080P but 720P so that obviously isn't the issue. I've loaded a video editor but most are for Vista or later, I still run XP as I'm not sure that Microsoft have worked out what system they want (Vista been & gone, 7 is now being replaced by For a camera under Aus$80 delivered it does a good job, it rattles around quite a bit when it's handlebar mounted, that & I like to 'aim' it, helmet mounted works better for me.
Uploading problems are mainly due to your connection speed, upload speeds are more often than not a lot slower than your download speed. It will also depend on the size of the file you are uploading. If the camera rattles when mounted to the bar, add some rubber strips and make sure the mount is really tight, but if you prefer helmet mounted then it's not a problem. Graeme ***Looking For Information About Bicycle Cameras ***
Number plates are a lot harder to read in a 720p recording.
thanks to fingy's post I bought a this mount for my #16 camera
i've found 720p sufficient for reading rego plates at close range in clear, daytime conditions. undoubtedly 1020p would give enhanced recognition. 480p VGA is insufficient though for anything except cars that pull up right in front of you.
Which is exactly why I prefer a higher resolution.
its actually one of the least important factors in plate reading. The most important factor is the lens of the camera, as a slightly telephoto lens will make the plate readable from much further away where the plate will be at a much squarer angle to the camera, and for far more frames.
Re: Video Camera who uses one?Pretty sure it has been mentioned before, but be careful if you use a GoPro mount. My camera ended up abandoning ship and flew straight under the wheels of a B-Double. The mount had sheered off the 2nd time I used it.
Pic here. Now, who is good at writing letters to companies asking for a replacement camera?
That's a lovely picture of the broken mount, but I was really expecting to see a picture of the squashed camera. Or what would be even better is the footage from the time the camera departed the bars to the time it met its fate under the wheels of the BD. I'm sure if you sent that to the makers of the GoPro you might not only score a new camera, but possibly video of the year. Did the memory card survive the impact ? Gas propulsion.......it's natural don't fight it.
As you requested... Ouch We looked for the memory card for 10 minutes. No luck.
Re: Video Camera who uses one?Mmmmmmm ? I don't see a camera. I see a mangled case & a bit of lens.
Maybe the remainder is in the tread going around & around on the highway to camera hell. Gas propulsion.......it's natural don't fight it.
Received the Liquid Image Ego on Friday but I haven't tried it out yet. I'm hoping to use this as a rear camera. Originally I wanted to pick up the Jumbo 808 #16 but with an 1 hour battery life it would have been good for my commutes to work but not for my longer weekend rides 3-5 hours. The Ego should provide around 2hrs by itself and should be more rain proof than the Jumbo plus the option of an extended battery soon and the ability to frame the video image with the iPhone prompted me to go for the Ego. Mounting - I'm hoping to attach the ego which comes with a standard tripod mount to the seat post. Are there any mounts that will allow me to attach it to the seat post but at 90 degrees (i.e. allows me to keep the camera upright)? I like the Contour Roam with its 270 degrees lenses which I will keep up front but hoping to get the Countour Plus 2 if the reviews are posititive. I think this will be a good bike setup as it records GPS and has an removable battery which I miss with the roam. ![]()
Re: Video Camera who uses one?It even fractured in the exact same spot as mine did.
![]() It seems that the handelbar mount (at least for road bikes) tend to fracture more easily compared to when mounted on BMX/Mountain bikes (I'm guessing vibration due to the lack of tread on bike tires/no suspension combined with the tighting of the lock on the plastic). If you buy another one for your roadbike I'd reccommend using one of the k-edge handle bar mounts or the GoPro rollbar mount (chunkier) attached to the stem. ![]() Watch out for the far right attack from The Ham!
Re: Video Camera who uses one?I wont be buying another GoPro. If they replace mine, all good, but I refuse to stump up another $300 to replace a camera that was destroyed because of their mount.
Re: Video Camera who uses one?What would you replace it with Norbs, assuming they don't do the right thing and replace it?
Either the new Contour or that Sony that has just been released.
Re: Video Camera who uses one?The Sony looks very cool and they DO know how to make cameras. I'd be having a good look into the mounts though.
Who is onlineUsers browsing this forum: AndyRevill, FuzzyDropbear, GBanger, Mylotian |
