Page 102 of 205
Posted: Thu Sep 12, 2013 1:00 am
by Aushiker
briztoon wrote:So I'm buying a Contour Roam 2 for my helmet/handle bar, and I'm looking for a camera I can mount on my seat post.
You do know that Contour have apparently gone out of business so not likely to get much in the way of support.
Posted: Thu Sep 12, 2013 6:17 am
by Wakatuki
Timeonabike wrote:Hi MichaelB,but hey summer is coming in Perth so no rain for the next 9 months.
Well thats not fair, can I send you some of QLD's coming deluge.
Back to thread..
Posted: Thu Sep 12, 2013 11:01 am
by Aushiker
dentalfloss wrote:Last ride was on the bike 4 hours and so far seems even the bacpac won't be enough for battery time. Would I need to carry another spare battery and swap after about 3 hours?
I would think so. I don't get much more than two hours out of my setup with the Backpac.
Then charge two batteries after every ride?
Yes. They can charge one after the other when connected together but.
Anyone know if it would be possible to connect the hero3 to a dynamo hub charger?
Not unless you mount it without the case or drill a hole in the side
Posted: Thu Sep 12, 2013 11:54 am
by briztoon
Aushiker wrote:briztoon wrote:So I'm buying a Contour Roam 2 for my helmet/handle bar, and I'm looking for a camera I can mount on my seat post.
Hi Andrew,
What support will I need? A local store has a lot of Contour in stock, so I was planning on buying through them.
Can you offer an appropriate alternative. I'm not tech savy at all, so need something simple to operate, etc.
Posted: Thu Sep 12, 2013 2:18 pm
by Aushiker
briztoon wrote:Aushiker wrote:briztoon wrote:So I'm buying a Contour Roam 2 for my helmet/handle bar, and I'm looking for a camera I can mount on my seat post.
Hi Andrew,
I guess legally you will have warranty from the local store so that is good ... it is really their problem if it goes bung. My Contour has gone well for a few years so maybe not an issue anyway. Just make sure you keep the documentation so you have an out if it is does play up.
Posted: Thu Sep 12, 2013 9:53 pm
by Aushiker
Another Kickstarter project -
Rideye: The Black Box Camera for your Bike. Might appeal to some ...
Posted: Fri Sep 13, 2013 8:53 pm
by dentalfloss
fingy wrote:dentalfloss wrote: is there a risk of these exploding?
that battery is about 2.5 years old maybe they explode at 3
I am
only concerned what it may doing to my head at such close proximity,
and being on my head everyday. I know the wireless Cateye refused
to work if the battery was near it
Hi fingy the #11 battery pack specification I have (model DS-2000) states 500mA max output
The mobius manual says use a minimum 1000mA output to prevent potential failure, see page (um no page numbers...), see section "Charging" of their manual
http://www.mytempfiles.info/mobius/MobiusManual.pdf" onclick="window.open(this.href);return false;
http://www.mytempfiles.info/mobius/index.html" onclick="window.open(this.href);return false;
For optimum results, the charging voltage should be +5V under load. Only
use quality chargers capable of supplying 1000mA (1A) and a stable voltage of at least 5V. Low
quality chargers may not be able to supply enough current and can lead to premature battery
failure or, in the worst case, even destroy the camera.
Posted: Sat Sep 14, 2013 2:18 am
by dentalfloss
Aushiker wrote:dentalfloss wrote:Last ride was on the bike 4 hours and so far seems even the bacpac won't be enough for battery time. Would I need to carry another spare battery and swap after about 3 hours?
Thanks Andrew - doesn't look like a good option for now. By your experience I would need 3 bacpacs I think for 4 hours? And they are integrated so seems awkward to carry that around.
I was hoping with a hub dynamo and a bunch of microsd cards could capture video or time lapse without having multiple batteries and bacpacs. Especially on tours when might be cycling 8 hours or more.
First test run with Mobius was just under 60 minutes at 1080p 30fps.
Posted: Sat Sep 14, 2013 2:46 pm
by Aushiker
dentalfloss wrote:Thanks Andrew - doesn't look like a good option for now. By your experience I would need 3 bacpacs I think for 4 hours? And they are integrated so seems awkward to carry that around.
Pretty close to that I would say, but you could increase battery life by using time lapse and maybe lower settings. Haven't tried this but
If you can charge your Mobius external battery with the dynamo whilst riding this maybe an option but if you plan to record day in day out on a tour you are going to need a fair cards I suspect.
Posted: Sat Sep 14, 2013 4:54 pm
by Boognoss
dentalfloss wrote:Aushiker wrote:dentalfloss wrote:Last ride was on the bike 4 hours and so far seems even the bacpac won't be enough for battery time. Would I need to carry another spare battery and swap after about 3 hours?
I use Backpacs and internal batteries for long rides. Swap out both at the same time when they're almost flat and get the same battery life again. Then once I'm out of Backpacs (I have two of them and 11 internal batteries) I just swap out the internal batteries.
Cheers, Simon
Sent from my mApple myPad using Tapatalk HD
Posted: Sat Sep 14, 2013 6:02 pm
by fingy
dentalfloss wrote:Hi fingy the #11 battery pack specification I have (model DS-2000) states 500mA max output
Mine also, yet the seller advertises it as a
1200mA I don't know much
about electronics but figured it'd be okay.
Maybe I need some thing like this one
2600mAh?
Posted: Sat Sep 14, 2013 11:52 pm
by Pushy
Kogan has
this, 2 outputs, 1 and 2.1 amp out and 11000mAh capacity
Posted: Mon Sep 16, 2013 7:23 pm
by dentalfloss
I noticed today Dick Smith has a few options like this one
http://www.ttmag.com.au/2013/02/20/meet ... rgy-stick/" onclick="window.open(this.href);return false; they were selling for $40. Also had an iTough or iPower or something which was water/dust proof and impact resistant 6000mah for $80
Ordered a 1A output battery box off e-bay for $10 and seperately 2 x 3400mAh panasonic li-ion batteries. So should get almost 6800 mAh in a profile similar to this item
http://www.ebay.com.au/itm/New-18650-5V ... 1176643633" onclick="window.open(this.href);return false;
So about $35 for 6800 mAh with known brand batteries. With luck the battery should last longer than filling a 64GB card, which at 1080p 30 fps should be close to 8 hours.
Could probably do it cheaper if buying the batteries in bulk or getting them from Chinese sellers. Bought mine from Australian seller was $5 more. Or take a gamble with cheaper name batteries.
Posted: Tue Sep 17, 2013 7:09 am
by VRE
dentalfloss wrote:So about $35 for 6800 mAh with known brand batteries. With luck the battery should last longer than filling a 64GB card, which at 1080p 30 fps should be close to 8 hours.
Which camera are you using? I've been using the GoPro Hero 3 for months now on my commute. The round trip is 2.75 hours and in the 1080p 25fps mode fills 25GB of the 32GB SDHC card I'm using with the GoPro. This means it would take 7 hours to fill 64GB (assuming I could find a way to keep the batteries charged for that long).
Posted: Tue Sep 17, 2013 8:11 pm
by dentalfloss
VRE wrote:dentalfloss wrote:So about $35 for 6800 mAh with known brand batteries. With luck the battery should last longer than filling a 64GB card, which at 1080p 30 fps should be close to 8 hours.
Only just got a Mobius. Those are approximate figures also no sound. Turning sound off saves approx. 7% storage space according to the Mobius support thread. Do you record sound aswell?
I would like a hero3 but from reports the battery charge time will be an issue. With a protective case the best option seems to be carry extra batteries and bacpacs - but this is costly. Without the case then it may be possible to run the USB battery like in this blog
http://blog.all-things-photography.com/ ... ur-go-pro/" onclick="window.open(this.href);return false;
Edit: here's an external USB apparently specific for GoPro
http://www.amazon.com/Gomadic-Capacity- ... B00A2UX0W8" onclick="window.open(this.href);return false;
Integrated circuitry tailors output voltage and charging current to exact specification of the GoPro Hero3 (accurate to 0.1v).
But li-ion batteries are inexpesive so there's a premium for gopro bacpac design. Can't find offical specs but the GoPro battery what 1050 mAh (???) and the bacpac "doubles battery life" so assume the same 1050 mAh. That's 2100 mAh for around $100 (correct me if a bacpac and spare battery can be had for less). AA size 18650 li-ion battery can store almost 3400 mAh for about $10 (plus a storage case). I understand the designs are different but cost per mAh is up there.
The idea was a gopro for front (for the better quality footage) and Mobius for rear.
Posted: Tue Sep 17, 2013 8:24 pm
by VRE
dentalfloss wrote:Only just got a Mobius. Those are approximate figures also no sound. Turning sound off saves approx. 7% storage space according to the Mobius support thread. Do you record sound aswell?
Well, I need
something to record me swearing at the numpties
Posted: Tue Sep 17, 2013 8:39 pm
by dentalfloss
Actually there's some slightly larger capacity 1300 mAh batteries for gopro (2 for $20) on e-bay
http://www.ebay.com.au/itm/2-High-capac ... 0950315179" onclick="window.open(this.href);return false;
And a battery bacpac for $65
http://www.ebay.com.au/itm/GoPro-Genuin ... 1338937738" onclick="window.open(this.href);return false;
So 2 backpacs and the 2 batteries $150 for total of 4700 mAh.
Aushiker says he can get just over 2 hours with the original battery and bacpac. The bigger batteries are almost 25% more capacity (assuming accurate claims) then maybe an extra 15 mins?
So all up maybe 4.5 hours from this setup at a guess?
Posted: Tue Sep 17, 2013 8:43 pm
by dentalfloss
VRE wrote:dentalfloss wrote:Only just got a Mobius. Those are approximate figures also no sound. Turning sound off saves approx. 7% storage space according to the Mobius support thread. Do you record sound aswell?
Well, I need
Do people here recommend recording with sound? Maybe you're right - I should turn on sound and redo the tests. Thanks.
Posted: Mon Sep 23, 2013 6:57 pm
by apsilon
dentalfloss wrote:Do people here recommend recording with sound? Maybe you're right - I should turn on sound and redo the tests. Thanks.
I certainly record sound. An extra element in the case of an incident. eg near miss, you file a complaint with the police, they counter with a statement you verbally threatened them. Video would show the near miss but without sound it's your word against theirs on what was or wasn't said.
Posted: Tue Sep 24, 2013 11:41 am
by Summernight
I have a question for all you tech-savvy people:
I've set up my 808 cameras how I want them (one sitting on the side of my helmet just beside my ear and the other on the drive train side of the seat stay). Both cameras are orientated 90 degrees so at the moment footage is portrait view and not landscape. I want landscape footage but want to keep the orientation of the cameras as they are if at all possible. Is there such a way to modify the settings so that the camera can sit vertically but still shoot in landscape or do I have to change my set-up?
Posted: Tue Sep 24, 2013 12:21 pm
by InTheWoods
Summernight wrote:I have a question for all you tech-savvy people:
The problem is the sensor will be in portrait. You'd probably have to open it up and swivel the camera unit (Lens&sensor) around 90 degrees. The only "rotate" option that the camera supports is 180 degrees, not 90.
Posted: Thu Sep 26, 2013 11:31 am
by Dr_Mutley
InTheWoods wrote:Summernight wrote:I have a question for all you tech-savvy people:
Anyone know if turning the lens 90 degrees is easy to do? Or is it easy just to do with software afterwards? I want to run my mobius vertically so it sits unobtrusively in the vent of my helmet...
Posted: Thu Sep 26, 2013 11:38 am
by apsilon
I doubt it'd go back together once you turn the guts 90deg (you're not just turning the lens but the actual sensor as well and as I imgaine that's mounted to the main PCB you'd end up having to turn everything).
Far easier to rotate the video in an editor later if you need/want to or of course mount it the "right way" round in the first place.
Posted: Thu Sep 26, 2013 11:57 am
by Dr_Mutley
apsilon wrote:I doubt it'd go back together once you turn the guts 90deg (you're not just turning the lens but the actual sensor as well and as I imgaine that's mounted to the main PCB you'd end up having to turn everything).
Unfortunately the "right way" is less unobtrusive... Turning the video later is prob the easiest way... I think I saw a 90deg lens and cable somewhere on the net... Would be the other option I guess...
Posted: Thu Sep 26, 2013 2:39 pm
by Lukeyboy
DriftHD Cameras are the ones that you can rotate the lens 359 degrees.
