how much difference is 6mm?
• Page 1 of 1
how much difference is 6mm?hello
this may seem like a really noob question but just wondering how much difference 6mm is on the rim? you get 24mm rims that don't have the word "aero" associated with them but 30mm rims do. just wondering how much difference half a centimeter could make (besides weight) Can you imagine what I would do if I could do all I can? - Sun Tzu
___________________________ Giant Defy Advanced 0 Shogun Katana
Re: how much difference is 6mm?| | About that much.
Re: how much difference is 6mm?Not a lot. 24mm going to 50mm would be more significant, but even that % difference is in single digit.
wow, i didn't know you peolpe knew so much about these things Can you imagine what I would do if I could do all I can? - Sun Tzu
Re: how much difference is 6mm?ERD of 30mm rims makes finding replacements bothersome, I'd stick with 24mm so that you'll have a good range of readily available rims to choose from when replacement time comes around.
Yep, noob question. Reality is despite the marketing fluff, to all but racing types, difference is sweet fanny adams.
umm, not really percentage difference is 70% (percentage change is 108%) Ever since the vasectomy...I mostly ride fixed.
Sorry, I should have been more specific in my reply. Given the context of aeroness, the percentage difference referred to power saving as a result of aerodynamic characteristic of the wheelset. Bianchi, Ridley, Montague, GT, Garmin and All things Apple
Re: how much difference is 6mm?so i wouldn't notice the "aero" difference in a 30mm rim compared a 24mm rim? i take it that it is better to get a lighter rim then a aero rim
Well, there are many variables to aero characteristics and power efficiency of a wheelset, not one that a lay person can figure out just by a quick look. Also bear in mind that aero performance is not an all or none phenomenon, it doesn't suddenly performs better by hitting 50mm, but it's a continuum of performance changes. Further, aero performance isn't just about rim depth. Spokes and hub also play a part. In any case, the general understanding is that aero will always trump weight. But even that depends on how much more weight. The statement stays true though for wheels in the same class. The other aspect to consider is the quality of bearings and rigidity. They also play a role in power efficiency. Selection criteria shouldn't be based on a single criteria. Bianchi, Ridley, Montague, GT, Garmin and All things Apple
Re: how much difference is 6mm?I have just built a set of 30mm wheels (plenty of these rims around) and have been happy with them. I have been riding 24mm so far and have noticed a somewhat stiffer ride. The wheel is a little heavier, but I ride mostly on flats. It does look more aero, but haven't ridden it long enough to jugde if it rides more "aero" too.
Theoretically, deeper rims will give a harsher ride as they should be more rigid in the vertical plane. Lateral stiffness depends on rim, lacing, build and other factors. Bianchi, Ridley, Montague, GT, Garmin and All things Apple
You are an optimist norbs. It is actually a little less than that. (Or did you apply the Coffee Shop Admiration Factor? That could boost the result significantly)
Aero trumps weight. Our Website is: http://www.pro-liteoz.com Find us on Facebook by searching for "Pro-Lite Australia"
Better engine trumps aero? 2012 Jim Bundy
1995 Bosevski - Athena mid/late eighties Colnago Cromor
Re: how much difference is 6mm?Pose value at the cafe trumps all!
Never noticed much difference between standard wheels, 50mm and 65mm which I have now in terms of the rigidity. But I did notice a difference in the speed (running above 50km/h) with the 65mm versus the 50mm which surprised me. The 65mm seems quite a bit quicker. Or maybe it was the fact that the engine wasn't misfiring on that day. The better thing is the hubs - the new wheels have very good hubs on them. The weight difference between the two is marginal, to the point of not being worth mentioning as it is so small.
Probably very little. Upgrade the engine instead.
Re: how much difference is 6mm?bugger aero wheels.....get serious aerodynamics...
Get a Velomobile!!!! ..... now THERE'S your aero difference.... Moving on from my old 'bent..... now a Velonaut !!
Trisled Rotovelo..... and away we go!!
• Page 1 of 1
Who is onlineUsers browsing this forum: darkhorse75, Google [Bot], jedaandfred, MisuVir, Steve_F, yolk |
