fitting mudguards and rear rack
• Page 1 of 1
fitting mudguards and rear rackI want to fit the above to an electra brand bicycle that according to electra cannot be fitted due to the disk brake, how do I attach a photo of the bike so I can maybe get opinions on how to get around this if its at all possible, even aluminium welding a piece near the drop out for the fixings. its a cruiser so clip on mudguards are not an option I want full metal guards and a rear rack. Buy another bike I hear you say but its too late its paid for and on its way
Re: fitting mudguards and rear rackjust paste the link into the text box, highlight/select the link, and click the "img" button along the top.
or just paste the link, people will wrk it out
Re: fitting mudguards and rear rackThe drum on posting pics is HERE.
It's possible to do. I had a similar problem on the rear of my commuter, fixed it with a longer bolt and some old chain rollers as spacers. ...whatever the road rules, self-preservation is the absolute priority for a cyclist when mixing it with motorised traffic.
Re: fitting mudguards and rear rackThanks guys hope that worked, heres the pic, oh it did work cool, yes it has a front rack but I absolutely need a rear rack and guards
Well, I can see that it has fender & rack mounts on the frame and forks. You may just need to get the official Electra ones to get a good fit. Have a look at http://store.electrabike.com/eSource/ecom/eSource/default/default.aspx for some options. I have two Electra Townies, and we had them fitted with Electra guards and racks when we bought them, so it looks seamless. '11 Lynskey Cooper CX, '00 Hillbrick Steel Racing (Total Rebuild '10), '09 Electra Townie Original 21D
Re: fitting mudguards and rear rackI thought I could see them on the back but not the front but electra themselves say a rear rack and guards will not fit this bike due to the disk brakes. I emailed them in the US and attached that picture
Re: fitting mudguards and rear racktopeak make a disk brake specific pannier rack
http://www.topeak.com/products/Racks/ExplorerTubularRack_discMount
Re: fitting mudguards and rear rackOh thanks that would work? that leaves the guards...
Hmm...... Just don't put too much weight on it, or ride over rough roads loaded up Riding bikes in traffic - what seems dangerous is usually safe; what seems safe is often more dangerous.
Re: fitting mudguards and rear rackoh showtime the roads here in Brisbane are shocking for bumps and pot holes, and I want to carry about 8 or 9kgs, puts that idea out I guess
Re: fitting mudguards and rear rackThat topeak rack is steel hey? just spot weld a rod from new where it broke to reinforce it problem solved????
Re: fitting mudguards and rear rackBodged on bits of rod are unlikely to go with the looks of your bike. I would be looking at something more like the Tubus Disco. Ok so it's a stupid name, but it looks to be a reasonable design. Only rated for 20 kg though, unlike the 40kg rating of other tubus racks.
![]() I was going to buy a fast, stylish bike, but I looked in the mirror & thought "you're not fooling anyone, you know"
Not at all. 'Tis aluminium I have seen at least two other similar breaks. The thing that breaks first is the mounting bolt - the widely spread rack needs a longer bolt and leverage acts on it (even when tightened up tight) and causes it to shear off. Could carry spare bolts of course, but when the stub breaks off in the frame, with no protruding end..... Riding bikes in traffic - what seems dangerous is usually safe; what seems safe is often more dangerous.
+1 Bloody good idea. That cruiser does not seem to have upper rack mounts on the seat stay (and the low stays are unlikely to work with P-clamps). You may also need to consider something like this (from Wiggle) ![]() Riding bikes in traffic - what seems dangerous is usually safe; what seems safe is often more dangerous.
Re: fitting mudguards and rear rackwhere can the disco be purchased and will it clear a disk brake and would it fit a cruiser like that? My bike so doesnt have quick release wheels either
Let me google that for you The rack only comes in one size, said to fit bikes with disc brakes equipped with either 26" or 700C wheels. I am way too lazy to search for the specs of your particular bike, but it looks like it has 26" wheels so it may have extra clearance over the wheel, but this will depend precislely on where you choose to mount it. If you don't want the quick release, don't use it - the rack will be just as happy mounted to a bolted axle or the rack mounts. I was going to buy a fast, stylish bike, but I looked in the mirror & thought "you're not fooling anyone, you know"
You would however, need to drill out the skewer-sized lower holes to axle-size..... and maybe even slot them for easier fitting if you have long axle ends. Riding bikes in traffic - what seems dangerous is usually safe; what seems safe is often more dangerous.
Re: fitting mudguards and rear rackThanks il padrone - you are correct, of course, on needing to drill it out to mount to an axle - do you think there is enough meat on the bracket ? It is made out of 10mm tube so the bracket is only about 20mm wide, which to my mind at least will leave it a bit thin after drilling.
If not blompods will need to make sure he can use the rack mounts & it's a bit hard to tell Also it seems tubus actually make 2 different size racks, despite websites listing them as one. The dimensions are on the tubus website A couple of cheaper alternatives are the Axiom Streamliner Disc DLX ![]() And the Axiom Journey Disc ![]() It seems King St Cyclery have the journey disc in stock in black $60 so I might have ride over & have a look I was going to buy a fast, stylish bike, but I looked in the mirror & thought "you're not fooling anyone, you know"
Re: fitting mudguards and rear rackThat Axiom Streamliner Disc is really just a Cargo copy. But it's made of alloy, not CroMoly like the Cargo so not near as strong.
Personally I reckon blompod should seriously consider converting his hubs to quick-release axles to be able to run something like the Disco. Riding bikes in traffic - what seems dangerous is usually safe; what seems safe is often more dangerous.
• Page 1 of 1
Who is onlineUsers browsing this forum: Baalzamon, Google Adsense [Bot] |
