Doping in C-grade ?Re: Doping in C-grade ?If anyone has evidence of doping at any level of racing whether it be C Grade at Heffron or anywhere else, you should report it.
If you know it's happening, as some people here seem to be implying, then here is how you report it confidentially http://www.asada.gov.au/rules_and_violations/intelligence.html . If you know it's happening and you don't report it - you are part of the problem. Don't turn a blind eye. If you are talking through your hat - just shut up because you are further denigrating the sport of cycling.
i was refering to tuesday, not saturday. i should have been clearer Oppy Le Mauco - Dura Ace (wet weather bike)
Cervelo S5 VWD - dura ace Di2
I know you were, that was my point. B grade on a Saturday (whilst it is a scratch race) is slower than C grade on Tuesday. The corresponding C grade average winning speeds for last 2 Saturdays at Heffron were: 36.2km/h 36.3km/h
Re: Doping in C-grade ?tuesdays really are a step or two up
i will go down there this arvo and have a look, hipefully ill be racing next tuesday! Oppy Le Mauco - Dura Ace (wet weather bike)
C grade just means that it is the third toughest group on that day. What you race elsewhere is immaterial, yes you may race in B grade elsewhere because you are the equivalent of the second toughest field there. B grade riders at Heffron race B grade at Heffron, because that is their relative strength. It seems like you would prefer the grades named A+, A and B. Would that suit you more. The label is to reflect the fact that it is the 3rd toughest field there not that it is the equivalent of C grade elsewhere. If you had all those riders in 2 grades A and B as you would have (I presume) then you would have carnage with crashes all over the place cause of the numbers on a tight course. ![]()
Monsieur longues jambes, il y a patapons et patapons, attention!!!
Re: Doping in C-grade ?Perfect person to explain to me what it means
Christine you need to dismiss yourself from this debate. As someone new to cycling/racing in the last 18 months, I can assure you that the tone in your posts are not meeting your objective of being a moderator on this forum.
Re: Doping in C-grade ?In another thread, it was mentioned Australian grades can be matched to US categories, which are guided by FTP watts/kg.
I think C grade was accepted as 3-3.5watts/kg. However, this is far from satisfactory. A 70kg racer will do 34-37kph. A 90kg racer will do 38-41kph. If a WW can generate these speeds, then they'd presumably be competitive. Now we have a more objective criteria for determining what % of WWs could race c grade. Hands up if you know a 90kg WW who can sustain 41kph for an hour. Fav Ride : Pottsville, Byron, Bangalow, Eureka, Dunoon, Nimbin, Uki, Mooball, Pottsville 200km 3000m
No, they are not. What determines your category level in the USA (and many other countries) are your race results and points accumulated from racing. When you first start racing, you are required to start as a Cat 5, race and earn enough starts/places to gather the points needed to be upgrade to Cat 4. Then the process repeats. For Cat 5, you get points for finishing, and part of the process of earning points at that level is simply gaining racing experience before you are permitted to race in the higher categories. Naturally, Cat 5 have people of widely varying levels of fitness, plus those that are simply not fit enough to race at higher categories. From Cat 4 and up, then you actually need to start gathering points based on results in order to earn your category upgrade. This is typically done in geographical divisions, e.g. NorCal (northern California) or State boundaries, sometimes several states combined. As a result, due to the variance in racing numbers / depth of fields, even this does not end up producing equality across the country. A Cat 3 in one division may be at Cat 2 standard elsewhere but if they travelled to another division, they would still have to race Cat 3 (and they may well clean up). If they stayed there, eventually they would accumulate enough points to be upgraded. Power outputs are not and never will be used as a grading mechanism. All the W/kg numbers refer to is the typical power of riders that race in those categories, but it's quite a wide band. e.g. in some districts, you won't win a hilly Cat 3 road race without an hour power of ~5W/kg. If you want to know what grade you should be racing in Australia (and you are not sure), then just go race. If you win by a country mile, then smile for the after race photo, take your $20 envelope, brag to your significant other all night simultaneously explaining why you need those new deep section carbon wheels, and turn up next week in the next grade up. If however you get dropped pretty quickly, then drop down a grade. Lather, rinse, repeat. Simple really.
Re: Doping in C-grade ?Back to more serious matters, doping at lower levels.
Have a read of these three items: http://velonews.competitor.com/2012/08/ ... hgh_232611 http://www.outsideonline.com/fitness/Dr ... l?page=all http://www.outsideonline.com/outdoor-ad ... l?page=all to get some idea. But hang on, that's overseas stuff, we don't do that here surely? Have a read about this Sydney doctor who
http://www.smh.com.au/sport/cycling/doc ... 28c9k.html
Re: Doping in C-grade ?Just had my first race ever in C grade (c for controversial) I finished 3rd and I confess to having a GU prior to the race
Re: Doping in C-grade ?I won my first C grade race yesterday. broke and averaged 38kph for 30 solo minutes.
Though I put my win down to a pack not prepared to work together on a windy day to reel me in. Fav Ride : Pottsville, Byron, Bangalow, Eureka, Dunoon, Nimbin, Uki, Mooball, Pottsville 200km 3000m
So Allan and Coggan race category table is wrong? http://www.americanroadcycling.org/articles/PSL/WiddersHump/WattsSpeed.htm Fav Ride : Pottsville, Byron, Bangalow, Eureka, Dunoon, Nimbin, Uki, Mooball, Pottsville 200km 3000m
Re: Doping in C-grade ?It's not wrong... It just gives you an idea where you stand... But as no one has a straight line across the 4 values ( or do they?... I am somewhere near the bottom on 5 sec power and somewhere near cat 1 on 1 minute power ) you can only use it as guide. About the only place I can think it would give you an accurate result is in an uphill TT... Everywhere else many other things come into play.
In the US they have a proper grading system ( on your license!!!! ) and like Alex says the only thing that changes that grading is race results ( or lack if them
if it is as simple as that, why did Allan and Coggan publish FTs for each category? and how did they determine them? Fav Ride : Pottsville, Byron, Bangalow, Eureka, Dunoon, Nimbin, Uki, Mooball, Pottsville 200km 3000m
Because they have shiteloads of data and can give you a guideline based on results. A handicap is weighted more towards FTP, a scratch crit will be weighted towards 1 minute power, and in the case of our events (Stromlo in Canberra) usually results in a sprint. If you don't have a sprint, you need exceptional 5/FTP - as the only way to place is to ride off the front. My 5 sec/1 min is classed as 'untrained', which is why I have no expectation of ever making it to A grade. Sent from my iThingy... I ride, therefore I am.
Actually if I recall they didn't want to publish categories but publishers / readers wanted them in there... everyone likes numbers after all. Alex knows more on this. I think they were established them from all their data as best off test results... they are only a guide but do tell you roughly where you sit.
+1 that is what they say in their book, we tested heaps of riders, here are some guidelines, so you can identify your strengths and weaknesses
At least your 5 second gets you into untrained, mine is not even close I have a decent 5 min, my 5 to 10 min power is well above my critical power curve, sub 5 minute drops away dramatically from the curve and after 10 minutes, my power goes into a steady decline below the curve. So knowing those guidelines, using the critical power curve, I know I need to work on my sprinting and endurance / FTP and I need to start using my strength to my advantage. my blog Nick Cowie, member of Peel District Cycling Club
Re: Doping in C-grade ?yes as nickobec says, looking at where your power sits within the 4 columns gives you a good idea of your strengths and weaknesses... helps you decide what to work on and what to play to your advantage.
Thanks for this post. For once I completely agree with you. Weekdays: "Bliss" (Trek Madone 5.2 2012) | Weekends: "Cadel" (self built) | Casual: "Kitty" (Giant Cypress LDS 2009)
I agree completely. I think the point that Alex and several others were trying to make was that Heffron Tuesdays has always had a reputation for being somewhat special. If you were a C grader, you know you have made it if you can survive Tuesday Heffron. If you got spat out, then you know you have to train harder Weekdays: "Bliss" (Trek Madone 5.2 2012) | Weekends: "Cadel" (self built) | Casual: "Kitty" (Giant Cypress LDS 2009)
I never said it was.
Who is online |
