Chamois cream without lanolin?
shann
Postby shann » Tue Oct 23, 2012 11:10 am
Does anyone know of a good chamois cream that doesn't contain lanolin?
Ken Ho
Re: Chamois cream without lanolin?
Postby Ken Ho » Tue Oct 23, 2012 7:36 pm
I use a Hemp Body Butter from the Body Shop.
Tim
Postby Tim » Tue Oct 23, 2012 7:55 pm
No need to buy an expensive purpose made chamois cream. All you need is a good barrier cream or moisturiser to help stop chaffing.
Plain old Sorbolene is cheap, non irritant and works well.
Another one I have been using with good results ie. no chaffing or saddle sores which I am prone (and renowned) for is Skin Basics, Zinc and Castor Oil Cream. It is dirt cheap and works a treat. Buy it in large tubs from the Discount Chemist Chain stores.
Postby RonK » Wed Oct 24, 2012 5:37 pm
I use QV cream, but I have also use good old sorbolene - Amcal pharmacies sell a 500gm tub for around $7.00.
swon38
Postby swon38 » Fri Dec 07, 2012 9:24 pm
Sorry for the bump and graphic description but I have a question.
My jocks kind of get stuck between my groin and legs and as a pedal the jocks pinch and pull and I end up with decent chafing. Stopping short of wearing jocks or anything that has a seam between the groin and legs, is it reslly worth getting branded chammy cream over your run of the mill qv sorbolene cream?
human909
Postby human909 » Fri Dec 07, 2012 9:55 pm
swon38 wrote:Sorry for the bump and graphic description but I have a question.
Why would you even consider wearing jocks? Nicks are meant to be worn without jocks! And if you are not wearing nicks then surely that is the first step!
(I rarely used nicks and I've never used chamois cream in my life. Never had problems even with 240km+.)
swon38
Postby swon38 » Fri Dec 07, 2012 10:09 pm
I don't wear knicks, I wear sports shorts.
I would prefer to keep it this way (personal preference).
human909
Postby human909 » Fri Dec 07, 2012 10:39 pm
swon38 wrote:I don't wear knicks, I wear sports shorts.
Fair enough! In fact I'm on the record on these forums as "anti-Lycra"! :lol:
My recommendations would be either nicks under shorts OR seamless underwear. Though I'm hardly the expert on this matter. Creams I have no idea on.
Postby Mulger bill » Fri Dec 07, 2012 11:35 pm
Three words for you swonny: Tensioned Leather Saddle :D
ausrandoman
Postby ausrandoman » Sat Dec 08, 2012 6:10 am
Vaseline
Nobody younger than <del>27</del> 28 has experienced a month cooler than the 20th century average.
gassyndrome
Postby gassyndrome » Sat Dec 08, 2012 11:57 pm
There is no comparison. Go the nicks, with or without MTB shorts over if its the aesthetics that bother you. No seams rocks!
lump_a_charcoal
Postby lump_a_charcoal » Sun Dec 09, 2012 11:58 am
Jockey make good, seamless, thin jocks, which are almost a lycra material.
I use them to stop chafing when running.
$20 a pair, but worth it.
GraemeL
Postby GraemeL » Sun Dec 09, 2012 4:23 pm
I don't wear them either, I just wear the tight fitting short style undies and find them very comfortable even on long rides,
Graeme
Sent from my Transformer TF700T using Tapatalk 2
swon38
Postby swon38 » Sun Dec 09, 2012 5:46 pm
Any recommended (affordable) brand of knicks in that case?
greyhoundtom
Postby greyhoundtom » Sun Dec 09, 2012 7:56 pm
swon38 wrote:Any recommended (affordable) brand of knicks in that case?
Aldi knicks are the cheapest knicks you can buy, (paid $14 for the last one I bought) and while the padding is pretty good they are only suitable for wearing under shorts as they are virtually see through. :shock:
Postby il padrone » Sun Dec 09, 2012 8:12 pm
Chamois creme for chamois. If you wear jocks I'd hate to see the unholy mess that'd result from chamois creme :o :P
I only ever wear jocks for a short commute (10kms). Longer distance it's always knicks or Ground Effect Juggernauts, each with a chomois. But I never use chamois creme, even on a 2 week - 2 month tour; nor on a 200-300km Audax day ride.
Lovelessrobot
Postby Lovelessrobot » Mon Dec 10, 2012 1:07 am
I'm just starting to indulge in rides over an hour and am finding the knicker thing to become a problem.
To avoid buying more 'stuff', I improvised and have been using silicone based lube (yes, sex lube. Swiss Navy :oops: ) to keep things comfy. You only have to use the tiniest amount and it lubes for ages.
It means I can keep wearing underwear (because I am too paranoid to go without) and ride for longer without getting uncomfortable.
clackers
Postby clackers » Mon Dec 10, 2012 12:00 pm
Treat the knicks as underwear, Swon - launder after every ride. Just put those shorts over the top of them if you want to keep your current aesthetics.
Jocks can dig in, and the material of some boxers collects your perspiration instead of wicking it.
stinhambo
Postby stinhambo » Tue Jan 01, 2013 12:46 pm
Tim wrote:No need to buy an expensive purpose made chamois cream. All you need is a good barrier cream or moisturiser to help stop chaffing.
Do you apply the Sorbolene to the Knicks padding too or just the skin?
old al
Postby old al » Tue Jan 01, 2013 9:01 pm
Here's a thought. Are there any knicks made today with a chamois insert that is actually chamois? Why do they still call it chamois cream. By the way I use BBB cream. (Breasts, Buttocks, and Between the Legs). Top stuff, just rub it in, no mess and really works.
Al.
clackers
Postby clackers » Fri Jan 04, 2013 10:50 pm
Some people on this board might have applied lotion to genuine chamois to soften it, but these days the inserts are foam.
Postby RonK » Sat Jan 05, 2013 10:32 am
Slather it on the pad, liberally, and I mean liberally. Whatever remains on your hand, wipe it off on your skin.
Users browsing this forum: Adstar, Bing [Bot], Derny Driver, Duck!, Google [Bot]
