Moron Motorists #3
twizzle
Re: Moron Motorists #3
Postby twizzle » Sat Jul 06, 2013 10:48 pm
Ross wrote:
gobsec wrote:
yes, flashing versus solid beam can be a dilemma. i agree that motorists can find a flashing light difficult to assess for distance, although in my experience most motorists will hesitate as a result, which to me is a good thing. however a solid beam light can easily be missed within a background of lights, whereas a flashing light is quite distinctive.
I think it's more a case of the motorist recognises the flashing light as a cyclist and disregards it as nothing important whereas with a solid light they are unsure whether it is a bicycle or motorbike and because of this they err on the side of caution and don't pull out in front of it in case it is a motorbike.
Beginning of the week - driving home at night and needing to merge out of a slip lane, I have no idea if the light I saw was a bicycle 10M behind me or a HID in the distance. Just a bright spot of light in the dark.
I ride, therefore I am.
chriscole
Postby chriscole » Sun Jul 07, 2013 12:16 am
darkelf921 wrote:
chriscole wrote:
darkelf921 wrote:Well, I had a doozy today. Words cannot adequately describe how scared I was when this happened. A bus drove so close to me I had to struggle with the bike so I didn't get sucked in toward the bus.
Here's the video.
http://youtu.be/SSy_OZiOwC4
Eep. Wow. :shock:
While that was definitely scary, and both highly dangerous and illegal on the part of the bus driver (and yes you should report it), at the risk of inciting a lynching, it has to be said.... choosing to ride on a highway... probably not the best decision, don't you think?
I wasn't riding on a highway. I was riding on the wide shoulder. The section you see is where another road joins it. You have to ride around a "medium strip" to continue forward. As the truck turns left and joins the main road, I have to ride into the left lane (of the main road off the shoulder) and then cut through the left lane to get back onto the shoulder. There is a solid line so I have to stay in that lane until the line becomes unbroken before I can move left though.
Don't get me wrong, I'm not taking your comment personally and have thought about it as you have described it. However before the start of this video, on the original video, you see me look over my right shoulder (nothing immediately behind me) and stick my right arm out indicating I am moving to my right.
Fair enough. Not familiar with that chunk of road myself, and the (relatively) brief look afforded by the video made it look somewhat highway-esque and kind of uninviting from a cycling point of view. :)
LinzOC
Postby LinzOC » Sun Jul 07, 2013 5:21 pm
arkle wrote:
jasonc wrote:
arkle wrote:
This is true. The driver slammed on and hit the indicator simultaneously when he found the street he needed to turn down. He made a mistake in this regard. This is normal unpredictable behaviour that we have to expect and prepare for.
Summernight correctly hung back and gave herself enough space and time to brake to avoid a possible left hook and subsequent collision, and her strategy worked perfectly.
What the eff are we whining about?
arkle
exactly. as what is stated above makes the truck driver a moron motorist.
I challenge any motorist on this forum to claim that they have not braked suddenly to turn down a street they were unsure of the location of. It's not moron, it's normal human fallability. Everyone does it. You people talk like you are perfect superhero drivers.
arkle
Exactly. I've done it on the bike for goodness sake.
I'd also hazard a guess that the bike is in the truck's blind spot. Rear LHS? He'd be relying entirely on the mirrors there.
human909
Postby human909 » Sun Jul 07, 2013 7:07 pm
AKO wrote:Never made a mistake on the road?
I don't try to shrug off errors as "normal human fallibility". Doing so is what gets us into this lethargic state of affairs that normalises vehicular homicide.
As I said I don't drive and change directions without ensuring the way is clear. So this approach hasn't got me unstuck.
LinzOC
Postby LinzOC » Sun Jul 07, 2013 7:45 pm
Too simplistic I think.
Aircraft accident investigation considers errors and violations among other items when trying to determine a cause(s). An error is a mistake, often caused in turn by something else (fatigue, distraction, stress etc) where as a violation is a deliberate going against the regulations. An example of the former is forgetting to put the oil cap on your car because you are in a rush; an example of the latter is doing 140 kmph in a 60 zone. The former doesn't usually get punished (although retraining may occur), the latter almost always sees a separate investigation - often criminal.
Unfortunately a number of accidents are caused by errors. Your comments above indicate violations - of which there are plenty in this thread. In this particular case (of the left turning truck) I'd argue it was an error based on stress in trying to find a street. It's not normalising vehicular homicide; it's recognising that accidents are not simple one cause events (unless of course it is an attempt at vehicular homicide - in which case we are looking at a violation).
A_P
Postby A_P » Sun Jul 07, 2013 8:27 pm
Summernight would have been in prime position to be seen in the mirrors.
The mirror is clearly visible in the footage for about 17 seconds before the truck turned.
Anywhere forward of the rear wheels is blind spot in my mind
queequeg
Postby queequeg » Sun Jul 07, 2013 8:56 pm
How Timely:-
http://m.smh.com.au/travel/travel-incid ... 2pjm8.html
Looks like the plane landed short in perfect weather. Will be keeping an eye on this one as there have been some earlier incidents with icing in the fuel system during the landing approach, and from memory there was a 777 crash at Heathrow in 2008 which had some similarities. (http://en.m.wikipedia.org/wiki/British_ ... _Flight_38)
human909
Postby human909 » Sun Jul 07, 2013 9:00 pm
LinzOC wrote:Too simplistic I think.
I don't think your clarification is any less simplistic. Many 'errors' or minor mistakes are arise when the personal consequences are minor and the level of care and consideration is low. Being careless is just as much a violation. Going 140kph in a 60 zone is no more deliberate than not being careful. Your differentiation between criminal and non criminal is the big problem. Normalising accidents creates an environment that is less safe.
I wouldn't describe my self as a "careful" person who never makes mistakes. However put me in charge of a dangerous vehicle or put me on the side of a 100m cliff face and suddenly I'm a damn site more careful!
InTheWoods
Postby InTheWoods » Sun Jul 07, 2013 11:05 pm
queequeg wrote:How Timely:-
Going OT but can't help myself. Its not going to be ice in the fuel system - much warmer flight ... and ... the BA plane used Rolls Royce engines which are completely different to the Pratt&Whitney engines on the Asiana flight, including a completely different FOHE :) Its almost certainly going to be the pilots flying the plane into the ground - ILS at San Francisco was not operating.
queequeg
Postby queequeg » Sun Jul 07, 2013 11:19 pm
True (no time to check what engines it had fitted), but you have to seriously question a pilot who can crash a perfectly good plane into a runway in perfect weather (unless they are too reliant on "Autoland"). Moron Motorists, Moron Pilots :-)
K2
Postby K2 » Mon Jul 08, 2013 2:03 am
queequeg wrote:True (no time to check what engines it had fitted), but you have to seriously question a pilot who can crash a perfectly good plane into a runway in perfect weather (unless they are too reliant on "Autoland"). Moron Motorists, Moron Pilots :-)
Oh, I wish you hadn't gone there. It's going to be attempting to overtake a cyclist on the edge of the runway now, innit?
Summernight
Postby Summernight » Mon Jul 08, 2013 12:16 pm
K2 wrote:Oh, I wish you hadn't gone there. It's going to be attempting to overtake a cyclist on the edge of the runway now, innit?
I'm up for trying that as they don't go fast when turning and I've seen all the movies and TV shows where a car can drive right up to them, no problems. 8) I probably could fit underneath the thing anyway, as long as I wasn't sucked into the engines or run over by the wheels... Now, where are the plane's rear-vision mirrors... Oh wait... :P
For what it is worth in relation to my video, Greatapoc is on the money - I considered the truck driver worthy of an MM mention here because of the late indicating and turning without looking closely.
At this same intersection about 30 minutes later on the same day I was a pedestrian walking across this exact side street (I had put the bike away) and a van and tradie ute right-turned without giving way to the pedestrians crossing the side street and both did so at speed. They were MMs too. They probably need a refresher in the road rules regarding giving-way to pedestrians but just goes to show you cannot walk/ride/drive in a daze as idiots are everywhere.
(Good point on the left-hook terminology, Queequeg. And that would have been some sight seeing the Tarago being squished...)
Postby trailgumby » Mon Jul 08, 2013 2:06 pm
InTheWoods wrote:Going OT but can't help myself. Its not going to be ice in the fuel system - much warmer flight ... and ... the BA plane used Rolls Royce engines which are completely different to the Pratt&Whitney engines on the Asiana flight, including a completely different FOHE :) Its almost certainly going to be the pilots flying the plane into the ground - ILS at San Francisco was not operating.
At 12,000 metres, the temperature near the ground is not going to be all that relevant. If there was ice in the tanks, it's entirely possible it will not have thawed by final approach regardless of local ground level temps.
Not making any conclusions as to cause, just sayin'.
zero
Postby zero » Mon Jul 08, 2013 4:08 pm
Back to motorists.
Got right hooked today. I think that driver managed 6 or 7 traffic rule breaches in this video, depending on how a judge might interpret pass stopline at red. As per usual covering the brakes makes its seem undramatic.
http://www.youtube.com/watch?v=MFEmrv4nraU
Postby find_bruce » Mon Jul 08, 2013 4:17 pm
zero wrote:Back to motorists.
It appears you expected the driver might be a moron & weren't disappointed. I am unfamiliar with that intersection - was it a case of the driver being in the wrong lane & then rules & traffic be dammed I am getting to where I want to go ?
zero
Postby zero » Mon Jul 08, 2013 5:12 pm
He actually started in the right lane, cut off the driver in the left lane without indicating (see the hard stop).
Lukeyboy
Postby Lukeyboy » Mon Jul 08, 2013 10:56 pm
Temps can play a part but there have been steps in preventing that from happening. Apparently it looks like it might be pilot error stalling on approach into the airport :shock:
elantra
Postby elantra » Tue Jul 09, 2013 11:24 am
mick243 wrote:
Summernight wrote:Lunchtime today (doing a small errand). Decided to take the bike instead of walking to cut about 30 minutes off the round trip. Middle of Melbourne CBD. I think I prefer peak hour drivers...
(and yes, I got the O and 0 mixed up. Whoops. :P)
actually, being a heavy vehicle longer than a certain length (7.5M from rusty memory) he's not doing anything wrong, it would be nice if he indicated for longer. if he got into the left lane first, his back wheels would cut over the footpath (and people waiting to cross) on the corner.
If a long-ish vehicle is gunna do wide turn... he/she should Slow right down, Give a long indication, Check left mirror, and Wait for any vehicle in that lane to appear to slow, stop or Clear the intersection
oxonabike
Postby oxonabike » Tue Jul 09, 2013 11:52 am
So with the recent bad interactions between bicycles and trucks recently, had this scary moment on the commute this morning. The passing manoeuvre started off okay, but professional driver may have overlooked the length of his trailing load. Was bum clenching enough from the front view, so glad it was only the rear camera that watched this unfold.
Summernight
Postby Summernight » Tue Jul 09, 2013 11:57 am
oxonabike wrote:So with the recent bad interactions between bicycles and trucks recently, had this scary moment on the commute this morning. The passing manoeuvre started off okay, but professional driver may have overlooked the length of his trailing load. Was bum clenching enough from the front view, so glad it was only the rear camera that watched this unfold.
Whoops, driver forgot about that extra 10-15 metres or so of load. Bum-clenching indeed.
Those things are scary. Especially when you see those pictures of what wind can do to the second trailer (putting it off in the gravel on the side of the road while the front section is still in its lane.)
hannos
Postby hannos » Tue Jul 09, 2013 1:07 pm
I posted this a few months ago
As it happens, my complaint was summarrily ignored. So I submitted a complaint to the Customer Assistance Unit.
Tomorrow I go in to give a formal statement and it appears the driver (or registered owner) will be receiving a Neg Driving charge.
2010 BMC SLC01
zero
Postby zero » Tue Jul 09, 2013 1:18 pm
hannos wrote:I posted this a few months ago
Its not a 6km/hr over the speed limit summary offence that they can mail a fine out for.
JohnJoyner
Postby JohnJoyner » Tue Jul 09, 2013 1:19 pm
I would've needed a clean pair of knicks after that one....
jules21
Postby jules21 » Tue Jul 09, 2013 1:23 pm
it looks like the truck driver attempted to give you room, but then had to pull back into his lane early, squeezing you with his back trailer.
Gerry.M
Postby Gerry.M » Tue Jul 09, 2013 1:24 pm
Just out of curiosity, is the path to your left a shared bike path, and if so why wouldn't you use that instead?
Looks like the sort of road you can't claim the lane on safely and so your stuck in that dodgy little edge strip.
Users browsing this forum: christophers94, Scott_C
