Stages Power Meter
Stages Power Meter
Postby Krank » Sat Dec 29, 2012 7:07 am
http://www.stagescycling.com/stagespower-tech-specs
Your thoughts on this unit and it's limitations (if any) for measuring true power output?
Byte
Krank
by Forum Ads » Sat Dec 29, 2012 7:24 am
Re: Stages Power Meter
Postby winstonw » Sat Dec 29, 2012 7:24 am
cons
- less accurate with significant asymmetrical pedaling technique. nevertheless, I suppose it depends on what a cyclist wants to use power data for. If he wants to train to improve output, then asymmetry error won't be an issue. It's only when someone wants to compare their power output to someone else that it might be an issue.
- doesn't work on carbon cranks.
Fav Ride : Pottsville, Byron, Bangalow, Eureka, Dunoon, Nimbin, Uki, Mooball, Pottsville 200km 3000m
winstonw
Postby Krank » Sat Dec 29, 2012 7:28 am
interesting - thanks
how to the expensive high end units differ?
Krank
Krank
Postby Matt_Matt » Sat Dec 29, 2012 9:19 am
Thank you for your interest in the Stages Power meter. Unfortunately, we cannot ship to those outside of the US and Canada at this time. As a new company, and US based manufacturer, we've made the decision to only sell to North America until we're comfortable growing to support the demand and product outside of that area. We want to ensure we can support our customers in the highest quality manner and we cannot do this until we have our systems in place in other countries
Matt_Matt
Postby Krank » Sat Dec 29, 2012 9:33 am
i have a contact in usa - so no probs in mail..
krank
Krank
Postby Alex Simmons/RST » Sat Dec 29, 2012 10:30 am
winstonw wrote:- less accurate with significant asymmetrical pedaling technique. nevertheless, I suppose it depends on what a cyclist wants to use power data for. If he wants to train to improve output, then asymmetry error won't be an issue. It's only when someone wants to compare their power output to someone else that it might be an issue.
Comparing with others isn't the primary issue, although it helps if a power meter is accurate as usually people do change meters at some stage and inaccurate meters can make season on season tracking problematic.
Asymmetry in left side-right side power output is:
- normal
- variable from person to person (meaning that even if two people have the same total power output, this unit may not report them as the same)
- variable for the same person depending on cadence, absolute and relative power output, fatigue level, bike fit, type of riding, changes in fitness etc.
e.g. you can be 46:54 at one power level and 49:51 at another (and this would be completely normal). Which means the accuracy will vary somewhat as the unit assumes you are always 50:50 (which would be pretty unusual). In other words it might be accurate at one power level and much less so at another power level.
I'd say it has potential to be a good intro product into training with power, provided one recognises the limitations of the data and what it can be sensibly used for (and what it shouldn't be used for), similar to how other such products in the past, like the Polar chain based power meter, provided a cheaper entry to the power meter club.
Keep in mind that for a regular trained cyclist, threshold power will only vary by ~ 10% from under trained to peak fitness, and that often we are seeking to assess changes in power of only a percent or two when fitness is at personal best levels.
I can't comment on things like ability to validate calibration, durability, consistency, warranty, service and support etc
Alex Simmons/RST
Postby jules21 » Sat Dec 29, 2012 1:39 pm
ematchizit?
jules21
Postby winstonw » Sat Dec 29, 2012 2:15 pm
winstonw
Postby Xplora » Sat Dec 29, 2012 2:41 pm
No Campy options is pretty disappointing, but I can understand that it would be too hard if they are invading the crank volume to fit all the electronics onboard.
Xplora
Postby Krank » Sat Dec 29, 2012 2:46 pm
Xplora wrote:No Campy options is pretty disappointing, but I can understand that it would be too hard if they are invading the crank volume to fit all the electronics onboard.
agree!
Krank
Postby Xplora » Sat Dec 29, 2012 3:16 pm
It's due to the carbon. Hysterisis or something like that. Reason to go DA9000?
I really have to question the wisdom of putting a power meter on a 105 crank. If you are throwing around 1250 bucks at a power meter and Garmin, perhaps you have money to pony up for a new crankset as well? :|
Xplora
Postby dale79 » Sun Dec 30, 2012 4:28 pm
not much cheaper than the tried and proven powertap hubs..
dale79
Postby skull » Sun Dec 30, 2012 5:45 pm
you can get quarqs for less than $2k brand new from O/S
skull
Postby Alex Simmons/RST » Sun Dec 30, 2012 6:25 pm
skull wrote:you can get quarqs for less than $2k brand new from O/S
Don't need to go O/S to get them for less then $2k.
I sell complete Quarq SRAM crank sets from $1869, and much less for Specialized/Cannondale Quarq spiders.
Alex Simmons/RST
Postby skull » Sun Dec 30, 2012 6:28 pm
There you go, you can get them from a reputable Australian distributor for less than $2k.
I take it you are supplying Quarq power meters again.
skull
Postby Xplora » Mon Dec 31, 2012 7:20 am
In fairness to the Stages system, it's MUCH simpler than the powertap, and I am guessing the "elite" systems are much cheaper to implement because the expense is from the crank (which you are unlikely to swap) and you don't need to build the crank into a wheel etc which I am guessing is going to extend the cost enormously. The cheap powertap system is a similar price, but I'm thinking that it would be cheaper for the Stages system. Just seems a shame that you can either swap wheels, or swap bikes... most dudes sinking dollars have more than one bike lol
Xplora
Postby Alex Simmons/RST » Mon Dec 31, 2012 8:46 am
skull wrote:There you go, you can get them from a reputable Australian distributor for less than $2k.
Yes, Quarq were keen to ensure I could still supply their product here in Australia via SRAM's distribution network.
Alex Simmons/RST
Postby guyc » Wed Jan 30, 2013 7:53 am
guyc
Postby Xplora » Wed Jan 30, 2013 9:38 pm
ta!
Edit: both reviews basically back up what Alex Simmons said. Sounds like I will have to look at a power tap.
Xplora
Users browsing this forum: justanewbie
