Stages Power Meter
- g-boaf
Re: Stages Power Meter
Postby g-boaf » Mon Sep 01, 2014 3:07 pm
Postby march83 » Mon Sep 01, 2014 3:14 pm
Postby Crawf » Mon Sep 01, 2014 3:16 pm
However for those already using BSA/Shimano, you need to fork out for a brand new crank & chainrings, rendering your old Shimano crankset useless if i'm not mistaken?
So it's not just a $800 purchase, its a $800 + crankset purchase.
Postby boss » Mon Sep 01, 2014 3:33 pm
Correct, if you do not have compatible cranks then you'll need a new crankset and rings. Same deal with Quarq, SRM, etc. Except, say with Quarq, you are looking at AU$2k for local stock with a SRAM chainset (no rings).Crawf wrote:Power2max looks like it could be the next choose if things don't go well with Stages/FE.
I ended up paying around $1350 for a P2M classic ($799) with Rotor 3D cranks ($350) and Praxis rings ($200). The standard 3d (not 3d+) slot straight into a Shimano BB.
You could get a foot in the door cheaper with some FSA Gossamer cranks (or BYO second hand cranks) and BYO rings. Sell your Shimano chainset and probably end up somewhere vaguely close to break even.
And as I said if you already have a chainset you are looking at a ripper of a deal at $799 for a spider.
- Xplora
Postby Xplora » Mon Sep 01, 2014 4:58 pm
- Carrots
- Ross
Postby Ross » Mon Sep 01, 2014 8:13 pm
My Garmin 510 is playing up as well, very hard to upload rids to my PC.
I guess the next thing to stuff up on the bike will be the Di2.
Bloody electronics.
Postby boss » Mon Sep 01, 2014 8:39 pm
I haven't heard much good about old mate Quarq. Seems very hit and miss.Ross wrote:If it makes you feel better Boss, my Quarq has just died, for the second time. I've had one replaced under warranty already, not sure if the warranty Quarq has warranty.
Bloody electronics.
Postby Jesmol » Mon Sep 01, 2014 9:14 pm
I'm on my second, first being replaced under warranty.
- Alex Simmons/RST
Postby Alex Simmons/RST » Mon Sep 01, 2014 10:41 pm
some models now have battery rated to 5 years.Xplora wrote:SRM has both the best and the WORST battery solution. We give you ten times the life of any competitor, very little chance of it dying unexpectedly, but you have to send the crank OS to get a battery changed
other limited models now have user replaceable battery.
- Xplora
Postby Xplora » Mon Sep 01, 2014 11:31 pm
Postby boss » Tue Sep 02, 2014 9:46 am
I figure you could time it right with some base training or other non-critical work and sub in another PM. Even a second-hand Stages would be ok enough to live with for a month, 105's are going for $400-600 and enough batteries to see you through a month would be like $50 if you pay supermarket rates. Haha!
- Xplora
Postby Xplora » Tue Sep 02, 2014 10:09 am
Touch wood, but it's quite illuminating how much charge is required for a PM, because I'm still on the same battery 6 months later for my HR strap and the cadence sensor 12 months later.
- g-boaf
Postby g-boaf » Tue Sep 02, 2014 10:49 am
5 years is more than long enough. Especially given how owners of some types of power meters seem to have a shop-sized supply of CR2032 batteries for their devices.Alex Simmons/RST wrote:some models now have battery rated to 5 years.Xplora wrote:SRM has both the best and the WORST battery solution. We give you ten times the life of any competitor, very little chance of it dying unexpectedly, but you have to send the crank OS to get a battery changed
- scotto
Postby scotto » Tue Sep 02, 2014 11:48 am
- g-boaf
Postby g-boaf » Tue Sep 02, 2014 11:59 am
You mean like a Seiko Kinetic Direct Drive (ie, the watch I'm wearing now)? Hmm - that'd be a brilliant idea. It would add some weight, but it'd be good. As long as the mechanism can stand up to sudden acceleration.scotto wrote:what about a watch style battery setup thats charged by movement. self charging.....
- scotto
Postby scotto » Tue Sep 02, 2014 12:05 pm
Postby earlybird » Tue Sep 02, 2014 1:37 pm
- AKO
Postby AKO » Tue Sep 02, 2014 7:20 pm
Excuse my ignorance but how do set the Garmin to automatically display the calibrate menu? I like the sound of that.earlybird wrote:Battery replaced 1/9 - I'll see how many hours it lasts for. I have found though that when the bike is in the car, the movement triggers the stages and my garmin displays the calibrate menu.
Malvern Star XCS 5.0 MTB (2012)
Malvern Star Path Racer 1 (2015)
ProLite Cuneo
- Xplora
Postby Xplora » Tue Sep 02, 2014 9:29 pm
YES. THIS. PLEASE TELL.AKO wrote:Excuse my ignorance but how do set the Garmin to automatically display the calibrate menu? I like the sound of that.earlybird wrote:Battery replaced 1/9 - I'll see how many hours it lasts for. I have found though that when the bike is in the car, the movement triggers the stages and my garmin displays the calibrate menu.
- jules21
Postby jules21 » Tue Sep 02, 2014 10:09 pm
Postby earlybird » Tue Sep 02, 2014 10:33 pm
I can't find a setting for it, it just does it. It has done since the lbs set it up (about 4-5 months ago). I did a full factory reset on the garmin 2 weeks ago and never did anything other than turn on the ant+ power setting and ran the detection. I've looked through the menu and can't find anything relevant. I've got an Edge500 with firmware 3.30.AKO wrote:Excuse my ignorance but how do set the Garmin to automatically display the calibrate menu? I like the sound of that.earlybird wrote:Battery replaced 1/9 - I'll see how many hours it lasts for. I have found though that when the bike is in the car, the movement triggers the stages and my garmin displays the calibrate menu.
Did a test today and sure enough, with bike strapped inside the car, the power meter woke up after about a kilometre. That's an extra couple of hours a week of wasted battery drain.
Sent from my iPad using Tapatalk
Postby jasonc » Wed Sep 03, 2014 7:55 am
can you buy me a pair too?jules21 wrote:i just bought a pair of Vectors! that's all i have to say about that
Postby dale79 » Wed Sep 03, 2014 9:06 am
yes i noticed this on a trip to qld.. got up there and meter worked. got home and battery flat.. 24 hours of drivig and probably on the whole wayearlybird wrote:I can't find a setting for it, it just does it. It has done since the lbs set it up (about 4-5 months ago). I did a full factory reset on the garmin 2 weeks ago and never did anything other than turn on the ant+ power setting and ran the detection. I've looked through the menu and can't find anything relevant. I've got an Edge500 with firmware 3.30.AKO wrote:Excuse my ignorance but how do set the Garmin to automatically display the calibrate menu? I like the sound of that.earlybird wrote:Battery replaced 1/9 - I'll see how many hours it lasts for. I have found though that when the bike is in the car, the movement triggers the stages and my garmin displays the calibrate menu.
- AKO
Postby AKO » Wed Sep 03, 2014 9:21 am
No worries. Mine is a 510 and I've never updated the firmware. Might give it a go.earlybird wrote:I can't find a setting for it, it just does it. It has done since the lbs set it up (about 4-5 months ago). I did a full factory reset on the garmin 2 weeks ago and never did anything other than turn on the ant+ power setting and ran the detection. I've looked through the menu and can't find anything relevant. I've got an Edge500 with firmware 3.30.AKO wrote:Excuse my ignorance but how do set the Garmin to automatically display the calibrate menu? I like the sound of that.earlybird wrote:Battery replaced 1/9 - I'll see how many hours it lasts for. I have found though that when the bike is in the car, the movement triggers the stages and my garmin displays the calibrate menu.
ProLite Cuneo
Users browsing this forum: am50em
