Page 3 of 10
Re: 2013 Black Cats Award
Posted: Sat Feb 16, 2013 4:41 pm
by birdbrain
Wow that is some black cat
Puts my 2 little ones to shame
Posted: Sun Feb 17, 2013 4:20 pm
by twizzle
Ozkaban wrote:cerb wrote:A guy down at crits last Sunday got a bit of a puncture...
Punctured the tyre AND the rim!
Far out! That's an expensive puncture! I don't imagine you could repair that sort of thing...
Nah, just a scratch, that will buff out.
(Where I do my Crits, we walk the track before the race to remove sharp objects).
Sent from my iThingy...
Posted: Sun Feb 17, 2013 5:57 pm
by jcjordan
Well 5 for me now.
Ran over a bit of green bottle and kill a tire
Posted: Sun Feb 17, 2013 7:15 pm
by wombatK
First flat of the year - small shard of glass picked up on cycleway near Kyeemagh.
So it's 1 for me.
Flat was on the rear. A Maxxis Detonator that's had two flats in 3000 km - ie. about 1500 km per flat. That's half the mileage that Conti GP 4000s give me between punctures, but I'm too tight to toss away the Maxxis tyres that came on the Cell Triumph yet. Treadwise
they look to have plenty of wear left.
Posted: Sat Feb 23, 2013 8:53 am
by Dan
Previous Total: 0
Today: 1 - Black Panther (much bigger than your average cat) - bogan droppings (VB tallie) chucked from the Hornibrook Highway onto the cycleway, sliced straight through a 500km old Rubino Pro. Dead to say the least. Luckily only 800m from the start. Thanks also to Hamster & co for stopping and checking on us!
RUNNING TOTAL: 1
Posted: Sun Feb 24, 2013 3:57 pm
by vander
Been back on the bike 2 weeks and I have had 4 flat tyres in about 7 or 8 rides. Just wanted to complain about it somewhere. Cant find anything wrong, the rim tape looks OK dont really know what it is.
Posted: Sun Feb 24, 2013 5:49 pm
by Lukeyboy
Dan wrote:Previous Total: 0
RUNNING TOTAL: 1
Get it to run smooth and you got yourself a new tire for the trainer. Well, that's where all my cut wheels end up going
Posted: Sun Feb 24, 2013 10:32 pm
by Dan
No trainer here! It'll serve as a patch donor.
Posted: Wed Feb 27, 2013 7:56 am
by jcjordan
Well that's 6. At least the bit of aka ssh that got me was only 20 meters from the coffee shop.
God I hate the wet
Posted: Wed Feb 27, 2013 9:15 pm
by twizzle
+1, 4. A new Evo3 on the front on Sunday night, five minutes after leaving home this morning the sealant in the front tube came out as a spray of vapor. It sort of sealed, so I pushed on till It finally lost the air about 3km later. Only a tiny cut, but it didn't seal. But I think this wasn't the road racer sealant but the thinner stuff for MTB. It still sucks.
Posted: Sat Mar 02, 2013 3:18 pm
by jasonc
first entry for a long time. first (And hopefully only) for 2013
+1
total : 1
rear tyre. went down straight away. wet roads with some drizzle. went past again about half hour later and saw some nice bits of metal around so I'd say it was 1 of them.
tyre: gatorskin 23c
kms on tyre: ~1500.
total punctures on tyre: 2.
EDIT: 2 cyclists went past and they didn't say a word. I ALWAYS offer assistance.
Posted: Mon Mar 04, 2013 9:52 am
by twizzle
+1,5. A ~4cm nail through the rear tyre, smacked the life out of the front derailleur clamp but luckily avoided the paintwork. What a way to ruin a perfectly good ride.
On the positive side... It puts me on track to lead the competition yet again if I can keep up this rate all year.
Posted: Thu Mar 07, 2013 10:52 pm
by HiChris
Number 2 for the year, one week old rear tyre meets green glass. What is it with green glass?
Posted: Sat Mar 09, 2013 2:03 pm
by g-boaf
3 punctures in a space of 5 minutes!
Cut right through the tyre too. Bad.
Glass bottles should be banned! Went and had a look, looked like left overs of a bottle of Vodka.
Tried the trick with the $5 note, that didn't work at all.
I was have a really enjoyable ride too. Making good power, reasonable speed for the first time in ages.
Running total +5.
Hey Twizzle, you've got competition this time.
Posted: Sat Mar 09, 2013 11:30 pm
by Dan
You now have a tyre donor for real sections of sidewall to replace the $5 note
Posted: Sat Mar 09, 2013 11:38 pm
by g-boaf
Dan wrote:You now have a tyre donor for real sections of sidewall to replace the $5 note
True.
vander wrote:Been back on the bike 2 weeks and I have had 4 flat tyres in about 7 or 8 rides. Just wanted to complain about it somewhere. Cant find anything wrong, the rim tape looks OK dont really know what it is.
What wheels have you got? Checked the edges of the rim for any sharp edges? That was the issue when I had that problem with the wheels I have.
Posted: Sun Mar 10, 2013 10:45 am
by RonK
Stick with the $5 note - at least it is multi-pupose.
Posted: Mon Mar 11, 2013 3:32 pm
by Big_Red
Out for a little 25km Wynnum loop nite ride on saturday 9 March with a mate to give his new roadbike a test, but make a wrong turn and hoon over a set of railway tracks way too fast and not only get a pinch flat (23mm tyres (AT) 100psi
) but also pop the rear light out of its holder and lose a battery, and the water bottle flies out of the holder as well. Pull tube off wheel and there are twin 20mm long punctures at the bottom of the valve. Binned when i got home. Also must have been bitten 26,575 times by mosquitos as the area where i had to change tube was swampy and the recent rain has led to a mozzie explosion.
Then commuting to work today, i've got a flat from who knows what, no more than 1 km from starting off. Tiny split at bottom of valve, cannot find any thing in tyre to explain it, might be because tyre not seated properly after saturday's misshap. Unlucky. +2
Total = 3
Posted: Mon Mar 11, 2013 3:45 pm
by Dan
RonK wrote:Dan wrote:You now have a tyre donor for real sections of sidewall to replace the $5 note
You're right - can't swap a bit of rubber for coffee, but then again after seeing whatever article in whatever tabloid about exorbitant coffee prices at some restaurants/bistros/whatevers, it seems you can't often swap $5 for one, either
Posted: Mon Mar 11, 2013 4:01 pm
by twizzle
*sigh*
+1, 6. Beer bottle glass in the rear tyre creating a slowish-leak. ONCE AGAIN, I discovered it while cornering. The fairy is an evil cow.
Posted: Mon Mar 11, 2013 4:14 pm
by jasonc
Big_Red wrote:Then commuting to work today, i've got a flat from who knows what, no more than 1 km from starting off. Tiny split at bottom of valve, cannot find any thing in tyre to explain it, might be because tyre not seated properly after saturday's misshap.
had this happen to me. I reckon cause was my pump. The clamp on pumps pull on the tubes (hence I have a lezyne screw on pump). This over time can cause increased rubbing/splitting. could have just been a dodgy tube too....
Posted: Mon Mar 11, 2013 9:17 pm
by g-boaf
Dan wrote:RonK wrote:Dan wrote:You now have a tyre donor for real sections of sidewall to replace the $5 note
I have my own coffee machine.
twizzle wrote:*sigh*
Bugger! You must have done something pretty bad to upset the great gods of tyre punctures.
Posted: Tue Mar 12, 2013 6:11 pm
by twizzle
What the?!?!! Damn it Fairy.
YOU. ARE. A. BITCH.
I was minding my own business. How DARE you stick some small random piece of trash on the road for me to pinch flat on.
On top of that - less than 1Km from my house, making the only viable option to CARRY MY BIKE seeing as the tyre was trashed and needed replacing, and the new tyre was at home.
Posted: Sun Mar 24, 2013 2:48 pm
by twizzle
+1, 8. Something cut through the rear tyre (new tyre yesterday!), only just nicked the tube so it only went down slowly so I didn't bother to stop until we got to breakfast - although, it did bottom out a few times in the last few hundred metres. Then when inflating from CO2, the flipping valve unscrewed itself (second time with the Vittoria tubes), dumped all the CO2 and scared the heck out of the people near us at the cafe.
Posted: Sun Mar 24, 2013 4:01 pm
by jasonc
+1.
new total: 2
GP4000s rear tyre
coot-tha challenge day. chunky piece of glass.
