Old is new...
• Page 1 of 1
Old is new...Gasp! Just when the disc brakes zealots have been preaching to us that discs will be the next braking advance on pro team bikes, Ridley changes to...linear-pull brakes.
![]() ![]() ![]() Cycle touring blog and tour journals: whispering wheels...
Re: Old is new......whatever the road rules, self-preservation is the absolute priority for a cyclist when mixing it with motorised traffic.
Re: Old is new...
Fair guess - it's no surprise that the pro teams are more interested in going faster than stopping. Cycle touring blog and tour journals: whispering wheels...
Re: Old is new...There are very good technical reasons not to have road disk brakes. Listen to this velocast spinoff for such a discussion (link to mp3). It's quite eye opening.
Re: Old is new..."My bicycle masters boardwalk and quagmire with aplomb. Those that doubt me... suck THUMB by choice."
Re: Old is new...Looking at the road bike ride I posted here it's pretty obvious discs for road bikes are mostly overkill. Most notably the first thing to give out is not your brake power but rather the tyre traction. Disc brakes do nothing to help this.
Re: Old is new...
Hmmm... was broken, for me at least. Interesting podcast. I think I shall subscribe. "My bicycle masters boardwalk and quagmire with aplomb. Those that doubt me... suck THUMB by choice."
Re: Old is new...
No doubt these guys will be crucified for their heresy. But their comments are pretty much the same as I've made elsewhere on this forum. The most telling comments: "a new product to empty your wallet" and "a solution to a problem that doesn't exist". Cycle touring blog and tour journals: whispering wheels...
Re: Old is new...Braking tracks on your rim wear out and if I could buy a set of Zipps that would last for 10 years after replacing the rotors a few times, I would gladly pony up the dollars for Zipps or Enves. Carbon doesn't age or wear out from bumps but nothing can prevent abrasive wear from braking.
That said, I'll be waiting a long time for Zipp to put discs on a 404. A LONG time.
Re: Old is new...As someone who has crashed into the side of a car in the wet because my brakes didn't work, I hardly think there isn't a problem rim brakes in the wet.* Initial bite is important with emergency braking. You need to be able to decelerate instantly in an emergency, not wait for the front rim to dry first. Having said that, it really depends on your setup and circumstances. My current wet bike (when the roads are wet as I don't generally ride when poring rain) is good with V brakes and 50mm tyres. The wide tyres shield the rims to some extent from getting too wet. I started with front disc on a road/CX bike because I had trouble getting enough leverage from the hoods to get the back wheel of the ground under braking with caliper brakes. I tried better pads but it still didn't work well for me. After using disc for a couple of years, I then decided to go back to rim brake on the front with the spare wheels and CX fork I had. This was the result, so I went back to disc. As is the same with many things, if you don't like discs, no-one is making you buy them. Rim brakes aren't going to go extinct just because some people prefer discs on the road. *Under certain circumstances
Re: Old is new...There are very good technical reasons for pro-tour riders not to have road disk brakes. For the rest of us who are not worried about aero and who don't ride on closed roads, they do have advantages. The velocast blokes did concede that they were good on "city bikes" and that is about what many of us use our road bikes for. I regularly do a 15km run to the CBD on shared paths and my time on a MTB with knobblies and discs is about 2-3 min slower than on either my 2012 CF roadie with dual pivot brakes or my 1991 steelie with dual pivot brakes (they both feel the same). The difference is that when I approach a blind 90 deg turn into an underpass I have to start braking about 5 meters earlier on the roadies, with less confidence in the result. I would estimate that on a roadie with discs, I would be about 10min faster than on my MTB. And no, I am not in a hurry but we all benefit with high intensity training rides - I always say that I am training for something more important than the Olympics - the next 20yrs of my life.
Re: Old is new...
Go back and read the OP properly - you will see that the subject is brakes on pro team bikes. But anyone planning to ride a CX bike on the road would be wise to remember that these bikes and their brakes are designed for low speeds. Oh, and if you cannot stop in the wet and have a collision, perhaps you should question your own judgement. Cycle touring blog and tour journals: whispering wheels...
Re: Old is new...Any other judgements?
Re: Old is new...
Go back and read his post properly-Emergency Braking. You know, the Jeebers moment when every microsecond and centimetre counts. Maybe if Nobody and myself were mind readers we'd be able to foresee the event in time to scrub the rims dry. ...whatever the road rules, self-preservation is the absolute priority for a cyclist when mixing it with motorised traffic.
Re: Old is new...
Emergency braking: When it's wet SLOW DOWN. Exercise some judgement and ride at pace where you can stop safely in an emergency. Cycle touring blog and tour journals: whispering wheels...
Re: Old is new...I'm thinking of a front disc on my Azzurri commuter similar to what you are running Nobody. My reason is that the rim brakes are wearing the bejeezus out of my front rim. The wet rim picks up grit that ends up becoming embedded in the pads. The noise coming from the rim on one of my kangaroo populated steep descents during my commute sounds terrible. The rim is getting chewed up fast.
Are discs a bit more durable or cheaper to replace if not?
Re: Old is new...That's one reason (other than unpredictable braking) why I swapped to disc first on the MTB. Got tired of wearing away my front rim in the wet. Discs are about $30. A steel one should last a long time. A new Avid one is ~1.82mm by my digital vernier calipers. Mine is down to ~1.74mm now with about a guestimate of 2/3 to 3/4 of the pads used. Although I haven't found a minimum spec, I'd probably replace at about 1.5mm for safety which may be after two sets of pads. That might end up being a total of 7 years or more for me. However the main reasons to change for me would be the extra wet weather safety and not having to listen to my rims grinding away.
Re: Old is new...
Nice info thanks mate
Re: Old is new...I dont know if anyone here has noticed, but all accidents/ collisions occur when you dont stop in time. Sometimes it just doesnt matter how much you prepare or expect something or ride slowly. Accidents, by their very nature, happen. Riding slowly in the wet is no guarantee of safety.
As for discs, I bought a CX bike for commuting and using cable discs on the road in drenching rain is just about as good as good rim brakes in the dry. For those thinking that the brakes aren't designed for speed of a road bike, consider this: CX races are commonly held in the wet with mud and moisture regularly getting on the braking surface. Add into that the fact that CX races are typically held on courses with big terrain differences and considering that they are 'races', I think general commuting and road riding will be well within the brakes abilities. My experience, having ridden the bike on bunch rides and using it for three months for 35km per day commutes with 800m relief, is that the brakes are more than capable of handling the speed of road riding. As for the other brakes from the original post, its kind of scary to think that pros are being expected to ride something with poorer braking ability than what is possible from widely accepted industry standard brakes. The aero advantage must be immense!!! Merida Reacto 907 TWE wheels, Merida HFS 1000D, Merida Cyclocross CX4 Disc, Custom HongFu 29, Norco Diamond, Chariot CX1+CX2
Re: Old is new...I think it's more like they can win or lose races by the tiniest of margins. They also live in a different world to us as they can go fast enough that aero makes a significant difference and cars don't suddenly pull out on them in a race.
Re: Old is new...Yep, I think you'll find the professionals have very different expectations of their bikes in the open road without support vehicles.
Don't forget, they have race bikes and training bikes as well, so they can spec them very differently to suit those conditions. Even nonpros do this (2LLegs, that's YOU)
• Page 1 of 1
Who is onlineUsers browsing this forum: BentleyO, find_bruce, Kraeg, Matthews, michaelten, Steve_F, Tbird, vosadrian |
