Pumping up tyre of pram / toddler bicycle
Postby robbiepapenfus » Thu Jan 31, 2013 11:54 am
Hi guys,
Silly question..
I bought myself a Bontrager foot pump, which works great for my bicycle BUT its virtually impossible to pump up a pram or toddler bicycle wheel and there is not enough space (between the spokes and rim)to insert the tyre valve AND lock it.
Do I need to buy another pump for the pram / toddler bicycle or can I get some sort of extension?
Any ideas?
Robbie
robbiepapenfus
by Forum Ads » Thu Jan 31, 2013 11:56 am
Re: Pumping up tyre of pram / toddler bicycle
Postby MattyK » Thu Jan 31, 2013 11:56 am
Do you need to lock it? I usually just hold the head on the valve stem with one hand and pump with the other. You're only putting in about 20 psi.
MattyK
Postby jaseyjase » Thu Jan 31, 2013 1:26 pm
cheapest screw on hand pump should do it!
jaseyjase
Postby RonK » Thu Jan 31, 2013 1:48 pm
Use your Lezyne pump. What, you haven't got a Lezyne? :lol: :lol: :lol:
Postby gorilla monsoon » Thu Jan 31, 2013 4:50 pm
Go for taller, narrower wheels with 19mm tyres and a lower spoke count. Better aero and lower rolling resistance. Don't forget to go 110-120psi in the tyres. :D
Some days you are a big, strutting rooster, some days you are a bit chicken and some days you are just a complete cocque. Roger Ramjet: 2009 Giant CRX3 Spockette: 2009 Trek FX 7.3 (WSD, property of Mrs Monsoon) Lady Penelope: 2011 Avanti Cadent 1.0 TdF
gorilla monsoon
Postby Ozkaban » Thu Jan 31, 2013 7:14 pm
gorilla monsoon wrote:Go for taller, narrower wheels with 19mm tyres and a lower spoke count. Better aero and lower rolling resistance. Don't forget to go 110-120psi in the tyres. :D
Maybe a carbon 4 spoke wheel would be a better option if valve head clearance in an issue...
Ozkaban
Postby roobab » Thu Jan 31, 2013 7:43 pm
LEZYNE
roobab
Postby rkelsen » Thu Jan 31, 2013 7:54 pm
RonK wrote:Use your Lezyne pump.
This.
roobab wrote:LEZYNE
This.
Buy one and wonder why you didn't do it earlier. I like it so much, I'm going to buy the company.
volutamus scandemus
rkelsen
Postby queequeg » Thu Jan 31, 2013 9:07 pm
on the pram, replace the tubes with ones that have angled valve stems.
on the kids bike I use a lezyne pump as it is the only one that can get into the tiny space. I might try the same angled valve stem on the kids bike as it makes it much easier!
'11 Lynskey Cooper CX, '00 Hillbrick Steel Racing (Total Rebuild '10), '09 Electra Townie Original 21D
queequeg
Postby bigfriendlyvegan » Thu Jan 31, 2013 9:12 pm
$2 hand pump from the $2 shop. The old style where the tartan printed tube goes into the handle. I've had the same problem with (a) a balance bike, (b) a bmx wheel with a disc on it (yes, 'twas totally aero) and (c) a bmx wheel with about a thousand spokes in it.
bigfriendlyvegan
Postby robbiepapenfus » Fri Feb 01, 2013 11:47 am
Thanks for the advice guys :)
robbiepapenfus
Users browsing this forum: GSXR1
