Indoor trainer just for bad weather?
• Page 3 of 5 • 1, 2, 3, 4, 5
Re: Indoor trainer just for bad weather?
Good luck with it all. Doing lots of dedicated training indoors takes a fair bit of personal drive. Just one comment - you can't do effective sprint work on any trainer such a KK or any unit that has a roller-tyre interface. They simply can't provide the resistance/inertia load necessary, and tyre slip will be significant. And it may not be safe either, let alone consider the bike behaves differently under maximal load when on a trainer than when unconstrained. You can do hard work up to/including lactate tolerance, but forget about neuromuscular power development, that needs to be done on the road or track. It was possible on my special ergo bike to get enough resistance for genuine acceleration efforts, but keep in mind it had a 30kg flywheel with double reduction gearing is a far cry from any regular trainer.
Re: Indoor trainer just for bad weather?This is all fascinating stuff but highly confusing to know how much to spend before you get something worth having for my needs.
The Jet black fluid seems a decent entry level option for not a huge price but is it worth spending more to get better...how long is a piece of string I guess! Never underestimate the power of ignorance
Re: Indoor trainer just for bad weather?To be honest, the cheapest I would advise based on reviews and forums is the Cycleops Fluid 2. Some like it better than the more expensive Kurt Kinetic, though the KK gets more wins when it comes to head to head reviews. It's $268 delivered from Wiggle if you use the promo code 20-OFF at checkout. I got the Kurt Kinetic for $333 delivered from Probikekit. I had to change the currency to UKP, then put in the promo code 25UP.
For me the extra $65 seemed quite easy to justify, but in your situation it would be a tougher choice to spend the extra, the Fluid 2 is by all accounts a high quality trainer.
Had my first go on the Z1 last night, as I wanted to muck around with the tension and check my cadence and heart rate. In other words, lots of fiddling about, which was safer to do indoors than on the river loop at 5am in the dark! Following the instructions to give it 1.5-2 turns of resistance once the wheel touches the roller seemed pretty solid. It's obvious straight away that it's much harder that riding a bike on the flat. It feels almost like riding up a 1-2% gradient constantly. I was mid-cluster on the small chainring and doing 90rpm and 25kmh roughly. Started to sweat pretty quickly while I was madly pressing buttons on my (new to me) Garmin and customising screens, so decided to stick with it for a bit. Did 20 minutes and created a decent sized puddle of sweat on the floor! I reckon if you could do a solid hour on these things, it'd be worth at least double that on the road. I'll need to keep some towels and a mop and bucket handy if I do longer stints on this thing! I can't comment on the more expensive units, but I'm impressed so far with the Jet Black Z1. It's fairly quiet, feels solid and gives a heck of a workout. Litespeed Tuscany with SRAM Force and Open Pros - soon!
High power fans are an essential item to include in the budget when looking at an indoor trainer set up. So even if the trainer is fairly quiet, it'll be drowned out by the noise of the industrial sized cooling fan needed to make a training session effective. Put it this way, if you typically ride at 25-30km/h outside, you have a breeze of that strength flowing over your entire body keeping your cool and wicking the sweat off your skin. Once core temp begins to rise, even a little, performance degrades significantly.
Re: Indoor trainer just for bad weather?Check out my practical cycling and cycle touring website: VELOPHILE AUSTRALIA
One can HU all they like, but if cooling is inadequate, training will be compromised and be less effective.
Re: Indoor trainer just for bad weather?Just chatting with jack1071 and he confirmed you could get a pretty accurate estimate of your power based on the Kurt speed graph. If you are working towards a specific band Z4 for 20 minutes, you could reasonably guess the power output based on the speedo - this will only work if you've got a speedo, a trainer that is consistent and a formula that it can apply to.
Won't beat an SRM, but it will be better than nothing or HRM. I'm going to pony up for the Road Machine asap once Minister of Finance has approved the purchase authorisation
Re: Indoor trainer just for bad weather?I've started writing my project to display current speed/cadence/watts/time on my laptop while on the trainer. It may not be that special at first, but I'll be able to customize it as I get ideas about what might help with training.
Where power is poorly estimated using those formulas is shifts in speed, ie accelerating/decelerating. As an example, I could stop pedalling and the next second still might be doing 30km/h, therefore generating 250W without pedalling. I'd like to make that more accurate, but it won't make a huge difference for what I'll be doing the first few weeks, so I'll likely start light and build the app up as needed.
Would that KK be this one? http://www.cycling-inform.com/store/pro ... ainer.html Never underestimate the power of ignorance
Re: Indoor trainer just for bad weather?Wrong link!
http://www.cycling-inform.com/store/pro ... ainer.html Looks like its between the Z1 or the Road machine in the kind of price range I'm considering but quite a difference in price Never underestimate the power of ignorance
Re: Indoor trainer just for bad weather?I'm talking about the Road Machine, here is a link with their current trainers:
http://www.kurtkinetic.com/trainers-c-7-l-en.html Got mine last night, set it up with wifes bike first, seemed rock solid without giving it a good test yet.
For $333 delivered? That seems like a great price from what I've seen elsewhere Never underestimate the power of ignorance
Re: Indoor trainer just for bad weather?333 is probably the cycleops.
www.frugalrouleur.com should confirm. Prolite Oz has the Kurt Road machine delivered 419 dollars with Oz warranty - it's so heavy that I'm not sure you'd want to be fighting over warranty returns to the UK
Good point about warranty... Anyone know what the CycleOps Fluid 2 trainer is like? http://www.cyclingexpress.com/cycle/cyc ... 95000.aspx Never underestimate the power of ignorance
Re: Indoor trainer just for bad weather?$333 was ProBikeKit after taking off 25 pound discount using their discount code last week. $0 shipping too.
The Cycleops Fluid 2 is supposed to be an excellent unit also, a little less resistance than the Road Machine from all accounts. There is also a Fluid Pro which has the bigger flywheel for more resistance
Cycling Express have the CycleOps Fluid 2 Pro for $350 but another 12.5% off (this weekend only I think) makes it $306...seems like a good option Never underestimate the power of ignorance
Re: Indoor trainer just for bad weather?Depends what your goals are - the Road Machine is recommended by the dudes from http://www.trainerroad.com as the best one out there for consistency at the price point - it's not a Wahoo Kickr or Computrainer etc which cost twice as much. If your goal is to improve via power workouts at a certain price point, then the Road Machine is going to be a lot better than the competition. You COULD use the Jetblack Z1 or Cycleops etc etc which are a bit cheaper, but you might be able to avoid an upgrade to a power meter for a while because of the superior aspects of the Road Machine.
If your goal is to spin your legs when its raining, you're probably spending too much with any of these ones. You just have to ask yourself, do I want to spend 100, 300, 500, 1000 or 2000 bucks? It doesn't matter how much you spend if you don't need it. Road Machine seems to match my budget and goals.
Re: Indoor trainer just for bad weather?I have just got the JetBlack Fluid Dyno.
Some info here for those interested. http://cycling.norbtech.com/2013/03/set ... e-trainer/
Re: Indoor trainer just for bad weather?That review sealed the deal for me - I don't think it would be ideal for what I'm after. The dynometer is HUGE. It's from the same school of thought as wannabe drag racers with their "I've spent too much time in the bathroom and now I'm blind" dials
This confuses me more than ever! So if I'm just wanting to do a few k's when the weather is wet what should I be spending? Never underestimate the power of ignorance
Re: Indoor trainer just for bad weather?I've had a Kurt Kinetic Road Machine for a couple of years now and it hasn't let me down. Might be a bit more expensive than some others, but IMHO well worth the dinero.
Probably 300 on the Jetblack Z1 fluid trainer? www.cellbikes.com.au for the click through. I'd be getting that one except I don't see the point in saving 100 bucks on a tool that I hope will be useful for my wife as well, as well as me getting towards ULTIMATE BREWTUL POWER I've been looking at power meter books, software, etc etc. methinks my expectations are higher than yours... that was my point. If you don't need the world, don't overspend.
