Cadence Sensor Installation Gone Wrong...
Panz05
Postby Panz05 » Sat May 04, 2013 1:31 pm
Hi,
I have recently purchased a new bike and have put my 810 and the cadence sensor on my new bike. I have installed it and am getting readings, but I went for a ride this morning and was averaging 11rpm whilst doing an average of 20km per hour. On my previous bike, I would average 20km per hour with an average of 65rpm for my cadence.
I suspect that the sensor has moved whilst I have been riding, but I am now questioning the way I have set it up on the bike. I am hoping you could take a look at my setup and tell me if this is ok or offer any suggestions on how to place the sensor.
The frame is different to my previous frame so I couldn't place the sensor in the same position as there was not enough clearance for the speed magnet on the spokes. If I reversed it, I could get the right clearence and both speed and cadence appeared to be working.
As a result, I had to place the speed magnet on the spoke close to the rim. The speed does seem to be accurate as I do average about 20km per hour, but because cycling is very new to me, I am not sure if this is the right position.
Any advice would be greatly appreciated.
Lapierre FDJ Di2
Baalzamon
Re: Cadence Sensor Installation Gone Wrong...
Postby Baalzamon » Sat May 04, 2013 1:38 pm
Turn the cadence sensor around, you have it mounted wrong.
It is reading your wheel revolution as cadence. The arm reads the information from the wheel, the body of the cadence sensor reads the readings from your crank.
Also you might want to check that your zip ties are UV rated, generally black is for outdoor use only.
Panz05
Postby Panz05 » Sat May 04, 2013 2:52 pm
Thanks for that. When I had the sensor on top of the frame, I couldn't get the speed magnet to clear the arm which is why I put it on the bottom of the frame.
The cadence magnet on the crank arm is within 5mm and the speed magnet is within 5mm of the retractable arm.
I will flip it over and play with it some more.
The white cable ties are just temporary as i already used the black ones. I have to get some new ones.
Thanks again, hopefully this afternoons ride will show up some more accurate results.
Lapierre FDJ Di2
Panz05
Postby Panz05 » Sat May 04, 2013 8:20 pm
I have turned it around, like you suggested. I couldn't get clearence when the arm was down, so I lifted it up. Do you think that will cause any issues?
I have tested everything and it all seems to be working. I will see how it goes on my ride tomorrow morning.
Here is how it is now mounted.
Lapierre FDJ Di2
antipodean
Postby antipodean » Sat May 04, 2013 8:34 pm
The arm on my sensor is in the upward position it works fine.
My question is, why are you using those hideous white cable ties?
2013 Oppy SL
2013 Boardman CX Pro
2012 KHS Yuma 29er
Fitzroy
Postby Fitzroy » Sat May 04, 2013 8:35 pm
No, no issue.
My Last 2 bikes had to have the arm up due to clearance. Just make sure everything is tight as required and you won't have an issue.
Panz05
Postby Panz05 » Sat May 04, 2013 9:38 pm
i am using the white cable ties simply because I made a school boy error with the black ones when I first put the sensor on and didn't have any replacements. I will try and find some tomorrow when I go out because I agree they look hideous :-)
Lapierre FDJ Di2
lump_a_charcoal
Postby lump_a_charcoal » Sat May 04, 2013 10:17 pm
You can buy a small magnet which will fit to the back of your pedal bolt, which allows you to remove the crank magnet + cable tie.
Well worth it IMO.
le_quiet_uno
Postby le_quiet_uno » Sun May 05, 2013 12:51 am
lump_a_charcoal wrote:You can buy a small magnet which will fit to the back of your pedal bolt, which allows you to remove the crank magnet + cable tie.
Well worth it IMO.
+1 it works really well for me.
2009 - Current - BMC SL 01 [2009]
2008 - 2009 - Cervelo R3 [2008]
2007 - 2008 - Trek 1.4 [2005]
Panz05
Postby Panz05 » Sun May 05, 2013 9:04 am
I would be up for that. Where can I find these magnets?
Lapierre FDJ Di2
Postby RonK » Sun May 05, 2013 9:08 am
Panz05 wrote:I would be up for that. Where can I find these magnets?
You can get them from Jaycar, or on eBay.
sdnelson19
Postby sdnelson19 » Sun May 05, 2013 9:19 am
I'm a high school physics teacher, and I get mine from this guy.. really cheap and quick delivery. (also have one on my bike as a cadence magnet)
View item
DavidTomic
Postby DavidTomic » Sun May 05, 2013 9:21 am
http://www.frenegry.com.au
The ring magnets are slightly easier to remove if you ever need to get at you're pedal bolt, so I'd suggest starting with them.
http://www.frenergy.com.au/products/Rin ... .-N42.html
Order a few of them, and you can always stack them together if you need a little more height to trigger the sensor properly.
Users browsing this forum: CaffeineAU, familyguy, kb, murbul, Thoglette
