12v air compressor suitable for 120PSI tyres
DarrenL
Postby DarrenL » Thu May 09, 2013 12:56 pm
I'm looking for a 12v air compressor that is genuinely capable of up to 120psi for the presta valve tubes
I've got a supercheap compressor at the moment, that is supposed to handle 140psi, but in reality noses over at 80psi max
any suggestions ?
human909
Re: 12v air compressor suitable for 120PSI tyres
Postby human909 » Thu May 09, 2013 1:08 pm
A decent floor pump is faster, better and more reliable. I'm confused why you would need a 12V compressor.
Postby RonK » Thu May 09, 2013 1:31 pm
human909 wrote:A decent floor pump is faster, better and more reliable. I'm confused why you would need a 12V compressor.
Probably cheaper too.
PB12IN
Postby PB12IN » Thu May 09, 2013 3:41 pm
best of luck with that, even the big ARB ones would have trouble getting to that preasure.
I have 2 good 12V compressors one mounted in the car and one portable, and a 240v compressor but I use a $60 floor pump to do the bikes tyres, as it is quicker, easier, higher preasure and a whole lot quieter.
Xplora
Postby Xplora » Thu May 09, 2013 4:24 pm
They aren't designed to achieve that kind of pressure. Get a floor pump or a proper tank compressor which CAN handle it.
Pushy
Postby Pushy » Thu May 09, 2013 10:02 pm
Have you had a look at one of these?
$70 plus the battery and charger, not sure what the all up price would end up being.
Les
06' Giant TCR C1
08' Colnago CLX
07' Apollo Swift
VW Jetta Diesel 5.5l/100km
R12RT
Postby R12RT » Fri May 10, 2013 2:26 am
I have one of these:
http://www.supercheapauto.com.au/online-store/products/SCA-12V-Lightning-Air-Compressor.aspx?pid=129247
It will pump a bicycle tyre up to 120psi with no trouble at all.
However, it is easier and more convenient to use a floor pump.
John Beaven
2010 Malvern Star Oppy C6
2014 Giant Propel Advanced 1
rkelsen
Postby rkelsen » Fri May 10, 2013 10:15 am
Echoing the sentiments above: Lezyne Steel Floor Drive. $50 delivered to your door from Wiggle.co.uk.
That is all.
Xplora
Postby Xplora » Fri May 10, 2013 3:12 pm
15 dollar Fluid floor pump does it too, but it sucks bad. I can't bring myself to spend more money. LOL
Users browsing this forum: KristianJ, ldrcycles, Majestic-12 [Bot]
