Page 1 of 1
Changing crankset
Posted: Thu Jun 13, 2013 7:26 am
by r11ss
Hi,
I would like to change my Sram red 53-39 for a 50-34. Do I need to worry about which bottom bracket (GXP/BB30) cranks to buy?
Sent from my GT-I9505 using Tapatalk 2
Re: Changing crankset
Posted: Thu Jun 13, 2013 9:02 am
by Duck!
Yes, as GXP & BB30 are not interchangeable. Check what you currently have and replace it with the same type.
Posted: Thu Jun 13, 2013 11:51 am
by tsatra93
Do you need to take off the cranks to see which BB you have? Or does it say it somewhere?
Posted: Thu Jun 13, 2013 11:55 am
by Purt
Duck! wrote:Yes, as GXP & BB30 are not interchangeable. Check what you currently have and replace it with the same type.
If you have BB30 you can buy an adapter to fit GXP. Not the other way round though.
tsatra93 wrote:Do you need to take off the cranks to see which BB you have? Or does it say it somewhere?
It usually won't say on the cranks. It might say something on the BB area on the frame. Could just google your bike model.
Posted: Thu Jun 13, 2013 12:20 pm
by tsatra93
Problem is the bike is 2nd hand with upgraded parts... Looked at the BB area and apparently I have this in it:
http://tbsm.com.au/bike-parts/drivetrai ... cups-15381" onclick="window.open(this.href);return false;
I have no idea about bike parts....but what is that? Ceramic cups? is it the bottom bracket? or just he red things at the end?
Posted: Thu Jun 13, 2013 12:59 pm
by Jesmol
Ummmm , they dont fit SRAM cranks (at least not GXP ones).
You could probably check roughly by measuring the Internal Diameter of the tube running through the cranks, GXP Std is a 24mm OD tube, BB30 is a 30mm OD tube. Not sure what the ID is, but would be under 20mm for the GXP version.
Posted: Sun Jun 16, 2013 9:21 pm
by avroncotton
Can't you just change the chainrings and adjust the chain accordingly.
Posted: Sun Jun 16, 2013 10:25 pm
by find_bruce
avroncotton wrote:Can't you just change the chainrings and adjust the chain accordingly.
Sadly no - the 53/39 will have a bolt circle diameter (bcd) of 130 mm while a 50/34 will have a bcd of 110 mm.
