How to correct Garmin 500 ride
Mustang
Postby Mustang » Mon Jun 24, 2013 6:06 pm
Saturday I rode just 15 km, I stopped the timer & turned the Garmin off.
Sunday I rode the Bris to Bay 100km.
In the excitement of the start I forgot to do the reset, the ride now shows the Sat ride, the distance from home to the start & the Sun ride.
When I download the ride to Garmin Connect it only shows the two rides combined (which is OK) but when I upload to Strava I have the travel distance by car as well????
Any suggestions?
I have saved the ride in a TCX file but when I open the file to correct!!! its past this baby boomer!!
Any suggestions? I would dearly like to keep my meters climbed.
A_P
Re: How to correct Garmin 500 ride
Postby A_P » Mon Jun 24, 2013 6:37 pm
can you split the ride with Garmin Base Camp, edit and then upload to strava?
Mustang
Postby Mustang » Mon Jun 24, 2013 7:05 pm
A_P wrote:can you split the ride with Garmin Base Camp, edit and then upload to strava?
Never heard of Base Camp? is it in the Garmin Connect area?
A_P
Postby A_P » Mon Jun 24, 2013 7:28 pm
Postby bychosis » Tue Jun 25, 2013 7:49 am
Strava let's you crop the start and end of a ride. Not sure if you can upload it again to end up with two copies one cropping off the end, the other cropping off the start.
Mustang
Postby Mustang » Tue Jun 25, 2013 8:36 pm
No success with suggestions so far:
come on you geeks?????? I,m behind the eight ball I need you helpppp
darkelf921
Postby darkelf921 » Tue Jun 25, 2013 8:47 pm
I've had a similar incident happen to me. I emailed Strava support and they fixed it for me. Try emailing support.
My YouTube http://goo.gl/UlJrkN Channel
nickobec
Postby nickobec » Tue Jun 25, 2013 10:09 pm
Golden Cheetah
GPL software
It will let you split rides into sperate files, even suggest logical places to split.
Does heaps of other things too
CRV
Postby CRV » Wed Jun 26, 2013 9:58 am
I use the crop ride feature on Strava, found under the actions tag, works well to reflect only the part of your ride you want to upload. Also easy to post/log the previous segment, you just need to upload whole ride again and re-crop. Hope that helps.
Mustang
Postby Mustang » Wed Jun 26, 2013 12:18 pm
Thanks Guys,
Crop the ride did the trick. Didn't see it on first suggestion.
Good to see you back Nicobec
