Longest run without a puncture
Posted: Tue Jul 23, 2013 9:05 pm
So what is the furthest distance or time (assuming regular riding) you have gone without a puncture ?
BNA - For the Australian Cycling Community
http://www.bicycles.net.au/forums/
I agree with lobstermash - you go first ...Paul B wrote:So what is the furthest distance or time (assuming regular riding) you have gone without a puncture ?
I got the Maraton plus fitted when I bought the bike, some bindis got me up near Corowa once but if I run them properly inflated there are no puncture.TCAT wrote:What's a puncture?
I use Schwalbe Marathon tyres and punctures are a thing of the past. I didn't take down the odometer reading when I purchased my second last Marathon but it may have done 8,000 to 10,000kms before I wore it out without a puncture.
The puncture fairy reads these forums... viewtopic.php?f=12&t=60292" onclick="window.open(this.href);return false;cyclotaur wrote:I agree with lobstermash - you go first ...Paul B wrote:So what is the furthest distance or time (assuming regular riding) you have gone without a puncture ?
I have, I got a flat in my first generation Nike Air shoes in the first couple of weeks. They refused warranty; I've not bought a Nike product since. Back then I wore out 4 pair of training shoes and a pair of racing flats per year.bychosis wrote:I don't run much, but I haven't ever had a puncture in a shoe.
Damn you puncture fairyThe puncture fairy reads these forums... http://www.bicycles.net.au/forums/viewt ... 12&t=60292" onclick="window.open(this.href);return false;
I am going 'off thread' here bit. I believe you change your tyres from front to back when the back one wears out. Would that be the case with the Vittoria tyre above? My 8 to 10 thousand kms was all done on the back. If you got that all on the back I may have to give them a go.il padrone wrote:I went over 14,000kms with no punctures on my Vittoria Randonneur Cross tyres on the old Sedona MTB, about 4 years of cycling.
Sparx wrote:Just ordered a Marathon Plus.
Put that in your pipe Puncture God!!!
I did 14,000 on a pair of serfas drifters, the rear wore out at 14,000 - the front is still going - IMO the front will perish before it wears out.TCAT wrote:I am going 'off thread' here bit. I believe you change your tyres from front to back when the back one wears out. Would that be the case with the Vittoria tyre above? My 8 to 10 thousand kms was all done on the back. If you got that all on the back I may have to give them a go.il padrone wrote:I went over 14,000kms with no punctures on my Vittoria Randonneur Cross tyres on the old Sedona MTB, about 4 years of cycling.
Both tyres lasted until 14,000 kms when I retired them due to some specks of red puncture protection layer showing. They had been swapped arond at about 7-8,000kms when the front was still in excellent comdition and the rear was showing wear but sill had plenty of life. I ended up re-using that old rear (now the front) for a few more thousand kms just recently.TCAT wrote:I am going 'off thread' here bit. I believe you change your tyres from front to back when the back one wears out. Would that be the case with the Vittoria tyre above? My 8 to 10 thousand kms was all done on the back. If you got that all on the back I may have to give them a go.il padrone wrote:I went over 14,000kms with no punctures on my Vittoria Randonneur Cross tyres on the old Sedona MTB, about 4 years of cycling.
I got less than 2000km out of a pair on my tandem. I guess the extra load wasn't good for them...il padrone wrote:Both tyres lasted until 14,000 kms when I retired them due to some specks of red puncture protection layer showing. They had been swapped arond at about 7-8,000kms when the front was still in excellent comdition and the rear was showing wear but sill had plenty of life. I ended up re-using that old rear (now the front) for a few more thousand kms just recently.TCAT wrote:I am going 'off thread' here bit. I believe you change your tyres from front to back when the back one wears out. Would that be the case with the Vittoria tyre above? My 8 to 10 thousand kms was all done on the back. If you got that all on the back I may have to give them a go.il padrone wrote:I went over 14,000kms with no punctures on my Vittoria Randonneur Cross tyres on the old Sedona MTB, about 4 years of cycling.
I had similar tyre life from a second pair on the new Thorn - they lasted for 2 years of riding, doing 14,000kms. The tyres again had no penetration punctures in that time.
Hmm.... 26x1.75, or the 700C version ? I think the 26x1.75 give a beefier tread and maybe better life. A number of friends of mine are using the same tyres now and are certainly having the same experience with punctures - no penetrationsironhanglider wrote:I got less than 2000km out of a pair on my tandem. I guess the extra load wasn't good for them...
700c - 28. They felt terrible in the corners on narrow rims at less than 100psi, the noise at steep cornering angles didn't inspire confidence either. I even had a puncture too, (a 3" nail which would have gone through anything).il padrone wrote:Hmm.... 26x1.75, or the 700C version ? I think the 26x1.75 give a beefier tread and maybe better life.ironhanglider wrote:I got less than 2000km out of a pair on my tandem. I guess the extra load wasn't good for them...
+1ironhanglider wrote:700c - 28. They felt terrible in the corners on narrow rims at less than 100psi, the noise at steep cornering angles didn't inspire confidence either. I even had a puncture too, (a 3" nail which would have gone through anything).
They weren't the right tyres for the job I ended up wanting them to do at the time.
