Fulcrum 5 V Campy Zonda wheelset?
andione1983
Postby andione1983 » Sun Sep 15, 2013 7:37 pm
anyone have experience with these two wheelsets, the zonda is 130 bucks more than the fulcrum 5... are they worth the extra for 100grams lighter?
are they that much of a better wheelset?
Do these wheelsets generally come with skewers?
http://www.wiggle.com.au/campagnolo-zon ... -wheelset/
http://www.wiggle.com.au/fulcrum-racing ... -wheelset/
thanks in advance
i am thinking of getting a set as spare for when my main set of wheels are out of action, like what happened this weekend
Road Bike - 2013 Merida Ride Lite 93
MTB - Boardman Team Pro 2013
Re: Fulcrum 5 V Campy Zonda wheelset?
Postby RonK » Sun Sep 15, 2013 7:50 pm
Zondas are a better grade of wheel than Fulcrum 5s, even if they do come out of the same factory.
Ken Ho
Postby Ken Ho » Sun Sep 15, 2013 7:53 pm
Well, I'm a Campy !! BAN ME NOW FOR SWEARING !!, so go the Zondas.
Postby Duck! » Sun Sep 15, 2013 8:58 pm
andione1983 wrote:Do these wheelsets generally come with skewers?
Yes.
macca33
Postby macca33 » Sun Sep 15, 2013 9:09 pm
Andy, the Fulcrum 5s are a good wheelset - I have a set as a spare and they roll exceptionally well.
The Zondas are the same level as the Fulcrum R3s (I believe) and I also have a set of R3s - they are slightly better rolling, but have a lower spoke count 16/21 R3, 18/21 Zonda vs 20/24 R5. The Zondas appear to be on sale online at present also.
The Fulcrum / Campy wheelsets are good value and sturdy wheels IMO.
zero
Postby zero » Mon Sep 16, 2013 12:49 pm
andione1983 wrote:anyone have experience with these two wheelsets, the zonda is 130 bucks more than the fulcrum 5... are they worth the extra for 100grams lighter?
thanks in advance
In a fulcrum 5 set, you get skewers, manual, rim is taped, its properly true straight from the box, and you get a card signed by the guy who built it, ie fit the cassette and tires and go. It is however a semi aero wheelset, not a lightweight wheelset (it has reasonably thick braking surfaces etc, they are intended to last a while).
Causidicus
Postby Causidicus » Mon Sep 16, 2013 7:25 pm
Fulcrum 5 have cartridge bearings.
Zonda have Record hub internals, Record freehub and Record skewers.
$130 for real hubs and skewers? Easy choice.
andione1983
Postby andione1983 » Tue Sep 17, 2013 5:33 pm
Ok just broke another spoke on my cheap stock Alex Rims, over it... after getting a new spoke and a straighten on Saturday $33.00... So what I want to know... If i buy the campy or fulcrum are they going to be a durable wheelset for bike track riding and a heavy guy like me at 98kg...If there are any other wheels please suggest but in don't really want to spend much more than 400$ for a pair and I don't want a really heavy set that would be heavier than my Alex rims / and a downgrade ... So an upgrade if you could say I'm assuming fulcrum and campy use better quality components than the Alex rims I have at present?
The Alex rims have just lasted on 1500klms or so... Is that crap? Should I bet longer? Should I take them back to the shop that straight them or to where I brought under warranty?
Sent from my Galaxy far far away....
andione1983
Postby andione1983 » Tue Sep 17, 2013 5:39 pm
Next question can I keep riding minus 1 spoke till I get a new wheelset in its only gone out of straight by a mill or two
andione1983
Postby andione1983 » Tue Sep 17, 2013 8:27 pm
From reading above posts again I think the fulcrum 5 wheels set will be a good durable wheelset for my bike... It's not a top line race bike so as long as the wheels are durable I will be happy... So unless anyone states otherwise in the next few mins I'm about to place my order on wiggle
Postby RonK » Tue Sep 17, 2013 8:34 pm
I'd be going the Zondas at 98kg.
andione1983
Postby andione1983 » Tue Sep 17, 2013 9:04 pm
Ok I pushed the buy it now on the Zondas I can transfer them to a new bike later down the track if i upgrade... Thanks fellas.. I'll let you know how they go.
winstonw
Postby winstonw » Tue Sep 17, 2013 9:11 pm
I thought the Zondas were on par with 3s...which I wouldn't consider a durable wheelset. details on another recent thread.
macca33
Postby macca33 » Tue Sep 17, 2013 9:15 pm
winstonw wrote:I thought the Zondas were on par with 3s...which I wouldn't consider a durable wheelset. details on another recent thread.
Nothing wrong with the R3s - I've ridden them on crap roads for over 3000Km at a weight well above 100Kg and they are fine. When I purchased them (Ebay) as a secondhand wheelset, they had been well used.
rangersac
Postby rangersac » Tue Sep 17, 2013 10:49 pm
I'm 95kg and my Zonda's have done me just fine for the last two years
andione1983
Postby andione1983 » Tue Sep 17, 2013 10:52 pm
rangersac wrote:I'm 95kg and my Zonda's have done me just fine for the last two years
Awesome good to know... What cassette you running from what I read maybe I should ditch my Tiagra? And put an ultegra cassette on too.... I read that steel cassettes can dig into the freehub
eeksll
Postby eeksll » Tue Sep 17, 2013 10:59 pm
andione1983 wrote: ... I read that steel cassettes can dig into the freehub ...
It is not the steel cassettes "fault". The "fault" is in the light weight alloy (non steel) hub on the wheels.
winstonw
Postby winstonw » Wed Sep 18, 2013 7:45 am
How many k's do you have to put on wheels before they are considered durable? I'd say way more than 30,000, on a mixture of roads including really cr@p, and bombing down steep hills with some heavy braking.
Two spokes broken in 3 weeks on the 3s I was using a few weeks ago. They've got around 25,000 on them. I weigh 86kg.
viewtopic.php?f=9&t=67022
Causidicus
Postby Causidicus » Wed Sep 18, 2013 7:55 am
andione1983 wrote:...should ditch my Tiagra? And put an ultegra cassette on too.... I read that steel cassettes can dig into the freehub.
Not on Campagnolo or Fulcrum wheels, as the freehub body for non Campagnolo cassettes is steel.
andione1983
Postby andione1983 » Wed Sep 18, 2013 8:08 am
winstonw wrote:How many k's do you have to put on wheels before they are considered durable? I'd say way more than 30,000, on a mixture of roads including really cr@p, and bombing down steep hills with some heavy braking.
well I take it my Alex rims are fit for the bin? 2 spokes in 3 days with 1500 ks...? Or should I get it repaired one more time and keep using until it breaks again then throw the campys on
andione1983
Postby andione1983 » Wed Sep 18, 2013 8:09 am
So i take that as yes I can put my Tiagra cassette on the campys and not worry about anything happening..
rangersac
Postby rangersac » Wed Sep 18, 2013 9:59 am
andione1983 wrote:What cassette you running from what I read maybe I should ditch my Tiagra? Sent from my Galaxy far far away....
Veloce 11-25 cassette.
andione1983 wrote:well I take it my Alex rims are fit for the bin? 2 spokes in 3 days with 1500 ks...? Or should I get it repaired one more time and keep using until it breaks again then throw the campys on
Ditch the Alexs. I've gone through several Alex rims (supposedly decent spec 36H ACE19) on my commuter through a mixture of cracking spoke holes, constant de-tensioning and spoke breakage.Fortunately I have a good relationship with my LBS and they sorted out the rebuilds and supplier hassling, until even they spat the dummy and went for Mavic A319s. No problems since.
eeksll
Postby eeksll » Wed Sep 18, 2013 4:26 pm
actually looking at the tiagra 4600 cassette exploded diagram vs the 6700 ultegra cassette exploded diagram you will probably be better off with a tiagra cassette.
probably: assuming there are more contact points of the tiagra cluster with the freehub.
andione1983
Postby andione1983 » Wed Sep 18, 2013 6:19 pm
eeksll wrote:
andione1983 wrote:
Causidicus wrote:[quote="andione1983"]...should ditch my Tiagra? And put an ultegra cassette on too.... I read that steel cassettes can dig into the freehub.
probably: assuming there are more contact points of the tiagra cluster with the freehub.[/quote]cool... Just put in an order for a Tiagra cassette (second one)
andione1983
Postby andione1983 » Mon Sep 23, 2013 6:52 pm
Here's the results ImageImage
Users browsing this forum: 10speedsemiracer, 1Rowdy1, AardMark, find_bruce, holywater, Waccofozzy, Yahoo [Bot]
