Rust coming out of crank arm, creaking noise when peddling
Postby newblah » Fri Aug 08, 2014 11:49 am
This week I've had a bit of a creaking noise come from my crank when peddling hard, when I got close to work this morning the creaking noise was quite a bit louder, when I stopped at work I noticed what looks like rust running down the crank arm.
http://i.imgur.com/q6rf7Ev.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/y3WJamu.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/vejVQvU.jpg" onclick="window.open(this.href);return false;
Anyone know what the likely damage here will be and what would likely need to be replaced?
- jules21
Re: Rust coming out of crank arm, creaking noise when peddli
Postby jules21 » Fri Aug 08, 2014 11:57 am
or you've spun a BB bearing. replace bearing. you will need tools if you don't go to LBS.
- bychosis
Postby bychosis » Fri Aug 08, 2014 12:00 pm
Edit: My bad, should have looked at the pics. Only applicable to square taper cranks.
- duncan16v
Postby duncan16v » Fri Aug 08, 2014 12:08 pm
http://bike.shimano.com/media/techdocs/ ... 746319.pdf" onclick="window.open(this.href);return false;
- jules21
Postby jules21 » Fri Aug 08, 2014 12:13 pm
- duncan16v
Postby duncan16v » Fri Aug 08, 2014 12:29 pm
newblah - are you sure the rusty water isn't just mud?
- Nate
Postby Nate » Fri Aug 08, 2014 12:37 pm
remove BB completely & drain/clean
- jules21
Postby jules21 » Fri Aug 08, 2014 12:38 pm
pretty sure the bolt is aluminium. never seen a rusty crank bolt. the bearings will rust if exposed to moisture, i.e. when they failduncan16v wrote:The source of the rusty coloured water appears to be the bolt, but that's an awfully lot of rusty coloured water... http://i.imgur.com/vejVQvU.jpg" onclick="window.open(this.href);return false;
- duncan16v
Postby duncan16v » Fri Aug 08, 2014 12:43 pm
That's why I'm wondering if that's just mud. The bearings in those sealed external cups are behind O-rings/seal arrangement (or, at least, they are on the Deore crankset I installed on my son's bike recently), so I'd expect the staining to be inside the frame rather than running down the crank arm - unless the the seals were lost when the arm fell off...jules21 wrote:pretty sure the bolt is aluminium. never seen a rusty crank bolt. the bearings will rust if exposed to moisture, i.e. when they failduncan16v wrote:The source of the rusty coloured water appears to be the bolt, but that's an awfully lot of rusty coloured water... http://i.imgur.com/vejVQvU.jpg" onclick="window.open(this.href);return false;
- jules21
Postby jules21 » Fri Aug 08, 2014 12:51 pm
- ohexploitable
Postby ohexploitable » Fri Aug 08, 2014 2:25 pm
- Dragster1
Postby Dragster1 » Sat Aug 09, 2014 6:16 pm
Postby newblah » Sun Aug 10, 2014 10:45 am
This was definitely not mud, the fact that it was only on that specific part of the bike accompanied by the creaking that started getting quite bad made me pretty sure of it.
What I didn't report back on is that I tried riding the bike to the train station after work, all of a sudden the pedals were completely stuck and unable to move. Took it to my local LBS (Success bike force, WA) and they replaced the bottom bracket for me, the bottom bracket's seal containing the bearings had completely broken open. It was quite a mess.
Thankyou to all for providing some assitance! Its always good going into the LBS with some sort of idea as to what went wrong and what to brace yourself for
Postby newblah » Sun Aug 10, 2014 10:47 am
- ohexploitable
Postby ohexploitable » Thu Oct 16, 2014 10:47 pm
Postby rustychisel » Thu Oct 16, 2014 10:58 pm
Nate wrote:id say frame full of water...
This, completely. If the bearings are toast >50% probability you'll need to replace them.
