Bike GalleryRe: Bike GalleryAre those wheels 650s? Or 24"? Photo looked very weird at first glance!
Re: Bike Galleryyep wheels are 650c
The gap is intentional, as it was made as the Pave bike.... so bigger clearance, and yes it has plush flex in the rougher stuff, but goes like stink on the smooth!! If I tried I think I could get the weight down to about 6.1kg without too much effort, but right now she is very happy.... I do love it without the stickers... its hot!!! photo was taken (AT) f1.8 so there is very little DOF! so that makes it look purty...
Re: Bike GalleryTrek Madone 4.7
Very happy with the new bits. Garmin Edge 500 Pro Race 3 Tyres (although I had 2 flats first ride out) Ultegra pedals Fizik seat ![]() ![]()
Re: Bike GalleryVery nice... I like the paint scheme. What is the sensor on the forks as it's not the normal Garmin speed / cadence sensor which mounts on the chain stay ?
Re: Bike Gallery
photo taken the morning I replaced the Polar setup to the Garmin Edge 500. (best bike bit anyone could purchase)
Re: Bike Gallery
doh... I was wondering Agree on the Garmin... love mine.
Re: Bike GalleryNice looking Madone
Cheers Dave.
Re: Bike Gallery
Nice bike, but get used to this! Jim MY RIDES: My Velospace Profile
Re: Bike GalleryNew baby my first foray into MTB world
![]() ![]() A new baby for the stable have not ridden yet. Still a virgin and still has bell. Opinions ?? ![]()
Re: Bike GalleryCrog, that's a really nice colour; didnt realise felt made such great looking mountain bikes. Seems to have a decent kit as well, but it's about time to ride it hard and dirty, and 'deflower' it. Sure you'll get hot and sweaty, but that's kinda the point
What are these salesmen peddling?
Re: Bike GalleryYeah mate that Felt is very nice, I only hear good things about them and seriously considered one when I was in the market for a hardtail. I ended up finding a deal on something else to good to pass up but I really rate them.
Your going to freakin love it Can ya tell me a bit more about those barends? I use them as well, same brand but I have not seen that shape before? interesting....
Re: Bike GalleryYeah haapy with the Felt and baby blue colour A little different from the norm and got it at goldcross for $1550 with pedals and bar ends chaper as it is an 09 model
Not being to up to speed on the MTB spec side of things (I know more about roadys) it appears to have good gear on it although carbon stays worry me a little bit bar ends from goldcross and specs from website below pics Only concerns are the hydraulic breaks and forks with respect servicing etc. Will need to download manuals ![]() ![]() ![]() ![]() from spec sheet not sure if anything needs upgrading FRAME Felt Superlight XC Series 7005 Double-Butted Aluminum, with Carbon Fiber Seat Stays w/Increased Tire Clearance, Monostay Design, 45mm Integrated Head Tube, Replaceable Derailleur Hanger, Disc-Brake Specific FORK Recon SL Solo Air with TurnKey lockout, Forged 6061 T-6 aluminum, Alloy Steerer, Disc brake specific Magnesium lower. 7000 series 32mm straight wall aluminum stanchions. 3.86 lbs. Disc Brake Specific Lower Legs, Includes Poploc Remote HEADSET Integrated 1-1/8" Aheadset--Cane Creek Type 45 Degree Sealed Cartridge Bearing, with Alloy Laser Top Cap, Custom Curved 1 x 15mm + 2 x 5mm Straight Washers STEM FELT RXC STEM Oversized 6061 Alloy, 3D Cold-Forged + CNC,1-1/8" Threadless 4-Bolt, 5 Degree Rise. 31.8mm Bar Bore CP Hardware. Extensions: 15.5=90mm; 17.5=100mm; 19.5=110mm; 21.5=120mm HANDLEBAR OVERSIZED 31.8mm Butted Aluminum Flat Bar, 5 degree Bend, Width: 600mm, 140 grams GRIPS: Felt Dual-Density Extra-Soft & Sticky (Recipe #25)center with Hard Outer Durometer, 130mm Length, 30mm OD, Grey outer/Blk grip section BAR END CAPS Rubber Plugs w/ Felt logo Bubble Decal, Included w/Grip SHIFTERS SRAM X-7 Trigger 27 speed Shifter FRONT DERAILLEUR Shimano Deore FD-M531 Dual Pull REAR DERAILLEUR Sram X-9 with X.O. styling 212grams CRANKSET Truvativ Blaze 3.0 3-Piece Crank w/Howitzer M15 Axle Interface for External Bearing BB, Cold Forged Aluminum, 42/32/22T Steel Rings, Lengths: 15.5=170mm; 17.5-21.5=175mm BB SET Truvativ Howitzer M15 Cr-Mo Axle with External Bearings FREEWHEEL SRAM PG-950, 9-Speed Cassette, 11-32T CHAIN: Sram PC-951 (9-Speed) Silver Outer BRAKE LEVERS Avid Juicy 5 BRAKES: Avid Juicy 5 Hydraulic, Rotors: 185mm Front; 160mm Rear CABLES: Custom Felt Cable Set, Standard Black Casing, Featuring CP Stamped Logos & FELT Rubber 2-Tone Tube Tops at Head Tube and One Red CNC Alloy ferrule Brake hose supplied with Brakeset SADDLE: Felt RXC Lite, Super Low Side Profile Look with Medium/Flat Top, Superlight Foam Double-Density Base, Silver Tubular Cr-Mo Rails SEAT POST Felt Alloy Micro-Adjust, 100% Black, 2014 Low-Profile Forged Head & Extruded Rall Clamps, 27.2mm x 350mm (CEN) SEAT POST CLAMP Felt Bolt-Type with Logo, Cold Forged + CNC, 6061 Aluminum, with Steel Barrel Nut Design, 31.8mm F/HUB Shimano FH-M475, 6-Bolt Type Rotor Mount, 32H, with Quick Release R/HUB Shimano FH-M475, 6-Bolt Type Rotor Mount, 9 Speed Cassette 32H, with Quick Release RIMS Mavic XM-317 Disc Doublewall, 26 x 1.5 x 32H, 23mm Width, Presta Valve, DISC Brake-Specific, Black Anodized With Single Eyelets TIRE Felt Devox RXC tire Low Knob RXC specific design, XXX Endurance Compound, 60 tpi case with Folding Tubeless ready bead, 26 x 2.0 SPOKES Black Stainless 14G/15G double butted with Blk Brass Nipples PEDALS None ![]()
Re: Bike GalleryAnother Trek ! a Trek Madonne 5.5
Apologises for poor quality as it was off an iPhone. Fingers crossed met the posting pics requirement. full Dura Ace grouppo came with Conti Gp4000s tyres LooK keo carbon pedals ![]() How my babe travels ![]() edge 500 from highlytunedatheletes for $429 free postage! ![]() Sideview 1 ![]() Sideview 2 ![]() Whats left of "Botranger" (Ritchey Stem/ FSA compact Wing - changed the ritchey due to drop angle / pro fit by ChurchillCyc) ![]() Last but not least, Fulcrum 1 wheelset !
Re: Bike GalleryClean looking bike there Stang
Goal 6000km ![]()
Re: Bike Gallery
Thanks, just had it serviced and cleaned before tooking the pic Nice s2 there wibbit. LOVE the white/red feature
Re: Bike GalleryThink it is about time I shared a few pics of my pride and joy.
Giant Defy Advanced 2 Standard specification as per http://www.giant-bicycles.com/en-au/bik ... 306/37460/ with one slight change, swapped the standard cassette for 12/27 to give the old bugger a little help on the hills. Carbon bottle cages Polar 200CS CAD computer (Includes HR and Cadence sensors) Cateye tail light A few images: ![]() ![]() Last edited by grt046 on Sat Jun 26, 2010 3:51 pm, edited 3 times in total.
Re: Bike GalleryHey Wibbit, those angles are really laid back, what's it like to ride.
Goal 6000km ![]()
Re: Bike GalleryYou'll be right GRT once you get some Ks under the belt, nice bike!
Goal 6000km ![]()
Re: Bike GalleryThe giants are really starting to look the buisness but what is with the black spoke protector
Re: Bike Gallery
The new mavic disc wheel
Re: Bike Gallery![]() ![]() Still have to properly polish the stripped fram, the San Marco Squdara saddle arrived in blue instead of yellow, and Im still waiting to apply new yellow bar tape and Rollamajig. Slowly slowly for my first build. Record 11speed next year too
Re: Bike GalleryCrap! In photobucket the right of both shots arent cut off!
Re: Bike GalleryGo to the bottom right hand side of your browser and reduce the screen size to 95%, maybe 90. Or reduce the size on photobucket.
Who is online |
