Tales of the Big W fatty. The Hyper Mammoth.
Cardy George
Re: Tales of the Big W fatty. The Hyper Mammoth.
Postby Cardy George » Fri Feb 23, 2018 6:15 pm
bychosis wrote:Got some new tyres for cheap. Weighed them and both combined are lighter than the lightest of the two I removed. There was also a whopping 300g difference between the two bigW tyres!! Pretty sure I haven’t worn off 300g with maaaadd skidz, but i guess it’s possible.
Weekend should get some more time for installation and then put the whole beastly Mammoth back of the bathroom scales.
Ooooh, where from and how much?
I remember losing nearly a kilo just from removing the tubes at my first (failed) attempt at Ghetto Tubeless
Postby bychosis » Fri Feb 23, 2018 6:56 pm
Not New unfortunately. From a wanted ad on rotorburn.
It’s just nuts how heavy the tyres, and other parts, are.
Postby bychosis » Wed Apr 18, 2018 9:33 pm
Updates. Finally got some round tuits.
Somewhere in the vicinity of 4.5kg lighter. Still no lightweight at 18.8kg but it’s a lot better than before.
Postby bychosis » Thu Apr 19, 2018 8:23 am
Parts:
Drillium rims. Duct tape rim strips. Saving over 400g of holes and swarf and not including what went straight into the vacuum cleaner.
Tyres: Second hand Vee 8. $30. Saving: 2.8kg (one original tyre's worth)
Tubes: Still there, might go tubeless, or get some lighter tubes.
Seatpost: eBay alloy. $16. Saving: 84g. Not much, but the existing one was a tad short for me.
Stem and Bars (not in pic): Alloy. $0 (parts bin). Saving 307g. Originally I was only going to replace the bars and got stopped because the stock stem takes 22.2mm BMX sized bars. Fortunately I found another 1-1/8 quill stem in my parts bin so the alloy 25.4mm MTB bars got a second try.
Crankset: Shimano Alloy + widgit 32tooth ring. $0. Savings approx 550g - forgot to weigh it before installation.
Cog: Switched gearing to make it a bit easier, 18tooth. Gone from 36-20 to 32-18.
Chain: switched to lightly used XTR 9spd from original SS. saving ??
Saddle: weighed the same as the potential replacement, so left the original.
Pedals: original
Removed: kickstand and chain guard. Saving: 422g.
Better remove those reflectors too.
Users browsing this forum: BugsBunny, mikesbytes, Newcastle Dave, P!N20, vinski
