fly12 first impressions
- GeoffInBrisbane
Re: fly12 first impressions
Postby GeoffInBrisbane » Tue Sep 13, 2016 7:26 am
Bug, or am I just too stoopid to work out how to get it out of BT mode?
- PiratePete
Postby PiratePete » Tue Sep 13, 2016 7:25 pm
Umm, I haven't had that one. Normally after finishing with the app, I press the power button on the camera to shut it down. BT remains active for several days, so if you open the app the camera will connect without needing to be powered on first. You could try fully powering the camera down to see if that makes a difference, this is performed by pressing and holding both buttons till it chimes. Otherwise a paperclip reset may be in order. Failing that I'd be on the blower to Cycliq for advise.GeoffInBrisbane wrote:One thing I've run into is that if my phone has BT turned on (for Garmin upload) when I plug the charger into the Fly12, it won't charge but seems to stay stuck in BT mode. I've had to run the battery flat to get it out of BT mode so I can charge it.
- GeoffInBrisbane
Postby GeoffInBrisbane » Tue Sep 13, 2016 7:47 pm
Postby eldavo » Sun Sep 18, 2016 1:28 am
I've changed the mount between several bikes and the alloy mount threads first stripped out at the top mounted on OS bar.
Using it only on 22mm handlebar grip area worked with bolts going right through for full thread use, but needing a grip spacer, compressing the rubber down eventually stripped the remaining thread.
So I'm looking for a new mount, ideally 22-32mm like this Cygolite Locktite gen2 quick release I'm used to.
I'm going to look at the screw mounted base that swivels, to see if I can use the Fly12 tripod mount adapted to the Cygolite handlebar mount. I have a Cygolite gen1 mount I can sacrifice if it looks promising and I can't find an equivalent compatible mount off the shelf.
- biker jk
Postby biker jk » Sun Sep 18, 2016 9:45 am
After lodging a support ticket with Cycliq and a bit of back and forth with Andrew from Cycliq, it appears that Cycliq has a different definition of flash versus pulse...jasonc wrote:I think this is the same on the iOS app - they are the wrong way aroundbiker jk wrote:I discovered that I had to select Pulse Low (brightness) for Flashing Low (brightness) to actually work.
- biker jk
Postby biker jk » Wed Sep 28, 2016 7:53 pm
- AUbicycles
- Site Admin
Postby AUbicycles » Wed Sep 28, 2016 10:20 pm
Worth regularly doing a full wipe.
Postby eldavo » Wed Sep 28, 2016 10:44 pm
I used an old digital camera tiny tripod base/screw and the gen1 Cygolite Expilion Loctite bar mount.
Initial issue was longer than the original bolted clamp mount, so one bike it wasn't as good a fit, not my ideal long term solution, but nice to have another option.
- biker jk
Postby biker jk » Thu Sep 29, 2016 7:13 am
If the card is removed from the camera and used in my computer the video can be played. You can also play the video with the card in the camera via the Android app. But you can't play the video via USB connection to a computer "as a device not recognised" error occurs. This sounds like a Fly12 firmware problem.AUbicycles wrote:Was it a full format - writing to zeros?
- AUbicycles
- Site Admin
Postby AUbicycles » Thu Sep 29, 2016 9:35 pm
If you can successfully connect - then video over USB may still not be the fastest.
Have a look at Cycliq Fly12 reset information (reset to factory settings) or option to update firmware. Afraid I don't have the details handy but am sure it is easy to find on the website - at minimum, support is quite good.
- tomee
Postby tomee » Sat Oct 08, 2016 12:49 pm
i always run it at 1080 (AT) 45 in low flash and sometimes ill get a half battery warning after a morning commute
- Comedian
Postby Comedian » Tue Oct 11, 2016 5:29 pm
So far, touch wood, mine has been great on battery. I only run the light on low though.tomee wrote:does anyone else get inconsistent battery life
Postby eldavo » Tue Oct 11, 2016 6:46 pm
I scrounged some long bolts for full thread use in the partly stripped top thread on the 31.6 bars, love the original bar clamp and didn't like the thread rotation of the camera tripod mount.
- Mububban
Postby Mububban » Wed Oct 12, 2016 11:43 am
I get this sometimes. I use high flash but if it's 10 hours of run time with camera only, I'd have thought high flash would last more then 1.5-2 hours before it died on me?tomee wrote:does anyone else get inconsistent battery life
Then on other 2 hour rides I get home after using high flash and seem to have 1 or 2 beeps of life left when I turn it off.
Postby eldavo » Wed Oct 12, 2016 11:59 am
I didn't like the light mode options dropping after 50% battery consumed, so it wasnt my preferred primary light. I use it as camera only primarily, bonus backup light or flash, especially since the pair of Ding FL1 arrived from Kickstarter. They are also under bar mount lights and the 750lm casts shadow on the Fly12 400lm.
- Comedian
Postby Comedian » Wed Oct 12, 2016 4:30 pm
I'm quite happy with mine as a light. It's enough for me.eldavo wrote:Is there a temperature or day/night pattern between the rides? LiPo delivers power better at room temperature, so cold air plus wind chill may cause variation.
My main two gripes with the unit is that the LED indicator light is on the bottom if mounted upside down, and that you can't aim the light and the camera separately. I can't see a way around this one. If you have the camera straight then it is hard on oncoming bike eyes. I don't have much bike path on my commute so I can live with this.
Since I put the super good memory card in it hasn't missed a beat.
Postby eldavo » Wed Oct 12, 2016 4:51 pm
This plus the Ding light are two nice new 2016 Aussie Kickstarter products that have delivered (* everyone elses troubles not in focus but not forgotten for this statement).
- tomee
Postby tomee » Wed Mar 15, 2017 9:58 am
i get video corruptions or the thing just stops recording mid ride
running a genuine sandisk 64gb UHS extreme card
numerous logs with cycliq trying to troubleshoot the thing with them saying the device is fine
i dont understand how $100 dashcams in my cars which run the same SD card have never had dramas over the years and this device has been plagued with bugs from day one
- AUbicycles
- Site Admin
Postby AUbicycles » Wed Mar 15, 2017 6:24 pm
Also try a different card, even as a genuine Sandisk card, if the card is flawed, then it would be food to check it and rule that out with a secondary working card.
- Comedian
Postby Comedian » Wed Mar 15, 2017 6:57 pm
I had lots of problems with mine until I got just the best card I could buy. Hasn't missed a beat since.tomee wrote:I am about to give up on this POS camera
Try the car it came with, and if it doesn't play up then you know it's your card.
Postby cp123 » Thu Mar 16, 2017 11:23 am
I just didn't want to raise a ticket first off as I've just got an active ticket with the fly6 too and don't want to jinx myself or piss them off. other than that it has been good to date.
- Comedian
Postby Comedian » Thu Mar 16, 2017 1:08 pm
Watching this with interest. My biggest concern with the fly6/fly12 is their non replaceable batteries. So far, touch wood the fly12 has been excellent in this regard. I've done three normal commutes (40 minutes, one with light), and one two hour ride this morning (half with light) and it's beeping twice indicating half charge. I can live with that.cp123 wrote:I did a fly12 buy on the kickstarter opening. I'm not sure if its kaput. I can charge it up over night but put it on the bike and set off and its down to orange light shortly afterwards and conks out of charge within 15 mins. maybe it is a battery issue? should I just reformat it again?
- PiratePete
Postby PiratePete » Thu Mar 16, 2017 6:19 pm
Sounds like a battery, I'd suggest contacting Cycliq.cp123 wrote:I did a fly12 buy on the kickstarter opening. I'm not sure if its kaput. I can charge it up over night but put it on the bike and set off and its down to orange light shortly afterwards and conks out of charge within 15 mins. maybe it is a battery issue? should I just reformat it again?
Postby jasonc » Mon Mar 20, 2017 1:14 pm
- Comedian
Postby Comedian » Mon Mar 20, 2017 3:13 pm
Mine doesn't do that on either bike. Have you got cables pushing it?jasonc wrote:so how do i stop the thing rotating upwards? am using a k-edge combo mount. anyone got an ideas?
